Cleat too Narrow in Road Shoe?
Hi everyone. I've recently switched to my first road shoes (budget friendly, Spanish brand Spiuk Rodda, with SPD cleats). Unfortunately, my right foot is been hurting me on the outside. Seems like I'm putting my weight there, instead of the center. I did bike fitting few days ago and everything else is now working except for this issue.
I've discovered that I have very large hips and changed my saddle to the 168mm Specialized model (wow what a comfort!). Could it be that I need my feet to be in as wide position as my hips? Is it even possible to do that? Cleats are at maximum but I still feel discomfort and pain after an hour of ride or so. Would a wider shoe do the work? Any similar experience or advice? Much appreciated, thanks!
Quoted: 6348 Post(s)
Liked 4,948 Times
Are these Shimano SPD cleats? If so, move the cleat to one side so it's away from the side that is bothering you. If you bought these from a shop, they'll usually help you get them adjusted right over several attempts. At least until they get tired of seeing you! <grin>
Possibly moving the cleat forward or aft might help. The alignment should have your toes pretty much pointed straight ahead. But I've had to adjust one foot to be slightly heel in and it just barely misses the crank arm.
Not sure what you mean by "cleats are at maximum".
Welcome to BF!
Welcome to BF!
Welcome to BF!
Welcome to BF!
Liked 4,948 Times
Might just be the shoes. Or it still might be the cleat adjustment. While usually pushing the cleat away from the pain works to a certain extent. You might still need to change the location to give your foot a different place over the pedal so the part of your foot that you want to push with has something to push against.
If you can't find any relief from moving the cleat, then maybe some sort of inserts to replace the inner sole of your shoe might help.
Maybe someone else that has had some big issues with this and solved the problem might yet respond to your question. But again, if you bought these at a local bike shop then go back to them. They've probably heard the same from others and might know better what to do.
Might also be that you just need to train your foot to push more with the side of your foot that your big toe is on.
I think I had the same issue. I solved it by going with wide pinned, flat pedals - DMR V12s and Five Ten shoes. The width and the pins keep my foot planted where I put it, and the amount of surface area reduces the pressure my foot places on the pedal (lbs/square inch).
Thanks everyone! I just both another pair of shoes, which offer wide(r) model and they are made of very soft material, so I hope this will solve my issue. It was a journey to find it, but fingers crossed! I really appreciate all the answers.
Btw the brend is Lake, if anyone else needs it. There are some European sites with lower prices, so if you're in EU, give it a try.
Likes For Bald Paul:
Quoted: 4877 Post(s)
Liked 4,042 Times
Give those a try but I was thinking the opposite. That perhaps what you are feeling is the shoe deforming around the cleat and not supporting your foot. I wonder if a stiffer sole would separated the force from the cleat and transfer it to your whole foot, not just right at the cleat.
OM boy
Bikes: a bunch
Quoted: 551 Post(s)
Liked 710 Times
usually if the shoe is deforming due to soft soles, the hotspot would be somewhere under the cleat fastening.
Besides cleat rotation (which usually doesn;t factor into foot hotposts as much as knee and msucle issues), the really key areas to look at is your 'stance', affected by knee/lower leg angle and ankle pronation/supination... some techy stuff, like canting.
but to make it a bit simpler to address. Q factor - you'll want to look this up.
wider hips, with a too narrow Q, often means too much pressure on the outside of the foot, and can create ankle issues
This is not 'catch-all' - too many factors - but a good starting point.
Since your have 'road' shoes, you're likely on a 'road bike', which for some has a quite narrow Q as std... Try riding any mtb bike (even in normal sport shoes). If that feels 'better' , then you might be well served with some pedal extenders, as noted by Bald Paul.
There are a number of various pedal extenders on the market, in various extension lengths.
They're not all $50/pr, many are quite economical and allow 'experimentation' (check Amazon and internet) for variety
highly recommend for those with Q factor issues...
Ride On
Yuri
Ride On
Yuri
