Folding Gravel Bike build
Quoted: 233 Post(s)
Liked 151 Times
I'm going to build up the above frame (a ChangeBike DF-833G 650B MTB frame) into a gravel bike and need some inputs on the setup selection.
Purpose wise, I'd want to use it for weekend rides with roadies and also as the touring bike where it will see use on trails/gravel.
Its going to be with the Shimano 105 groupset running a 50/34T chainring and XT 11-40T cassette expanded via a road link.
Shimano 105 R7000 Compact Chainset (11 Speed) 50-34T
Shimano XT M8000 11 Speed 11-40t Cassette
One big issue will be the brakes.
I'd like to use cable actuated ones for easier troubleshooting (esp in the field).
So the TRP Spyre (cable actuated, road pull ratio) seems to be an ideal choice.
I am very confused by the mounting.
The frame seems to be IS mount and the TRP are either in post mount or flat mount.
1. So I should be getting the post mount version and using Post > IS adapters?
2. Do the adapters need to be TRP branded or just the generic Shimano ones will do?
3. I don't see the brakes having front/rear options so does that mean the same brakes are for both front and rear?
Any other inputs are welcome, especially on whether running a road link to expand the gear range will be viable.
TIA
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I ran a 50/34 crankset with an 11-36 cassette and did not need a roadlink.
Now I'm running 46/30 with an 11/42 cassette and don't need a roadlink either.
Likes For TimothyH:
Quoted: 716 Post(s)
Liked 807 Times
To answer your original questions.
1-yes
2-it doesn't have to be brand specific
3-the same caliper is used for front and rear
You didn't ask, but I agree that your chosen crankset will probably not work on that frame. The bottom bracket is 68mm, so that will work with the road cransket, but the crank arms probably wont clear the chainstays. The distance between the crankarms on most Shimano road doubles is 116mm. Measure the distance across the chainstays at 170-175mm back from the center of the bottom bracket. If it is more than 110mm, you don't have enough clearance to use that crankset.
1-yes
Likes For dsaul:
Quoted: 233 Post(s)
Liked 151 Times
Why? That’s a 5.5 pound frame that’s going to be extremely stiff. It’s going to handle strange with skinnier tires and really strange if they’re slicks. As someone who’s done a few roadie rides on a drop bar mtb with slicks - you’ll need to be seriously strong to keep up unless it’s a very casual ride.
But that’s not really what you came here for I suppose. I did note that although the Change website is seriously lacking specs, I’m almost certain your chosen crankset isn’t going to work on that frame.
I do ok with roadie rides on my 20" foldie, so long as I am sneaky and draft most of the time.
So this larger wheeled bike should at least perform at least the same (thats the plan anyway ).
This is not my only bike and I do have a Tri-bike, but it'd be nice if this new bike serves double duty every now and then.
Ok. Noted on the crankset.
If thats the case, is there something out there that would clear the chainstays and be at least 46/30T?
1-yes
1-yes
I just ordered a pair of TRP Spyres.
If you know of a crankset that can clear the chainstay and takes 48/32T or 46/30T, do let me know. TIA
Quoted: 716 Post(s)
Liked 807 Times
The White Industries G30 crankset will work with that frame and get you the gearing you want. Otherwise, I think you may be stuck with an MTB crankset. SRAM makes a few 2x MTB cranksets with 42/28 chainrings.
Likes For dsaul:
Quoted: 233 Post(s)
Liked 151 Times
Thanks for the replies.
Any idea if the Shimano GRX chainring with 46.9mm chain line will be worth waiting for to see if its a better fit?
The White Industries G30 has a chainline of 45mm, so it seems to suggest that the GRX will be a bit wider.
(Sorry, totally no knowledge on MTB stuff).
Bikes: Jamis Quest Comp
Quoted: 169 Post(s)
Alternate suggestion, if you aren't in a hurry(and not super tall): Velo Orange is making a mini-velo. https://velo-orange.blogspot.com/201...e-is-live.html
I want one so I can just slide it in the back seat of my car, or the hatch of a small suv without having to take the wheels off.
But I'm not sure if the sizing will work for me.
Quoted: 716 Post(s)
Liked 807 Times
GRX has a Q-factor of 151mm and the G30 has a Q-factor of 171mm.
Quoted: 233 Post(s)
Liked 151 Times
I've already got 2 mini velos.
In fact I toured on a smaller 18" one for a few years.
The reason for looking at a 650b build is that I found during touring that it would almost always involve some trail riding to some degree and small wheels are harder to roll over rocks, roots, etc.
