New Trek Emonda SLR frame
Bikes: Trek Emonda slr
Liked 5 Times
hi to all of you
i purchased a new trek emonda slr frame and at the box, it was missing the carbon front derailleur washer (part number w531901)
from bike24.de they told me that this is not included and you have to buy it separately. to be honest, i do not believe them because without this i won't be able to build my bike.
thanks
thanks
Expired Member
Quoted: 3800 Post(s)
Liked 5,800 Times
Thanks for posting. If someone else on BF orders one of those frames they will know to order the washer at the same time! Hope it doesn't take too long. And welcome to BF!
Liked 5 Times
i ordered it already but it is not honest not to include this part.
they should inform me at least, as they say, that I need to buy the seat mast as an extra.
the strange is that they include the bolt for the washer but not the washer.
we will see, maybe i will contact with trek
Likes For Alex1098:
Hey there, Mitch from Trek here. Part number W531901 wouldn't come with the frameset. Not all front derailleurs would need this which is why it is not sold with the frame. We ship our frames pretty bare to let the customer choose how they want to build it. I confirmed this with the parts list for the frameset just to be sure.
Likes For eastsideride:
Expired Member
Liked 5,800 Times
Thanks for clarifying! OP should rest better knowing nobody took advantage of him.
Likes For shelbyfv:
Likes For flyjimmy:
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 942 Times
Build it 1X, problem solved!
Clark W. Griswold
Quoted: 4509 Post(s)
Liked 4,197 Times
You should have bought the frame through your local dealer. A lot of that third party stuff gets you bupkis. If you buy it from your dealer you get full warranties and support. Then again me personally I wouldn't buy a Trek. The 520 was a decent machine until they decided to get rid of the steel fork and replace it with aluminum. If they had done carbon, I could see ok following trend. Carbon is not great for traditional double rack touring but a carbon fork with mounts is easily sold and a steel fork is not hard to get but an aluminum fork seems fairly low value.
Anyways, we got a little off topic...
Clark W. Griswold
Liked 4,197 Times
The 520 is still a decent machine. The reason for the change to the aluminum fork was due to the integrated headset bearings which gives longer life to your headset and is simpler to work with. When making the change to the headset, we had to modify the fork crown. In steel, it was simply too heavy for the weight we wanted to maintain, so we went to aluminum instead since it keeps the weight down but allows us to make it just as strong for mounting weight to the front of the bike. If it was heavier, others might complain about that. But the frame will remain steel and the bike shares the same history as the early 520.
I got to wonder if Trek was really doing a lot of headset warranties because I haven't ever had to do one and that is my job is warranties.
However yes we did get off topic.
Liked 5 Times
trek confirmed that this part should be included
so now they will send to me the missing part.
