Dahon Launch second generation hinge
Quoted: 354 Post(s)
Liked 124 Times
It seems that Dahon has a new version of the Launch hinge. Instead of the serrated engagement teeth that extends all the way to the exterior of the hinge, it is now smooth teeth and is hidden inside.<br /><br /><img src="https://cimg6.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1563/untitled_1_jpga_fca308f5d1d718e3bfd3d2f3db0414f3ccdfa460.jpg"></img><br /><br /><a href="https://youtu.be/9w23adDuEmM">https://youtu.be/9w23adDuEmM</a>
https:// youtu .be/ 9w23adDuEmM
<br /><br /><a href="https://youtu.be/ibLo7sYruow">https://youtu.be/ibLo7sYruow</a>
https:// youtu .be/ ibLo7sYruow
<br /><br /><a href="https://www.dahon.com.hk/products/dahon-archer-pro-folding-bike-kba005-black-20-jaws-hinge">https://www.dahon.com.hk/products/dahon-archer-pro-folding-bike-kba005-black-20-jaws-hinge</a><br /><br /><a href="https://www.dahon.com.hk/products/dahon-launch-d8-8%E9%80%9F%E7%A2%9F%E5%89%8E%E6%8A%98%E7%96%8A%E8%BB%8A-kba083-8spd%E6%9A%B4%E9%BE%8D%E6%8E%A5%E9%A0%AD">https://www.dahon.com.hk/products/dahon-launch-d8-8%E9%80%9F%E7%A2%9F%E5%89%8E%E6%8A%98%E7%96%8A%E8%BB%8A-kba083-8spd%E6%9A%B4%E9%BE%8D%E6%8E%A5%E9%A0%AD</a><br /><br />There are 2 models, one is called Launch D8 KBA083, and another one is Archer Pro KBA005.<br />There are other Launch models that don't have the "jaws hinge".
Quoted: 354 Post(s)
Liked 124 Times
https://www.dahon.com.hk/products/da...8E%A5%E9%A0%AD
https://www.dahon.com.hk/products/da...-20-jaws-hinge
55+ Club,...
Bikes: 9+,...
Quoted: 1144 Post(s)
Liked 879 Times
How about actually sharing the video next time,... (the second one I couldn't locate)
Rider. Wanderer. Creator.
Bikes: Bike Friday Pocket Rocket, Cinelli Hobootleg, Zizzo Liberte
Quoted: 423 Post(s)
Liked 882 Times
https://www.youtube.com/watch?v=9w23adDuEmM
Quoted: 354 Post(s)
Liked 124 Times
There is a bug in the forums that hides the iFrame of youtube videos in the post, and then if you try to edit the post, it inserts the HTML tags.
If you look at my original post, you can see the video URL in between the HTML tags.
If you look at my second post, you can see the video URL clearly with spaces inserted to prevent loading the buggy iFrame.
Quoted: 354 Post(s)
Liked 124 Times
55+ Club,...
Bikes: 9+,...
Liked 879 Times
It was shared by me. Either you're using the controls on top of the comment box incorrectly, using an add blocker, or you're using the wrong format. Otherwise the issue is on your part.
Palmer
Quoted: 1702 Post(s)
Liked 1,889 Times
The "Deltec" cable. Dahon claims great things about strength and pedaling efficiency based on testing (results advertised but details not yet made public.)
Bike frames with tension cable members: Dursley-Pedersen, 1890s.
There was a manufacturer in the late 80s/early 90s that used cables for the downtube as well based on the idea that a typical downtube operates primarily in tension.
Quoted: 354 Post(s)
Liked 124 Times
I'm interested to know whether the newer hinge design without the serrated teeth and a recessed edge, has any benefit over the older design, other than ingress of water/dirt.
Likes For john m flores:
Likes For Schwinnsta:
Quoted: 646 Post(s)
Liked 738 Times
I've got mixed feelings.
Dahon finally has disk brakes, FINALLY upgraded the hinge (which I'll wait until the second iteration).
But that cable....
ugh!
Nothing says "we have no faith in our own frames" than an after thought structural cable.
(possible lawsuit induced?)
I'll likely on my last Dahon, and when it goes.... [not sure yet]
Edit:
Looked at the hinge. Clamp on the bottom and a bolt neat the top. hmmmm... I'd have to see it up close.
At lease the frame is finally strengthened around the hinge.
Edit edit:
Better bottom bracket, more contact surface area for the hinge.
When it folds the cable makes it ugly. (yikes)
The underneath locking mechanism is a welcome change.
Palmer
Liked 1,889 Times
Likes For tcs:
Likes For CrimsonEclipse:
Likes For tds101:
Bikes: 1999 Bike friday NWT, 2009 Bike Friday Tikit, 2023 silverock Dewy, 2008 Dahon Smooth Hound, 2023 Litepro Trifold
Quoted: 206 Post(s)
Liked 250 Times
[QUOTE
Of course in your analysis, going to discs means they have no faith in their rim brakes...[/QUOTE]
Granted disks provide more power ,it’s also a marketing benefit. Having disk brakes give’s the bike more high end appeal.
