Mystery bike and build ideas contest
Bikes: 1999 Bike friday NWT, 2009 Bike Friday Tikit, 2023 silverock Dewy, 2008 Dahon Smooth Hound, 2023 Litepro Trifold
Quoted: 199 Post(s)
Liked 242 Times
Nothing to win but just for fun. What is this bike? What should I do with it?
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 276 Post(s)
Liked 246 Times
Well, I would say it is a Dahon Smooth hound 2010 break away version. That said, if it were fitted with Dura ace, it could be a hammerhead 8 but the wheelset is standard dahon deluxe.
You could either make:
- a road bike
- a gravel bike
- an hydrid bike
- a rigid mtb.
either way, you could upgrade to 9 (sora/alivio or microshift) or 10 (Tiagra or Zee or microshift) speed.
Some inspiration may be:
MTB
Road
Cyclocros/gravel
- a road bike
- a gravel bike
- an hydrid bike
- a rigid mtb.
MTB
Road
Cyclocros/gravel
Likes For Fentuz:
Quoted: 199 Post(s)
Liked 242 Times
Thanks for this information. I’m leaning toward the hybrid version. Based on the condition of the frame and components, this bike has has a tough life (maybe abused). I don’t want to add more by turning it into a MTB. So, I’ll use it in an urban environment with occasional gravel trails.The 8 speed Microshift acolyte would do and is less expensive than the 9 speed.
I paid 45$us for the bike. I’ll replace all the components except the wheels over the summer. My biggest issue is the bad black paint job that was applied.😕
Likes For jfouellette:
55+ Club,...
Bikes: 9+,...
Quoted: 1139 Post(s)
Liked 872 Times
That paint job equals a crime against humanity. I hope this ends well. I can't wait to see the finished project. 🤘
Quoted: 199 Post(s)
Liked 242 Times
The previous owner(s) painted over protective tape. I’ve removed some of it and the original paint is there. The tape was applied on some parts of the frame only. Pictures later…
Quoted: 199 Post(s)
Liked 242 Times
Here are pictures after I removed the tape. Paint thinner works well to remove the adhesive residue. The original paint is still nice which is maddening to think someone painted over it.
55+ Club,...
Bikes: 9+,...
Liked 872 Times
That's going to be a complete strip job. Definitely a crime doing that to this bike. ☹
Quoted: 199 Post(s)
Liked 242 Times
I started wet sanding the black paint down to the original blue paint. Obviously I can’t remove all of it but using finer grit , I may be able to get away with a matte clear overcoat. A gloss finish is doubtful. Not perfect but better than what it is now. I won’t be using nasty chemicals stripping the paint. Been there and done that. I paid 45$ for the bike. My budget is going on components.
Quoted: 276 Post(s)
Liked 246 Times
So this is confirmation you have "2008 break away" smooth hound. I would not worry about the painwork quality; it is crap for factory... both my smooth hound and hammerhead 8. I think they didn't use a good primer and everytime the chain or a rock get in touch, it flics the paint off (On the hammerhead, nail scratching does it).
Still, I would go to 9 speed. Shimano Alivio shifter is about $25, shimano derailleur M340 is $20 or less and a 9 speed sunrace 11-36 cassette is $30. and since you are aiming for a urban environment, I'd stick some continental urban contact 42-406. When I run the bike as a "go to the shop" bike, in flat bar with contis, it was nice, comfy and zippy.
Quoted: 519 Post(s)
Liked 633 Times
Shimano
In 2014 I bought a second hand Dahon Dash P18 which came with a Shimano SLX HG81 11-36T 10-speed cogset
In 2016, I changed the RD to a Shimano Zee. The cogset was moved to my FSIR Spin 5 when I sold the Dash frameset, and subsequently to my FSIR Spin 3 where it is presently installed. The cogset and RD have provided flawless performance since 2014 and 2016, respectively, through the rigors of touring. They are with me now on tour in Korea and still functioning perfectly several tours later.
Moral of the story: buy once, buy right. Spend a little more to get a lot more. Oh yeah, the SLX shifter from the 2014 Dash is still mated to those two components too. Don't be pound foolish; buy Shimano. The sweet spot is probably at Deore.
Smooth, crisp shifting is mostly a matter of the shifter once you've got the RD aligned and the upper/lower ranges dialed in. Invest in an XT level shifter. The haptics are so nice.
If you want to go 11-42T, I can also make recommendations based on long-term, real-world use.
Quoted: 199 Post(s)
Liked 242 Times
Hum, quite a few good ideas to think about. Thanks.
I finished removing most of the black paint. I can’t get in all the areas so this will be it. I decided not to use sprayed clear coat. Automotive wax will do for now. Here is the result.
iti biking
One advantage of 9 speed Microshift Advent over its 8 and 10 speed siblings is that it has the widest range of shifters. Acolyte is flat bar only, while Advent X is a choice of flat bar and brifters. Advent has those, bar end shifters and thumb shifters. If you want to mess about with different builds on the frame, 9 speed is the sweet spot with Microshift.
Quoted: 199 Post(s)
Liked 242 Times
I measured the steer tube and outer diameter is 38,1 mm. That creates a challenge fitting it with a standard 25,4 mm stems. The tube also has a protrusion all along its length...This interferes with a 38,1 stem (see the previous pictures). Any ideas?
Quoted: 276 Post(s)
Liked 246 Times
it should be a shim. I did not fit it and used Std 1" 1/8 stem with 31.8 handle bar.
Quoted: 199 Post(s)
Liked 242 Times
Correct! It’s a shim. Many thanks for the help.
Schwinnasaur
If that short piece of the vertical went inside the stem riser and the horizontal stem fit around it, then it's a shim. Hope I helpful, I do not have any experience with that bike.
Likes For Schwinnsta:
Quoted: 276 Post(s)
Liked 246 Times
Quoted: 199 Post(s)
Liked 242 Times
Update: I removed the left crank , the right has stripped threads (not from me). I cut part of it with a metal hand saw. I ll try with a Dremel for the rest. I installed the v brake calipers but one screw stripped. I ll get a screw removal bit for that. Handle bar, steerer tube spacers, adjustable stem, brake levers temporarily.
Satori Melange Medium: https://www.satoribike.com/pro.php?m=d&pid=19&cid=8&f=2
Likes For Jonesandrew:
Quoted: 199 Post(s)
Liked 242 Times
Here is an update picture.
