Dynamo lights won`t turn off
Bikes: Ridgeback Steel Tourer,Recumbent SWB,Steel Road,,Raleigh Twenty,Elephant Bike,Pashley Pronto TNT.
Quoted: 21 Post(s)
Liked 5 Times
I just installed a sturmey X-Fdd dynohub on my elephant bike. It powers the lights ( band M cyo and tailight ) ok but i can`t turn them off. I have several dynohubs,including another x-fdd on my other bikes,but have not had this happen before. I tried swapping the wires around but it stays on. Any help please,Thanks.
Quoted: 21 Post(s)
Liked 5 Times
Yes, a switch on the back. But,it stays on.
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 184 Post(s)
Liked 310 Times
If you ride it with the light in the off setting does the light illuminate? If so, then there is a problem with the light. If you ride it with the light on, then want it off, the standlight capacitor will need to discharge before the light is fully off. The standlight in my B&M taillights stays on for over an hour, they are just that good.
Quoted: 3522 Post(s)
Liked 1,500 Times
If there was a wiring problem between the hub and headlamp or between the headlamp and taillight, it would mean you could not turn it on, so not a wiring problem.
Is the headlamp still under warranty?
One of my B&M headlights, the on and off switch in the back of the light does not work. I did not realize that until after warranty expired. Mine is a different model.
working on my sandal tan
Quoted: 3873 Post(s)
Liked 2,574 Times
Do you press the button while the wheel is turning? I’ve noticed that my Eyc doesn’t respond to the button when the bike is stationary. I assume the switching is electronic and needs some juice coming in to register the change.
Quoted: 21 Post(s)
Liked 5 Times
Thanks for all your replies. I got this light when they first came out.It has the metal casing. I think I will just run it with the lights on. I`m suprised its still going at all after 15 years?
Likes For Grishnak:
Liked 1,500 Times
Likes For Tourist in MSN:
Randomhead
Liked 3,786 Times
I expect most of my dyno lights will last 15 years, but I got my first one in 2011 and it failed. But that was because the shell came apart and let water in, I think.