Quoted: 206 Post(s)
Liked 250 Times
A
Disk do offer more braking power but at an additional cost vs v-brakes. The later are still adequate for many situations. The bike industry likes them for the extra profits from disk replacement and bike shop for the maintenance. I have both and well adjusted v brakes with koolstop pads provide very strong braking power. Going down the Alps is another thing…😀
Likes For jfouellette:
55+ Club,...
Bikes: 9+,...
Liked 879 Times
A
Likes For tds101:
Quoted: 354 Post(s)
Liked 124 Times
Let me take a wack at it:
https://www.youtube.com/watch?v=ibLo7sYruow
But that cable....
ugh!
Edit:
Edit edit:
But that cable....
ugh!
Edit:
Edit edit:
I would assume most of the bending load still goes to the pin on the left side.
But the jaws reduce the load on the pin by making the connection more stiff.
The problem with the other hinge designs is that the right side was just a single point connection in tension, and flexed like a see-saw.
Likes For tomtomtom123:
Is there any updates on the performance of the gen2 hinge.
I'm looking at buying a folding bike.
Deciding between
Dahon Mariner D8 = $800 NZD RRP (500 USD) - older style hinge
Dahon Launch D8 = $1000 NZD RRP (620 USD) - gen 2 jaws hinge
Tern Link C8 = $900 NZD display model (~550 USD)
Unfortunately no one sells the bike in my part of NZ so I have to get it shipped, these are shipped prices.
Thanks for your thoughts.
Deciding between
The Deltec cable on the Dahon is more feasible, because the monobeam frame is much larger in closed section size, so has a bunch of torsional stiffness. The Deltec only reduces the bending moment on everything on the monobeam, including the beam, welds, but most importantly, the hinge. Which is why I improvised a deltech for my Speed from kevlar line, and it really tightened up the hinge, haven't had to adjust the hinge since.
The new Launch also looks like it has a hollowtech II style 2X crank, just like I retrofit to my Speed. These guys can't stop imitating me. EDIT: OH!!!! That's right, the past Launch is just 1X! They really did imitate me. Although I would have used 110 BCD 50/34, looks like that is 130 BCD 52/42.
I'm still figuring out the Launch hinge 2.0, I need to see better views of it open. The previous Launch hinge just tightened vertically. I don't know if this newer one is different in concept.
EDIT: The welds around the hinge are dressed, smoothed out like my vintage Cannondale, vast improvement in aesthetics there. Looks like all other welds as well, that's a big deal, not just looks, it also reduces the stress concentration at the boundaries of welds. OK, looks like Dahon is trying harder.
Only downside I am seeing is still no thru-axle, especially in front, to keep wheel from popping out of dropouts under hard disc braking. They also could have instead, mounted the front caliper on the front of the right fork blade, like on the new Curl.
Deciding between
Deciding between
EDIT: In the past, I would not have wanted 10-speed rear, I had preferred 8-speed as more durable, and at one time it was. But now it seems, all 8-speed chains are crap material (either worse than before, or not as good as they needed to develop for 10+ speeds), so 10+ speed chains are more durable, so I would now favor that.
55+ Club,...
Bikes: 9+,...
Liked 879 Times
As noted in my previous post, I think the new Launch is a significant advance over the last, in addition to the new hinge (which I don't know if is better); Front derailleur mount and 2X crank and I think I saw 10 speed rear, so 20 speeds, nicely dressed welds. That blows away the Mariner, for only USD$120 more. If I didn't already have an old Dahon Speed retrofit with a 2X crank, I'd buy one. But I still would like disc brakes. $1000? (current Launch D8 price), no. $620, I might be tempted.
Definitely not on Dahon USA's site yet. I've tried to bring up bookmarks I had for other stuff there, like Deltech, and it just defaults to their homepage. Now, I just tried Dahon's international site home page, for a second it flashed a page about Deltech, then instantly defaulted to the USA site. Guess they don't want people looking at Dahon outside their markets.
I need a VPN like russians seeking truth about the war.
EDIT: Even this link, hyped by Dahon as new ("Speed Technology", supposed to be frames more rigid than conventional bikes), I try to pull it up, flashes for a second, then defaults to Dahon USA site home page. Idiots:
https://dahon.com/the-folding-bike-p...and-solutions/
Where I saw the above link, article had this to say:
"Notably, DAHON is poised to launch a new range of aluminum and carbon fiber frames utilizing Speed Technology. These frames boast a 10-20% increase in stiffness compared to traditional road and mountain bike frames."
! Could that frame in the above video be carbon, and not aluminum with dressed welds?! Video is an east Asian language so I could not understand a word.
More info regarding my edits above, both aluminum and carbon are confirmed:
https://www.bicycleretailer.com/anno...ycle-show-2024
Commenting on that article... rigid is not always better. Usually you want frames rigid in torsion, but some flex in longitudinal bending for a decent ride. But also, the head guy at Bicycle Quarterly has opined that he prefers a frame matched to the rider weight and style, not completely rigid, but having just the right spring to it in pedaling. I have not experienced what he is talking about, but he's a hard-core biker, and samples among the best bikes on the market, so I don't discount what he says.
