USB Charging
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,331 Times
USB Charging
I know USB is the standard for most rechargeable devices, but I'm afraid I won't be able to see to plug in those little connectors before I'm too old to ride.
If there was one physical thing I could get back, it would be a toss up between my eyesight and hearing.
Quoted: 842 Post(s)
Liked 1,696 Times
Thankfully, USB-C seems to be the new standard. I can't tell you how many times I tried to jam one of those mini and micro connectors in upside down. On the units I have that use them, I paint a white dot on one side of the connector, and one on the unit. Line up the dots and connect.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,331 Times
The white dot idea is a good one. I may do that.
Likes For Chuck M:
Quoted: 6331 Post(s)
Liked 4,927 Times
Red dots make it charge faster! <grin>
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4368 Post(s)
Liked 3,031 Times
When I reached my 40's I need to wear eyeglasses for many tasks and still do. For bike rides I wear safety glasses that are bifocals and provide me with a 2.0 diopter magnification and they cost less than $20 and are availalble in clear, gray, and yellow tint.
USB-C is a welcome change having dealt with the USB B micro and mini and type A connectors for years. I now keep the appropriate cable stored with the device to save on hunting for a special cable.
Something to watch out for with USB-C devices is that the power draw depends on the wall charger that is used. Many need 10x the Watts output of the old chargers that fed a cell phone. With my power banks only a 20-Watt rated wall charger is effective.
Likes For Calsun:
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 599 Times
If you can't see to use a USB, can you see to ride?
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Quoted: 4311 Post(s)
Liked 1,387 Times
Yes.
"Can't see" might be a bit of an exaggeration.
The orientation of the small micro USB is hard to see. It's not unusual for people to have trouble with it. It's harder than it should be for the simple task of plugging something in.
It's common for people to have trouble plugging in the larger USB A type.
https://upjoke.com/usb-jokes
Likes For njkayaker:
ignominious poltroon
Quoted: 2283 Post(s)
Liked 3,506 Times
I'm seeing double.
Liked 3,506 Times
The remarkable thing about non-USB-C type USB connectors is that you have a 50/50 chance of getting it right the first time, but the odds are stacked > 99% against you. Even more remarkably, I've often gotten it wrong twice in a row.
Likes For Polaris OBark:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,331 Times
Yes. Quite well. Most everything I need to see on a ride is at a greater distance than arm's length.
This is how I expect my grandson should get his shoes on the correct feet. But somehow he has a higher percentage of getting it wrong than right.
Quoted: 1514 Post(s)
Liked 735 Times
That would be the definition of tough luck - to plug it wrong on the first try, then immediately try again and get it wrong again!
feros ferio
Quoted: 1403 Post(s)
Liked 1,351 Times
The one big benefit of being -7 diopters myopic is that I simply remove my glasses whenever I need magnification of a small object.
My wife sometimes has to ask me to read fine print, even though her eyes are otherwise "better" than mine.
Quoted: 645 Post(s)
Liked 1,565 Times
Europe is requiring all devices use USB-C soon so I think you'll see everyone incorporate that soon to avoid different products for different areas. I think it is headed that way anyway but this will help it along. It is so much better and especially so much easier to insert into the receptacle.
Quoted: 4864 Post(s)
Liked 4,012 Times
Likes For 79pmooney:
Liked 4,012 Times
+1 I have 4 levels of focus. Distance. Office. Reading. No glasses. I hate trifocals so I have distance/reading and office/reading.
Sr Member on Sr bikes
I just wish the electronics industry would have chosen one USB format and forced everyone (device makers, including Apple/iPhone) to use it. Instead
it seems like every new device comes with a different cable format.
Dan
Dan
climber has-been
Quoted: 3551 Post(s)
Liked 3,714 Times
Quoted: 842 Post(s)
Liked 1,696 Times
Precisely why USB-C is becoming the new standard. Or, rather, the standard, since there didn't seem to be one previously. Even if they were embossed 'correctly', the unit they were plugging in to wasn't necessarily marked. The dots work.
Would have been a godsend when I used to work the trading floors on Wall St. Though sometimes you did not have the opportunity to see what, or where you were working so it was all done by feel. Think rats nest under a desk with upwards to a half dozen PC's each with at minimum 2 monitors, or a server rack in an IDF closet at the end of the hall that has a waterfall of multicolored wiring. Not just talking USB but RS-232, Ethernet, fiber, video, etc. Got good enough that I could tell what connector I had in my hand without even looking at it.
In Real Life
Bikes: Lots
Liked 599 Times
Rowan
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
