first drop bar tape attempt... how long to live with my ineptitude?!?
Old 07-03-22, 08:44 PM
mschwett
Liked 1,506 Times in 762 Posts
after viewing a half dozen videos with conflicting "best methods" for doing this, i decided on the top down approach (not too worried about pressure on the bar tops unraveling anything, i'm on the hoods 95% of the time and the drops the rest) because i didn't like the electrical/finishing tape the bike came with. tape was ripping on one side from a minor spill.
ended up with some lumps... some asymmetry (shouldn't have tried to make the second one "better"), one or two little leading edges that aren't sitting flat, and i'm not 100% sure the last bit of tape is going to stay tucked in at the plugs.
live with it until it wears out... or eat the $40 for a second try!?!?
mschwett is offline
Likes For mschwett:
Old 07-03-22, 08:54 PM
sweeks
sweeks's Avatar
Liked 630 Times in 434 Posts
I doubt anyone will notice. Give yourself a break, and ride the bike until you feel like having a re-do.
I recently did my second wrap job on a set of "trekking" bars, and while I think I did an all-right job, I somehow managed to wrap the second side so the "Easton" name doesn't appear on the tape.
I'll live with this...
Both sides started and wrapped the same way, but the brand imprint is covered on the right side. :-(
sweeks is offline
Likes For sweeks:
Old 07-03-22, 08:56 PM
Litespud
Liked 797 Times in 446 Posts
why on earth are you spending $40 on bar tape? Tape is a wear item - buy a $10 roll, replace it every few months, you’ll be an expert after a few rolls
Litespud is offline
Old 07-03-22, 09:14 PM
mschwett
looks clean other than that! i guess the logo side has to be the “over” edge!
mschwett is offline
Likes For mschwett:
Old 07-03-22, 09:16 PM
mschwett
i liked the way it looks, they had it at the shop? the same tape lasted 5000+ miles on my last bike, so it’s not really a high $/mile kind of thing even at $40. does the $10 kind only last a few months?
mschwett is offline
Likes For mschwett:
Old 07-03-22, 09:17 PM
sweeks
sweeks's Avatar
At least I'll be able to tell which side is which!
sweeks is offline
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Liked 2,600 Times in 1,593 Posts
Looks way better than my first couple attempts at wrapping bars. I'd say you could have applied a little more tension at the bends, but you'll get another chance before too long.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 07-03-22, 09:22 PM
sweeks
sweeks's Avatar
...does the $10 kind only last a few months?
Seems unlikely. The original tape on my bike was 20 years old and still looking good. I only changed the tape because I went from drop bars to trekking bars.
sweeks is offline
Old 07-03-22, 09:34 PM
Polaris OBark
ignominious poltroon
Polaris OBark's Avatar
Liked 3,978 Times in 2,083 Posts
That would drive me nuts. If it isn't something that would get damaged by taking it off, take it off, and switch the two ends so that the label is exposed, and re-wrap.
Always remember this: there should be a hyphen in anal-retentive.
Polaris OBark is offline
Likes For Polaris OBark:
Old 07-03-22, 09:49 PM
BillRS22
Bikes: Waterford RS22 (2004), PEUGEOT PKN10 (1981), Raleigh Gran Sport (1976), Mercian 1974
Liked 65 Times in 25 Posts
Wrapping Bars
Wrapping bars is one of my least favorite chores. Your wrap is OK but looks a little loose on the drops. When you do rewrap the bar, use the old tape and practice on another bar if you have one before you do the rewrap. I just
wrapped bars on a vintage bike, and the left side looked great, but the right side a little rough at the finish. But I
just don’t wrap enough bars to get good at it. Bill
BillRS22 is offline
Likes For BillRS22:
Old 07-03-22, 09:58 PM
Russ Roth
Liked 1,057 Times in 743 Posts
Personally I think the direction you went is the worst when it comes to the edges rolling which will result in it looking worn faster. Since I'm cheap, I'd leave it and use it as an experiment to see how long it holds up wrapped like this. If it lasts the season, replace in the spring. Other then the direction you wrapped, it isn't a bad job, I've seen plenty of techs do worse with more experience, and even the really good ones don't get it perfect, just close enough people don't usually notice.
Russ Roth is offline
Likes For Russ Roth:
Old 07-03-22, 10:09 PM
sweeks
sweeks's Avatar
Luckily, I don't actually look at my bars to tell right from left!
I'd say I'm more OCD than A-R.
I don't think I'll take the tape off, since there's adhesive involved. Next time I'll know better... 20 years from now!
sweeks is offline
Likes For sweeks:
Old 07-03-22, 10:31 PM
icemilkcoffee
icemilkcoffee's Avatar
Liked 2,179 Times in 1,182 Posts
That Supacaz tape is probably not the best choice. It’s not stretchy enough.
