Headset for a Peugeot CFX-10
I need a headset and i am confused by all the options.All i know is the headset has to be 1 inch threaded with a 27mm crown race,but i am unsure of the stack height and do not want to purchase another headset i cannot use. If you'd be kind enough to link me to headsets that'd work,it would be greatly appreciated,
You might have a French threaded headset, taken from Sheldon Brown
The threaded parts of a French headset are non-standard, but the press-in parts are conventional. If you have a worn-out headset, it is most likely the lower races that are damaged. If you have trouble finding a French headset, you can replace the bottom races with ones from a standard headset, and keep the old parts on top.French headsets use a different type of keyed washer than others. Instead of having a groove machined in the threads, the rear part of the threads is filed flat. French headsets commonly used a serrated keyed washer, with matching serrations on the threaded bearing race. This makes French headsets slightly harder to adjust, but once they are adjusted, they hold their adjustment better than conventional designs.
I can't remember when Peugeot changed from French to English, I'm sure someone will be along with more info
Bikes: VeloBuild VB-R-022 // '89 Specialized Allez Full Dura-Ace 7400 // Santa Cruz Stigmata CC // Bridgestone MB-3 BoxTwo 1x Conversion // Bridgestone MB-6 // Santa Cruz Highball C // Ibis Spanky
Quoted: 68 Post(s)
Liked 20 Times
In addition to the above post - I believe Peugeot switched over from French to English thread at some point in the late 70s, so depending on the model of your bike, you may be ok with just a standard English thread one.
Likes For speedyspaghetti:
Quoted: 4231 Post(s)
Liked 3,940 Times
Also there's more to the proper replacement headset then the threading standard, or the frame/fork fits. It's the stack height. A lot of lower cost steel headsets have a fairly minimal stack height. To find stack height measure the "thickness" of the lower and the upper units or the overall fork steerer length minus the head tube length. 33-42mm is the typical range for a threaded unit.
So the needed dimensions are the fit to the fork crown and head tube, the threading and the stack height.
I was going to mention that Peugeot had changed from French dimensionally specd bikes to Eng/Jap in the late 1970s but started with the upper end bikes first. The CFX-10 is not a base grade model so I figured that it was Eng threaded.
I will add that headsets are one component that many don't fully understand all the compatibility aspects, or don't take the time to find these out before buying. This is one area where the LBS can often save time and mistakes. Andy
AndrewRStewart
AndrewRStewart
Bikes: 1973 Mercier 300, 1974 Peugeot PX10L, 1975 Lejeune Champion du Monde, 1982 Peugeot PX 10 Super Competition, 1984 Motobecane SP, 1987 Peugeot PX10 "Tout Mavic," 1983 Basso Gap
Quoted: 19 Post(s)
Liked 9 Times
This response is a bit late (!) but I can say that even the Peugeot bikes exported to the U.S. as late as 1982 still had French-threaded headsets. I know, as I have a 1982 PX-10 Super Competition sold here in California, and this is what it has. This is the same frame as the CFX10. The steerer also has the usual flat machined on the back, for the lock washer, as standard on French forks for many years. As a point of interest, the steerers on these models were honed to accept standard 22.2mm stems, and assembled bikes had English-threaded rear hubs.
Be aware that the standard headset on the assembled PX-10 was a Lightrace, with less stack height than typical competition headsets like the Stronglight or Canpagnolo SR. It is likely that the CFX frame was delivered with a slightly longer steerer to accommodate a variety of headsets, but someone else will have to confirm this.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1300 Post(s)
Liked 742 Times
for future reference.. French Versus English Threaded Headsets, and others too...
Scroll down to the dimensions chart, get out your calipers, and start finding the facts before buying.
https://sheldonbrown.com/cribsheet-headsets.html
Tag words: Peugeot French Headset
Quoted: 19 Post(s)
Liked 9 Times
The crib sheet will also reveal that French headset crown races might have either a 26.5 or 27.0 mm I.D. What it doesn't give is the year a given manufacturer changed their steerer threading. But it's pretty safe to assume that any French bike from the mid-1980s or earlier had a French threaded steerer and headset.
