Trek Verve upgrades/forums
Hey all....posted similar in Gravel bike forum, figured I'd try here also.
Just purchased a very lightly used Trek Verve2 2021 year.
Any must do upgrades that are worthwhile? Tires, gearing bars etc. Looking to see what's possible. Just want to
enjoy throwing better stuff on, making it my own...any forums, info, upgrades etc. would be appreciated. It's a red 2021 and is painfully stock. LOL I'd post a pic but you
know what they look like and I don't have enough posts to be allowed yet. Thanks in advance!
Happy banana slug
Liked 1,590 Times
Hi [MENTION=567907]Jbirdie57[/MENTION], welcome! Congrats on the new bike. You could just ride it and upgrade as parts wear out. Otherwise, mfr's usually cheap out on things like pedals, tires, and saddles, so those would be a good place to start. Unless they're comfortable, especially the saddle, then ride them to bits!
Clark W. Griswold
Liked 4,234 Times
I wouldn't put money towards the bike, just ride it as is and save your money towards a bike that will serve your needs better.
It is possible the brakes are part of the recall so you might check on that and replace as needed but don't put a bunch of money towards it. The Verve is a low initial cost bike so ride it and figure out what you like and don't like and get a bike that has what you want on it.
If you had to put anything towards the bike find things like touch points (pedals and saddle and maybe grips) that can be moved to another bike easily.
Deraill this!
Bikes: 18 Cdale Quick 1, 94 S-Works M2, 98 730 Multitrak, and a few others
Liked 478 Times
Welcome!
It's your bike so do as you please!
My wife has a Verve 3 that I have resisted the urge to modify beyond saddle and a pink kitty bell to match my daughter's bike. Future changes will be limited to pedals, tires, and SKS Blumel fenders. I have considered upgrading the group but it works great for her so I'll leave good enough alone. It's better that way for all parties involved.
Likes For Jbirdie57:
Clark W. Griswold
Liked 4,234 Times
The coolest thing is getting the bike you want. Save the money towards the bike that you want. Buying a bunch of single components is expensive buying a bike with all the components you want or as close as reasonably to it as possible is cheaper. For low initial cost hybrids it is just spending the least you can to keep it safely rideable and when it starts getting expensive time to move on. Good pedals and a saddle you like can move to a different bike but certain other components might not be worth it and putting that money towards the current bike will not really add the value that will make it all back at the end.
Also moving accessories is fine, lights and bells and stuff like that can sometimes move to a different bike. I have lights I move between bikes frequently.
Happy banana slug
Liked 1,590 Times
Likes For Korina:
Bikes: More bikes than riders
Liked 768 Times
The other side of this discussion is the intangible enjoyment you get out of turning hex wrenches and putting your stamp on something. I get this completely. I have six or seven hybrids, and all use pretty much the same basic component standards (7/8/9-speed drivetrains, 100/135mm hubs, etc.) and I swap stuff around on them all the time. I like trying different things and seeing how this component over here might work over there. My goal is not to get more speed out of one bike vs. the next. My goal is not to set a personal best record on a particular ride route. That's not why I cycle and it's not why I wrench on my bikes. I do it because it brings me enjoyment and satisfaction...it's something that I personally enjoy doing and I'm not particularly concerned about the financial perspective or getting my money back on something. That's not the end goal for me. Most of my bikes are hybrid bikes because they're what I like to ride.
So I can certainly identify with wanting to upgrade a Verve. I've done that myself. I once owned a 2015 Verve...beautiful bike and I never should have sold it. I sold it to buy a 2018 Giant Roam and never really did like that Giant the way I'd hoped and wish I had that Verve back. Anyway, the 2021 Verve has clearance for big tires and tires are the first thing I'd personally do with it. If you're interested in a nice ride or lower rolling resistance, you can spend money on some pretty supple tires...there are plenty in the 45-50mm range for these wheels (622mm, or more commonly referred to as "700c"). If your Verve has disc brakes, you could consider swapping to 584mm wheels (more commonly referred to as "650b" or "27.5 inch"). This would allow for even larger rubber if that interests you. I agree with Korina on things like saddle, pedals, and grips. These three contact points are usually pretty basic items from the factory and better stuff can be had. You may find better braking out of upgraded brakes or just brake pads (regardless of whether you have disc or rim brakes).
