How easy is it to overhaul Campy Ergo shifters?
Veteran, Pacifist
Quoted: 3940 Post(s)
Liked 4,939 Times
So my Campy 9 speed shifters still work ..... but the shifts have lost their mechanical feel. I can sense that a rebuild is in order in the near future.
Should I undertake this rebuild myself?
Are parts available?
How 'bout parts to convert right shifter to 10speed?
This is not a job for my closest bike shops - who is doing this repair at an affordable price?
Is there a BF'er offering this repair?
Thanks in advance.
Here is the bike wearing the 9 speed triple.
Thanks in advance.
Likes For Wildwood:
Bikes: a few..
Quoted: 82 Post(s)
Liked 152 Times
Thanks in advance.
Thanks in advance.
Veteran, Pacifist
Liked 4,939 Times
Advocatus Diaboli
Quoted: 4803 Post(s)
Liked 1,547 Times
Maybe the Bicycle Mechanics forum would have some insights?
Bikes: Yes
Quoted: 3288 Post(s)
Liked 4,056 Times
Do you have any experience as a watchmaker?
It's not quite that bad, but getting the last spring in the correct place can require a lot of patience. I did it once. That was enough for me.
If you're not hung up on the whole sustainability thing, a much easier solution for not much more money is to replace the entire shift assembly. You can get a 10-speed Record-level shift assembly for about $100. Then you just swap over your hood, clamp, and brake blade. I'm pretty sure you could handle it yourself, but if you don't want to I know a guy in Beaverton (me) who would do it for you the next time you're in the area. I hear @gugie is thinking about having another Ride, Wrench, and Grill this summer.
My Bikes
My Bikes
Veteran, Pacifist
Liked 4,939 Times
@AndyK -
Changing tubulars and clinchers = no prob.
I can adjust brakes (almost all) and friction shifters (usually) with skill.
Fenders can be tough, given a fender line and aesthetic requirement.
Hubs and BB and pedals are important enough to get done well.
Sounds like watchmaker is not in my skilz sets.
Shifters are important enough to be done well.
Body swap sounds good. Certainly more predictable in results.
I should check sourcing options.
Likes For Wildwood:
Bikes: a few..
Quoted: 82 Post(s)
Liked 152 Times
Likes For mtbikerjohn:
Bikes: '8? Ciocc Mockba 80, '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 228 Post(s)
Liked 313 Times
I've done a few ergo overhauls now. I prepped for the first one by watching a few of the You Tube videos that cover this subject. If you choose to take this on I'd recommend you proceed slowly and lay out the parts in the sequence you remove them. Be careful to not miss anything....some of the thin spacers (washers?) are easy to overlook when they are "stuck" to adjacent parts with grease. I documented several details, particularly the springs, with pictures so I had a reference for the reassembly. Installing the springs is the most challenging task, but relatively easy after you've done it once.
I overhauled an 8-Speed Ergo yesterday afternoon in preparation for moving it to another bike. I gave all the bits a thorough cleaning and fresh grease. I installed new g-springs while I had it apart.
Dean
Dean
Roll Me Up and Smoke Me When I Die
Likes For Dean51:
Veteran, Pacifist
Liked 4,939 Times
I overhauled an 8-Speed Ergo yesterday afternoon in preparation for moving it to another bike. I gave all the bits a thorough cleaning and fresh grease. I installed new g-springs while I had it apart.Dean
Did you buy parts from Branford? or where?
Veteran, Pacifist
Liked 4,939 Times
Thanks to all - excellent help.
Bikes: Yes
Liked 4,056 Times
My Bikes
My Bikes
Quoted: 228 Post(s)
Liked 313 Times
Parts came from one of the UK suppliers....I believe it was Wiggle, but it has been a while now. I purchased some extra carriers and g-springs when I realized parts for the early....8 speed in my case.....models were getting hard to find. I was not aware of Branford at the time. Given their proximity to your location....and mine (Port Angeles)....I'd sure check with them.
FWIW, one of my attractions to the Ergo levers is they are relatively easy to overhaul/repair. My experience doing the same with Shimano "Brifters" is not so good.
Dean
Dean
Quoted: 1533 Post(s)
Liked 725 Times
I've found you can give the G-springs a tweak to restore some life to them.
Likes For Kimmo:
Quoted: 1630 Post(s)
Liked 2,253 Times
I have done second gen Ergos in 10 speed, twice. Branford was a great help with advice and parts. I don't know of anyone else that has as complete service/parts.
It really isn't than bad. I would not work on a time piece but the levers were not really a problem. I do have an 8V set with the pointy hoods that will take the same g spring as the second gen Ergo but I think they swap left and right sides. Info on Branford site.
The key is the proper indexing of the parts in assembly. Don't force anything. The other significant challenge is the installation of the spring. Again it is about positioning the parts in the right orientation while assembly.
The difference between many of the Ergo''s are the markings on the blade. Chorus and Record are the same with that exception. The differences between the different versions are documented on Branfords site.
I say go for it!
I say go for it!
Quoted: 2643 Post(s)
Liked 1,992 Times
Quoted: 942 Post(s)
Liked 527 Times
Check the official Campagnolo YouTube Channel. If I remember correctly they had a video doing repairs and such. Not sure if exactly what you are doing is there or not but worth a look.
Quoted: 4275 Post(s)
Liked 2,997 Times
How hard is it to remove/transfer the shifter blades if you do the whole assembly? I have a powershift set of ergos that I'd like to convert to ultrashift.
Liked 2,253 Times
Quoted: 212 Post(s)
Liked 202 Times
I recently became the owner of 8 speed Campy Ergo power shifters.
I did not see this forum had a separate category for these shifters so I posted in the mechanic section.
For me, my LEFT shifter would not return to the small chainring. After researching, was informed it probably was...are you ready...the return spring
I sent it out to Pat at Bradford on Friday. I will keep all posted on the results.
If I had come to this section first..........I would have taken up Andy Ks offer and sent it to him and paid him
Liked 2,253 Times
I just converted my 10V 2nd gen right Ergo to 9v by buying a right Ergo that was broken with all the parts attached. The key is in the video above. I found the down shift toothed ring has a front and back, It needs to be oriented correctly. In addition, the sequence of moving the up shift is key to not having to fight the spring upon installation. The last key is the positioning of the part the spring is locked into. I mounted the Allen key used on front in a vice for mounting the assembly. Made the installation much easier.
P1050430 on Flickr
P1050433 on Flickr
Left overs. Note the downshift lever ring is in backwards. If one of your bearings falls out, there is a thick washer that goes between them. You should be able to assemble and tighten the screw and still shift fine.
P1050434 on Flickr
P1050430 on Flickr
P1050433 on Flickr
P1050434 on Flickr
Quoted: 212 Post(s)
Liked 202 Times
UPDATE
I received my " Brifter" back from Pat at Branford Bike in about 8 days.!!!!
Works perfect!!!
VERY REASONABLE in the repair price !!!!
Thank YOU Pat at Branford Bike.
I would HIGHLY recommend !!
Works perfect!!!