Next time go with a silicone bar tape. It’s stretchy and it doesn’t have any adhesive backing so you can re-wrap it as many times as you want.
icemilkcoffee is offline
Old 07-03-22, 10:36 PM
mschwett
Yeah, it’ll be interesting to see if it holds up. Seems like mixed opinions out there on the matter, I can see why the other way would be better for edge security but I really disliked the ring of electrical tape at the top!
mschwett is offline
Likes For mschwett:
Old 07-03-22, 10:40 PM
mschwett
yeah. Something which conforms a little more would be better!
mschwett is offline
Old 07-03-22, 10:48 PM
Crankycrank
Liked 1,215 Times in 838 Posts
Practice makes perfect. Use a hair dryer on low heat to soften up the adhesive, remove tape and try again. Also helps to make the tape more pliable when wrapping.
Crankycrank is offline
Old 07-03-22, 11:18 PM
Rolla
Guest
Liked 3,274 Times in 1,440 Posts
Wrapping bars is absolutely one of my most favorite aspects of bike maintenance! I think yours looks pretty good, tbh. But when you're ready to tackle it again, I would highly recommend starting from the ends of the bars and using something awesome like $30 Zipp Service Course tape. It's super stretchy, has a great feel, stays grippy when wet, and lasts a long time. The "figure 8" at the brake hoods and the diagonal cut at the end are the critical moves. Electrical tape is more forgiving than the finishing tape provided, but try to only do one or two wraps of it.
Until you become adept, it might take you 45 minutes to do the whole bar, so crack open a cold one, put some good tunes on the speakers, and enjoy the process!
Rolla is offline
Likes For Rolla:
Old 07-04-22, 12:43 AM
urbanknight
Over the hill
urbanknight's Avatar
Liked 1,265 Times in 718 Posts
You kind of answered your own question as far as I'm concerned...
Let that decide. As soon as it comes untucked or otherwise out of place, redo it. FWIW I think it looks fine and would probably not question that tape job if I saw it in a pack.
It's like riding a bicycle
urbanknight is offline
Old 07-04-22, 04:15 AM
Chuck M
Happy With My Bikes
Chuck M's Avatar
Liked 2,753 Times in 1,280 Posts
I've seen worse than what is in the OP on bikes for sale that were touting the wrap as a positive.
If it was my bike, it may bother me or it may not. But finishing tape bothers me too.
Chuck M is offline
Likes For Chuck M:
Old 07-04-22, 05:08 AM
bboy314
bboy314's Avatar
Liked 1,538 Times in 743 Posts
For next time, if you want to try starting at the bottom (which I’d recommend), ESI makes some really nice silicone finishing tape that looks good and is easy to use. It comes it’s their bar wrap but is also sold by the roll.
bboy314 is offline
Likes For bboy314:
Old 07-04-22, 05:57 AM
veloz
Liked 64 Times in 48 Posts
If it bothers you, unwind that tape and reuse it. No biggie. It might not stretch as much in the second wrapping but it's important to pull it tight. Tape wound from the top down probably won't last too long.
veloz is offline
Likes For veloz:
Old 07-04-22, 06:42 AM
fishboat
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Liked 816 Times in 474 Posts
After watching a half dozen videos and you still wrapped it backwards. As soon as the edges start curling back..it'll look rough. I'd strip it off and re-wrap it..you actually can use the same tape.
fishboat is offline
Likes For fishboat:
Old 07-04-22, 07:51 AM
mschwett
half the videos illustrated doing it top down, and the other half illustrated bottom up.
i’ll see how it lasts.
mschwett is offline
Old 07-04-22, 09:03 AM
ClydeClydeson
Liked 923 Times in 519 Posts
As others have said, it looks good but will hold up better if you wrap bottom-to-top. Yes, black electrical tape looks crappy, but you can find colour-matched electrical tape at the dollar store, and the electrical tape AND the bar tape can be trimmed to make a clean looking blunt end.
Another option is to tie off at the top with twine. There is a trick to finishing a twine wrap so the loose end is hidden and this looks very stylie...https://www.rivbike.com/pages/handle...d-twine-finish
ClydeClydeson is offline
Old 07-04-22, 10:13 AM
smd4
Liked 3,313 Times in 1,992 Posts
Looks fine to me but I agree with other folks. I always start from the bottom. Ride until it needs replacing. And $40 isn’t too much except for the cheapskates among us (and they are legion on this site).
smd4 is offline
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Your Privacy Choices -
