Cut and rethread spokes ?
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times
I am going to build a wheel with hub and rim I have on hand. I have some spokes to use but they are too long. I need to cut them shorter and cut new threads. Is this difficult to do ? Would I be better off to just buy new spokes ?
Clark W. Griswold
Quoted: 4461 Post(s)
Liked 4,130 Times
Do you have a spoke cutting and threading machine? I would probably buy the correct length personally.
Quoted: 1000 Post(s)
Liked 1,679 Times
This is so true, but it would appear that finding good spokes right now is kinda hard as opposed to just a few months ago. I would only go to the trouble of cutting and threading if I could not find the proper spoke lengths...
Edit: That's right. The last time I resized some spokes I did not re-thread. I just cut the length and used an old spoke nipple to dress up the end.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1251 Post(s)
Liked 338 Times
It just depends if there's a close place that does them. Also depends if they are used and what's available now. Postal has been going postal lately. LOL
I've done it several times. One set I redid was right at the top of the previous threads. That was a goof measurement.
These were also hard to get 2.3 heads.
I've bought uncut ones also. I also goofed the order and got black instead of silver. Tried to sand one off, took too long and it looked lousy anyway. LOL Still have those 49 + 1.
Really Old Senior Member
Spoke threads are rolled, not cut.
Take your micrometer and measure across the threads and again on the unthreaded section.
Threaded part is a greater dia.
Quoted: 1439 Post(s)
Liked 1,094 Times
Quoted: 581 Post(s)
Liked 921 Times
The effort and time to cut a spoke is not insignificant. I needed a replacement spoke a few months ago for a project and the shop didn't have the exact length so cut one for me. I forget what they charged me, ( $5? $10?) but it was quite a bit more than a single manufactured spoke out of a box, but considering the time it took them I didn't think it was unreasonable at all.
Each spoke is going to take some time to measure accurately and cut and crank through the threader, so the extra cost for 32 or 36 of them might be a lot. I am 100% certain you could find a box of DT Champion spokes in the right length for a lot less than 32 custom cut ones.
Bikes: Homebuilt steel
Quoted: 2205 Post(s)
Liked 428 Times
Most better bike shops will have the tools to rethread your spokes. I found a shop near me that did what you are asking and they charged me less than the cost of new spokes and did them the same day. I think the mechanic enjoyed it. More recently I was looking to buy the tools to do it myself but it's kind of expensive for a hobbyist to justify.
BTW, bikehubstore.com sells lots of spokes and the owner is a great guy that goes out of his way to please. Highly recommended.
Likes For IPassGas:
working on my sandal tan
Quoted: 3873 Post(s)
Liked 2,574 Times
How much too long are they? Is doing an extra cross a possibility?
Quoted: 2629 Post(s)
Liked 1,980 Times
I know there are places with these tools out there, but to my knowledge none of them are local to me. YMMV.
Likes For pdlamb:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
The Morizumi is a great machine, very easy to use. We had one years ago and ended up stocking spokes in 10mm increments then cutting to what we needed. Greatly reduced the number of spokes we stocked. It really isn't very time consuming.
Likes For cxwrench:
Quoted: 327 Post(s)
Liked 250 Times
is too expensive for something I would seldom use. Thanks for the idea.
And thanks to all that responded. The BF is great. A storehouse of knowledge
Liked 2,574 Times
Another thought: if you're using a double-walled rim and the spokes are just a tiny bit too long, nipple washers could "eat" about 1/2mm of spoke length. Nipple washers are still pretty easy to come by, too.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Another $0.02:
Cutting and rolling new threads is feasible for PG or single butted spokes. You might not have enough of the lower section on DB and TB spokes to roll, depending on how much you need to cut. I'm fine with spokes up to 2mm too long or short (per a calculator) on double walled rims.
Old fart
Quoted: 3617 Post(s)
Liked 3,449 Times
As @Bill Kapaun notes, spoke threads are rolled, not cut. Some bike shops have spoke threading equipment. Phil Wood's is nice, as it rolls the threads and cuts to length in a single operation. But it's expensive (couple thousand dollars, last time I checked). Cyclo and Hozan have more affordable ones (couple hundred dollars), but in my experience, they don't do as nice a job, and you need to cut the spokes to the desired length separately.
Quoted: 995 Post(s)
Liked 589 Times
Yes, if you try to cut the threads they will end up undersized. https://www.portlandbolt.com/technic...threads-bolts/
That is why they're rolled in the first place.
Clark W. Griswold
Liked 4,130 Times
Yep. Wheel Fanatyk is out of stock (Hozan Spoke Threading Tool - Wheel Fanatyk), and it cost about 100 fancy spokes. I don't know if anybody has one of the really fancy Morizumi machines for sale, maybe I'll get one after I get me a $500 bike pump.
Sr Member on Sr bikes
You could go the other way and cut the spoke heads off and use Z-bend pliers to creat your desired spoke length.
See this link —> https://jimlangley.net/wrench/espoketool.html
I actually created a replacement spoke this way for one of my bikes about a year or so ago. I didn’t have the z-bend pliers…just did it in the bench vise…but it works. It’s still on the bike working just fine. I’ve seen pics of wheels built entirely with Z-bent spoke. It looks OK, uniform, and works well. And, at $20.00 the pliers are a lot cheaper than a spoke threading tool.
https://www.amazon.com/Hangar-9-HAN1.../dp/B0006OBMJI
Dan
Dan
Likes For _ForceD_:
Senior member
Quoted: 946 Post(s)
Liked 664 Times
Ask around at local shops to see who has a Phil Wood or Morizumi spoke machine. My Morizumi is capable of shortening and rethreading spokes by as little as 2mm and down to whatever length the butting will allow.
Call around, if a shop has a Phil Wood or Morizumi machine an experienced mechanic can cut/roll spokes for a wheelset in 15 minutes. I wouldnt mind the job as a mechanic, a chance to use one of the nicet, more elegant tools in the shop.
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
As above, if you can find a local shop with a Phil Wood or similar spoke threader, it's really easy. Assuming it's already set up for the correct gauge spoke (it often is), then setup is 30 seconds and maybe 10 seconds/spoke.
On the other hand, if they have one of those cheap tiny 3 roller ones then it's a PITA. I've had shops, even on an empty day, go with the "We don't use it often, can't find it" excuse just to avoid using them (wasn't a great shop).
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
If you're ever down here in the South Bay, you can have them cut and re-rolled by Bicycle Express and Wheels By Fleming.
If you had posted earlier, I could have done it for you when I had my machine with me up in Loch Lomond back in May.
=8-|
=8-|
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