Quoted: 233 Post(s)
Liked 151 Times
Just a short update on the status.
The frame arrived and I brought it to the LBS for a try out with a used 105 50/34T crank. The chainring was near touching the chainstay, while there were no issues with the crank arms clearing.
So I have to go for a smaller chainring, but I did not want to go under 42T if I could, to get the high gears for road rides.
I came up with a SRAM Apex brifter and X9 rear/crank combination, but unfortunately, the SRAM distro here does not carry such "less common" items.
So back to the drawing board....
Next, I thought of just paying up and getting the Force 1x with the 42T crankset and 10-42T cassette.
Again, another disappointment from the local distro.
They just don't have such 'weird' combos since 'real users' only use Red...
I'd have to order now and get them in August.
The SRAM clampdown on online retailers frustrates me since the local distro is basically sitting on their laurels and unwilling to provide a good range of Sram products while finding them online and willing to ship to Singapore is so hard.
Ended up, not willing to let the distro earn my money for such poor support and found an online store I could buy from.
Got the Rival 1x instead which was my preferred budgetary choice anyway and saved me a fair bit over Force 1x.
I just hope everything fits when they arrive.
My preliminary measurements do indicate that the 42T chainring should just clear the chainstay into the recessed portion of the chainstay.
Likes For pinholecam:
Sunshine
Quoted: 11076 Post(s)
Liked 7,650 Times
Just read thru the thread again to see if it was ever mentioned...why a folding mtb/gravel frame?
Do you commute on a train/bus and the folding bike meets some restriction? Do you live in a 200sqft apt and need the few feet of space?
This is such a departure from the typical that it has to be asked...again.
Non omnino gravis
Quoted: 233 Post(s)
Liked 151 Times
I live in Singapore.
Yes, apartments are not too big here relative to what folks in the US or larger countries are used to.
So a smaller footprint for storage is always welcome.
The other thing is that this is a very small country, so any 'bigger' ride/tour will have to be overseas.
So the fold is mainly for less questions/problems for coach/train/plane rides.
Quoted: 233 Post(s)
Liked 151 Times
Unfortunately, I ran into issues with a SRAM Rival crankset.
The spindle length is too short and hence the chainring hits the chainstay.
I had to purchase a Shimano XT crank (96bcd) with a 3rd party 38T.
Most cheaper 3rd party chainrings of 96bcd asymmetric fitting seem not to have a 42T, though 44T is common. (always says out of stock)
I have a 44T coming, and will see if it fits.
1st choice is the 42T though since I think its the better balance of fast/climbing gears for my needs.
Non omnino gravis
I realize it's late in the game now, but with a BSA30 bottom bracket, you're opened up to most any 30mm spindle crank, so it would increase your options quite a bit. I just switched to BSA30 to run a Rotor 3D30 crank on my Ritchey frame. The road cranks will fit into BBs up to 86mm wide, and the MTB cranks up to 92mm wide. So you could have ~10mm of spacers on the drive side.
Quoted: 233 Post(s)
Liked 151 Times
I got really confused with all the options out there when looking for the groupset.
Different BCD dimensions, direct mount, compatibility...
Quoted: 428 Post(s)
Liked 340 Times
I read all your posts about folders which are very insightful and awesome so thank you for that. I do have a Brompton but it's not really suitable for group rides. Current I'm looking for a full-sized folder bike and your gravel Change bike really caught my attention.
I apologize if this is a really dumb question is there a 2x crankset that would fit the frame?
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 276 Post(s)
Liked 247 Times
Hi pinholecam,
https://www.changebike.co.uk/collections/all
Not lost wanderer.
Quoted: 901 Post(s)
Liked 1,036 Times
I have this Doppelganger 853 and it works well for my needs
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
Likes For bwilli88:
Quoted: 233 Post(s)
Liked 151 Times
Hi pinholecam,
AFAIK, there is no issue with using a double.
The only issue is actually running 1x with a chainring larger than 40t-42t (I had to shim my BB towards the drive side to get clearance when using a 44t)
Change Bike actually sells a bike with a 2x and 3x (mtb chainring sizes though)
Do note that the bike does not have a FD hanger, so you will need a clamp on FD.
Its great to see that the posts have been usedful to you (thats the whole purpose of the forums )
Thank you for this! Will take this into consideration when I decide to pull the trigger and start the build.
Quoted: 428 Post(s)
Liked 340 Times
Another option is the Ritchey Breakaway frame. It looks like the buke above is an imitation of the Ritchey solution.
