Winter jacket advice
I know there have been a lot of threads about jackets for winter. I used a ski jacket that had airways last winter in front and in the back but I always got sweaty wearing a sweater under neath. Can someone give me tips as I was looking at fleeces but hard to tell if they are breathable as top layer even if the company claims it is. At worst I will be reading under -22 F for an hour or so (10-15 miles daily one way). Also no wool stuff combos, thank you.
Likes For Frenzen:
just another gosling
Quoted: 3918 Post(s)
Liked 1,982 Times
I'd think a winter down parka from REI or some such, with only a thinnish synthetic layer under. Down is amazingly breathable. One adjusts effort to prevent getting either sweaty or cold. Expensive though. You want a thin outer and inner of ripstop, and not sewn-through construction. Another approach is to wear a somewhat oversized cycling wind jacket (not waterproof or resistant!) for the top layer, a poly zip-tee next to the skin, like from Craft, then a layer of 100, 200, or 300 fleece depending on temperature and experience. There are also wind jackets made for hikers and climbers which have a hood. Again, nothing water repellent. You can tell if it's the right wind jacket by putting your mouth on it and seeing if you can suck air through the fabric, but only slowly. When I delivered papers on foot in Fairbanks, I made a point of not adding more or warmer clothes until I felt my skin cold under my clothes. That forced me to adapt and be OK with what I had available when it got down to -60. One does adapt to cold as well as to heat.
Results matter
Results matter
Likes For Carbonfiberboy:
Sr Member on Sr bikes
There will be argument, but IMO (and opinion of many others), you just can’t get “breathable” And “waterproof” in the same garment. Not in a garment worn for intense physical exercise anyway. If something is breathable…allowing moisture vapors to escape…the moisture can also get in. It would appear that the garment is “breathable” for a body that is doing very easy to moderate activity…i.e. walking…and not something strenuous like moderate to hard cycling. So what it comes down to is that one way or another you’re going to be wet…either sweating from moisture that can’t escape, or from precipitation leaking through. So…I choose the garment/material that will keep me warm (wind proof) when it’s wet. My personal choice for winter wear is, like you, a ski jacket. That is topped with a very thin outer Pearl iZumi polyester windbreaker. I can’t believe how affective those windbreakers are. They’re so thin and lite, but do an OUTSTANDING job at wind breaking. If the weather is dry but just cold…down to about 35°F all I need is a long sleeve shirt, and that windbreaker. But it does not really provide any water resistance.
Dan
Dan
Likes For _ForceD_:
Quoted: 5234 Post(s)
Liked 3,609 Times
I'm a big fan of layers
but -40F on a bike?
but -40F on a bike?
Quoted: 4875 Post(s)
Liked 4,041 Times
I'd go for a very breathable jacket that goes to around zero (probably with good thermal underwear underneath. When it get still colder, pull a nylon (or equiv) windbreaker over that you can take off mid-ride as you warm up.
For me, the secret is to be warm enough the first 5 miles or so, then be able to shed layers to keep sweat down. Failure to do the first can mean (again, for me) a ride where I never do warm up and cannot get to a good, heat generating speed and effort.
Good hats under the helmet are another approach that are easily taken off as one warms. (At -20F, perhaps the hat under for the whole ride and a windproof shell over the helmet for the first miles.)
Liked 1,982 Times
Dan
Dan
Results matter
Results matter
Quoted: 1006 Post(s)
Liked 1,688 Times
In Central Texas it does not get that cold. For winters I just use a "Breathable Nylon Wind Breaker" with a hood (Anorak type). I then pile on appropriate layers underneath for the temperature. Even then, temperature regulation was inadequate till I sewed in some arm pit zippers. Its not pretty but it gives me a comfortable temperature range to ride in 40's° to 60's° F.
I know... For some people that's T shirt weather... Ha
Liked 3,609 Times
Likes For rumrunn6:
Quoted: 3326 Post(s)
Liked 2,171 Times
200 weight fleece is usually very breathable. If I were commuting at minus 22, i would wear a very light polypro top, then a mid weight fleece pullover sweater, then a NF Denali jacket or somebodies equivalent. Plus a light wind jacket as needed on windy days. I would not wear down, it loses its insulating ability when wet. If I were continually moving, I think those payer would be enough. I might carry a down puffy jacket in case I needed to stop and fix something.
Liked 3,609 Times
Likes For rumrunn6:
Liked 3,609 Times
I do use full sleeved jackets in wet weather, but it can be tough to balance the weather protection w/ ventilation. but yes wind & spray need to be protected against
this Columbia shell has been working out the past few years & it has pit-zips for ventilation
it's not cycling specific but seems to fit OK on the bike. came across it by accident. forgot my wind layer one day & was far from home when I realized it, so had to find an outdoor store & was lucky to find something comfortable
I often use this thick North Face jacket that my late Dad bought for me, one birthday. it's got enormous pit-zips & even tho it's not a "shell" provides good protection from light rain, with the added bonus of thermal protection. a nice all-arounder
I wouldn't normally spend $150 on anything but sometimes someone or I do, & I make sure to get our money's worth out of it
I wear layers. Merino wool base layer. Insulating layer and then outer shell for wind and rain or snow.
You'll keep yourself warm as long as you are pedalling so you might find yourself unzipping to let the heat out. But if you are stopped for a long time, you'll start freezing.
I don't like fleece. Too much static. I like wool. Go to a thrift store and look for wool cardigans or sweaters.
Bikes: Specialized
Quoted: 147 Post(s)
Liked 54 Times
Liked 3,609 Times
Likes For rumrunn6:
Bikes: 2022 Priority Coast, 2022 Priority Current
Quoted: 175 Post(s)
Liked 137 Times
Merino Wool baselayer, wool sox, fleece vest, and outerlayer thin jacket not windbreaker, but a little thicker. I like pearl izumi!
Bikes: two blacks, a blue and a white.
Quoted: 446 Post(s)
Liked 849 Times
Gotten many years out of my Gorewear insulated shell. Provides windproofing, waterproofing, very breathable. Can do a thermal or base layer underneath when needed. Not cheap, but well made and durable. Would buy again.
I don't know.
Quoted: 334 Post(s)
Liked 894 Times
if a jacket is very waterproof, then I end up wet anyway from sweat. If I have to ride in the rain, I'm committed to getting wet and I'll try to make the best of it.
as for winter jackets, all of mine are wind blocker in the front, vented or breathable material in the back. Seems to work. I cycle down to about 25 degrees F and layer according to the temp and predicted physical output.
Bikes: Specialized
Quoted: 147 Post(s)
Liked 54 Times
"Currently we ship to Austria, Belgium, France, Germany, Ireland, Italy, Luxembourg, Portugal, Spain, The Netherlands, United Kingdom and the United States. Please use the country selector to choose the correct site for your country".
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1272 Post(s)
Liked 1,327 Times
Yikes!
^^^This
Also ^^^this
Interesting. I'm quite the opposite, and everyone I know who rides in sub-freezing temps also subscribes to this rule-of-thumb: the secret is to not be warm enough the first 5 miles or so; you want to be a little cold when just starting out, so that when you do eventually warm up you don't run the risk of having already drenched your inner layers in sweat.
^^^This
Also ^^^this
Liked 4,041 Times
Edit: I'm built like an air conditioner, all surface area, little volume. I've always run cold. 98.6 and what's going on? That's almost fever for me. (A little exaggeration but over the many COVID skin tests, I was only once or twice up to "par".
Likes For 79pmooney:
Columbia makes good jackets their linings have a reflective material that keeps you warm and they are 2 jackets in 1, the one i have is a water resistant outter shell with an insulated lining, and if its really cold a layer up
Coldest I rode was with 3 layers top bottom, neck gaiter, winter boots and 2 wool socks on flat pedals and with a granny jacket down to about -5 degrees F. It doesn't get any colder than that where I live. I think a parka or heavy jacket is a must, as are mitten multilayer gloves. Consider electric heaters too at those temps.
Quoted: 7 Post(s)
winter jacket replacements?
So this is the jacket I've also depended on for over ten years of winter riding. Yesterday the main zipper gave it up and the jacket is useless and I am panicking about a replacement. So many new brands, so many new materials and the cost has only gone up. The Gorewear jacket was $$$$ but it had quality everything and got me easily down into the 20s before adding a layer of silk or whatever. If you had to replace yours today what would you go with? Showers Pass is looking interesting but IDK...
