Cost-effective chain lube
Quoted: 1869 Post(s)
Liked 666 Times
suggestions? Need to recommend one to a friend - good rider, not a mechanic.
Quoted: 6329 Post(s)
Liked 4,916 Times
Cost effective? Even the overpriced bottle of lube I bought at the bike shop has lasted 2 years and probably will last another year. So cost of lube really isn't an issue. Just use something.
Likes For Iride01:
Quoted: 2629 Post(s)
Liked 1,979 Times
Got an oil can and a half-used bottle of 10W30?
Likes For pdlamb:
Quoted: 430 Post(s)
Liked 714 Times
There are all kinds of lube, some for dry conditions, some for wet conditions, some that you may want to wipe down and re-apply more often, some which may not need that. Your friend will want to consider where he rides, and in what conditions. The important thing is to keep the chain lubed, if it gets gritty then clean and re-lube. Just don't let it get "dry" and cause wear on components. If doesn't want to pay the price for pre-made lube, I'm sure google has many DIY "recipes" for homemande lube.
Likes For freeranger:
Liked 666 Times
Ok, I'm gonna tell her to buy ProLink at REI.
Quoted: 511 Post(s)
Liked 651 Times
Home brew ProLink: oil of your choice (lots of people use motor oil) diluted in three parts odorless mineral spirits. Lube the chain liberally and then wipe off all the excess. Solvent evaporates leaving the lube where you want it. Been using this for hundreds of thousands of miles with great success.
Likes For KerryIrons:
Quoted: 1609 Post(s)
Liked 1,800 Times
Gulf Wax is like $4 a pound at Wally. 2 pounds will last you just about forever.
Likes For icemilkcoffee:
Likes For Atlas Shrugged:
Insane Bicycle Mechanic
Quoted: 814 Post(s)
Liked 746 Times
Jeff Wills
Jeff Wills
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
My favorite lube happens to be Boeshield T-9. It looks pretty expensive at ten bucks for a little bottle. But that bottle will last me two or three years. And I'm not stingy. I like lubing my chains, so I do it about every 200 miles. To me, one or two tenths of a penny per mile ridden seems reasonable.
Bikes: 1995 Specialized Rockhopper,1989 Specialized Rock Combo, 2013 Specialized Tarmac Elite
Quoted: 213 Post(s)
Liked 589 Times
I like Dumonde Tech Classic Lite for dry conditions in my area.
Quoted: 3406 Post(s)
Liked 5,590 Times
Likes For Shimagnolo:
Relevant to the context of this thread.
Is the goal to have a low-cost lubricant, or for the lubricant to minimize the cost of riding a bike? Lubricants are fairly inexpensive, but decent metal drivetrain parts can cost quite a bit, so a lubricant that produces good component longevity might be more cost-effective to use even if it's relatively "pricey". So for instance, Silca's Synergetic is a very expensive wet lube at ~$25 per 2oz, but in independent testing it's performed extremely well in wear rate tests compared with most other wet lubes.
Likes For HTupolev:
Quoted: 999 Post(s)
Liked 1,674 Times
Automatic Transmission Fluid - ATF
I use ATF as a Luber and a Cleaner of my chains. I use a little squirt bottle to apply a liberal amount then run the chain through a heavy cloth to get off oil and crud. I do this often as the dusty roads I ride dirty the chains quickly. The other advantages are ATF is cheap, penetrates well, is usually rubber friendly, does not stink, and has many other uses in the household. If I need more lubrication I just use a little 10W-30 as a chaser.I have, over the years, come to consider bicycle chains a disposable item. I clean um, lube um, use um, and think nothing of changing um out for new when they get worn. Same way with the new tires, tubes and maybe even freewheels.
(Except my old Regina 14-26. Now a worn Wall Hanger that gets taken down and used as a Figit tool. The sound of it bringing calming memories...)
Likes For zandoval:
Bikes: Habanero Titanium Team Nuevo
Quoted: 401 Post(s)
Liked 187 Times
Quoted: 992 Post(s)
Liked 589 Times
Hi, Ken!
I've used ProLink for years, and I think I've only ever used one bottle.
My only objection is that it's very runny, and it takes a little concentration to dispense only one drop to each chain link. Not really a big deal.
Chain life is good, and the chain stays fairly clean.
Cheers,
Steve
Cheers,
Steve
Home Depot:
https://www.homedepot.com/p/Blaster-...-CCL/205851095
Squirt a little on the chain and kick it back a few time every other ride.
Squirt a little on your garage door opener rails and bearings for a smoother open
working on my sandal tan
Quoted: 3873 Post(s)
Liked 2,574 Times
Is there a mainstream chain lube that *isn't* reasonably cost-effective when used properly? People will fixate on the smallest things...
Likes For ThermionicScott:
Quoted: 3606 Post(s)
Liked 3,023 Times
I recommend canola, but olive can add a touch of floral aroma with a nice peppery bite.
Tri-Flow when I started cycling back in 1985ish. Being lazy about cleaning my bike, I switched to Rock N Roll Gold in Oct 2016. Now wax since 2020 (completely) when I started doing more indoor training. Don't you have a default? It can't be that expansive. The Rock N Roll Gold 16 oz w/4 oz bottle I bought lasted me over three years (>20k miles & still have some in the garage after switching to wax). It only cost $23.20 on Amazon today. It's that cheapest thing for my bikes!
How cheap is the friend?