I like adding a rack to make the bike more versatile. I do enjoy "utility biking" where I'm riding with a specific purpose (groceries, hauling something from here to there, etc.). I have a bike trailer that started out as a Thule Chariot jogging stroller and it's now a flatbed cargo trailer that I use for hauling camp chairs to go watch fireworks at the park, or hauling firewood, or even Chick-fil-A hot boxes full of sandwiches for a fundraiser at church.
None of the things I mentioned above are required to ride or enjoy your bike, they won't make you faster, and they won't increase the value of your bike. However, I suspect you're a little bit like me and none of that is the object of the game for you.
First thing I did when I got my Verve is remove the 45mm tires that made the bike feel slow and cumbersome. Added fenders, a rack, changed the pedals, and added a brooks saddle.
Not sure why you would want to change the derailleurs? The bike comes with adequate deraileurs. Its not a bike for fast paced riding. I ride 100% rail trails that have mostly packed limestone/limestone dust, and some asphalt. Not sure your intentions for the bike, but unless you are riding gravel or rougher surfaces the first thing I would get rid of are the 45mm tires. I hated the stock tires it came with. Other than that, you are not going to find much difference in different derailleurs unless the ones on the bike are not working right. If its not shifting right most likely the cable tension for the derailleurs just needs adjusted. If its just better deraileurs you want. I'd save my money and get a different bike with better derailelurs.
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Liked 155 Times
It makes the front setup trivial.
Had enough posts to be able to send pics. My 2021 Trek Verve2 Still want to make it a 1by, cleaner look. A few mods....anyway here it is, thanks all for advice. Each post was read and considered.
Deraill this!
Liked 478 Times
Welcome!
- Swapped the original saddle for a Selle Anatomic R2 I picked up on sale. (Impression is still forming)
- RaceFace Ride pedals replaced the Trek platforms
- I installed Shimano Alivio brakes in place of the Tektro assemblies that came on it. I'll use the Tektro assemblies on another project bike that needs brakes. For $30, I think it was a wise and worthy upgrade.
Likes For Trav1s:
FreedomRider
Bikes: 1971 Raleigh Sports, 2008 Specialized Sequoia, 2016 Trek Verve 2, 2023 Cannondale Adventure Neo Allroad ebike
Liked 256 Times
This morning's ride with my 2016 Trek Verve 2 ... biggest upgrade is a rack , pedals / toe clips, and a Brooks B67 saddle with a non-suspension seat post. I have replaced the rear axle (snapped in half!). Otherwise, a fine bike for rides under 50 miles.
Trek Verve 2 at Manchester-By-The-Sea, Massachusetts
Maybe someone can point me in the right direction. I have a Verve 2 Step through XL frame. It seems like the Bontrager H5 700x45 tires are a thing of the past that originally came with the bike.
What would you guys recommend?
Mostly neighborhood riding and paved trails/rail to trails stuff. This bike is 99.9% used on paved surfaces. I’m interested in puncture resistant tires for sure as this is what destroyed my stock tire.
thanks
thanks
Clark W. Griswold
Liked 4,234 Times
thanks
thanks
Liked 768 Times
https://www.continental-tires.com/pr...res/ride-tour/
The solid center rib provides a smooth and quiet ride on pavement, but the tire can handle some off-pavement stuff with the side tread blocks, especially if you air them down just a little bit. The 47-622 size under the 28" product heading would be the size appropriate for your Verve.
Likes For hokiefyd:
Clark W. Griswold
Liked 4,234 Times
In addition to this very good suggestion, check out the Continental Ride Tour. I use and recommend these as very durable tires:
