Removing crank arm from front chainset
The pedal threads on my bike’s right crank arm are stripped. So I need a new crank arm. I can get the chain set off. How do I remove the crank arm from the chainset? I just need to replace the arm, the gears are fine.
Quoted: 3625 Post(s)
Liked 3,047 Times
I think you’re asking how to remove the crank from the bottom bracket—part of which is the axle that connects the two crank arms. Without knowing the make/ model/ year (or better, a picture) of your crankset, we probably can’t help you. Some cranksets require special tools in order to remove them.
Likes For smd4:
Quoted: 1439 Post(s)
Liked 1,094 Times
It is possible to install a threaded insert called a Helicoil which will restore the threads stronger than new.
Likes For dsbrantjr:
Quoted: 5931 Post(s)
Liked 2,825 Times
Please provide specifics. There are many types of crank systems so without details only a psychic can answer your question.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 914 Post(s)
Liked 1,985 Times
crankarm removal tool. google park tools crank arm removal they have videos and tell you what tool you need.
SE Wis
Quoted: 2754 Post(s)
Liked 3,422 Times
As FB said it depends on what type of crankset and BB interface you have. Check the various types and determine what you have. Cottered, cotterless square taper, cotterless ISIS/Octalink, Hollowtech II, etc. Even between some of these there are variations like older TA and Stronglight cranks with larger than the now standard 22mm puller.
Quoted: 3324 Post(s)
Liked 2,165 Times
Based on the fact that you seem to be unaware of what type of crank and bottom bracket you have, you are unlikely to own the proper tools to do this, I would take it to a bike shop and have them deal with it. As dedhed stated, there are a lot of different bottom bracket/crank systems, and you would need to know by looking at it, which one you have and what tools are required.
Likes For Steve B.:
Quoted: 1324 Post(s)
Liked 927 Times
Sounds to me like the OP wants t remove the chainrings from the crankarm. He said he could get the chainset off but wants to get the crankarm off the chainset. Thus it seems to me that it's getting the chainrings off of the crankarm that's the issue.
That'll be determined by the crankset the OP has. He might be lucky and have one with 5mm hex bolts or he might be unlucky and have one where the chainrings are riveted to the crankarm. We need an image to know for sure.
Cheers
Cheers
Liked 2,825 Times
So, there are now 2 reasons to need to know more details.
IMO it's useless to try to guess, and the burden is now on the OP to provide the needed info, or admit to himself that he's best off getting a quote for the job at the local bike shop.
FB
Chain-L site
FB
Chain-L site
Clark W. Griswold
Quoted: 4488 Post(s)
Liked 4,160 Times
I would just guess. I mean that is what we have to do so try it and see or consider giving us the needed info on what you have so we can help without guessing.
A helicoil could be what is needed but who knows anything because there is nothing in the post.
I would probably just take it to a local shop and let them take a look at it. It will be less headaches. You can certainly buy tools and learn how to do it but for that again you would need to give us some info so we can help and I don't know that is something I would tackle from what I can glean from the lean first post.
Mad bike riding scientist
Quoted: 6270 Post(s)
Liked 4,299 Times
I don’t agree with most of what has been said here so far. We don’t need to know that much about the crank. A crank that needs to use the threads to pull the crank is going to be either a square taper, an Octalink, or and ISIS crank. All three can be removed with a pickle fork. Having the chainrings in place isn’t going to make that much of a difference in removal of the arm. It will be a little more complicated but not by much.
JD4ever: get a pickle fork from Harbor Freight or you can rent one from many auto parts stores. Put it between the crank arm and the frame and use a hammer to drive the fork down so that it wedges the crank arm off. It’s relatively easy to do and you’ll spend more time getting the tool than doing the job.
In the future, make sure your crank puller is engage as far as you can get it to go on the arm. The aluminum threads are very easy to pull out.
Stuart Black
Stuart Black
Liked 2,825 Times
No one before could help because we had no (zero, nada) info about the crank, but you've given advice based on it being a bolt on type. What if it isn't?
Cyccommute ----- Sorry. Couldn't resist. If you re-read the OP you'll see where you took the wrong turn. It references stripped PEDAL threads, not remover threads.
Likes For FBinNY:
Liked 4,299 Times
I’d also like to point out that removing the chainrings doesn’t require that we need to know the brand of the crank, the date of manufacture of the crank, how long it took to ship across the ocean, if the guy doing the polishing on the crank wife was having an affair, or any number of other details. Yes, there are some cranks with riveted chainrings but most aren’t. If they aren’t it takes a 5mm allen wrench (or possible a Torx) to remove them.
Stuart Black
Stuart Black
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1301 Post(s)
Liked 745 Times
Cheers
Cheers
Liked 2,825 Times
It's impossible to know what the OP actually means. At one point he seems to say he can get the chainrings off. Then he asks how to remove them.
The only thing that seems clear is that the pedal thread is stripped, and that that he wants to replace the crank (while keeping the chainrings). But who knows, except that this is a good example of GIGO.
Likes For FBinNY:
Liked 3,047 Times
He actually never mentions chainrings. He says “chainset.” As I read this, he could just mean the chain. So it’s hard to say what he’s done with the chainrings. Adding massive confusion, he asks how to remove the crank from the chainset.
