How do I make a seatpost opening larger?
Hi all, my research indicates my serotta Colorado ii bike should have a 27.2mm seatpost, but my seat tube opening is measuring 26.0-26.8mm. It's hard to tell if the variance is due to my tool or the tube being ovalized. The binder bolt is loosened. This frame is new to me and I do not know it's history.
Does this mean someone overtightened the seatpost collar at some point? If so, is there a trick to getting it back to 27.2?
Edit: forgive the mess. I'm in the midst of re-organizing the garage. I promise that's not how I store my good wheels lol.
Sr Member on Sr bikes
Just a comment about the measuring tool you’re using…if you’re getting a variation of more than ¾ of an inch, I think you need to use a more reliable tool.
Dan
Dan
Likes For _ForceD_:
Bikes: Cuevas Custom, Cimmaron, 1988 "Pinalized Rockma", 1984 Trek 510, Moulton custom touring, Raleigh Competition GS, Bridgestone Mb-2 & 3, 1980's Peugeot - US, City, & Canyon Express (6)
Quoted: 1151 Post(s)
Liked 3,942 Times
??? - bit of a mystery
Sorry for the dumb question, did you double check the calipers were zeroed? I ask because even though I know better, I have made that mistake before
Likes For SoCaled:
Quoted: 4857 Post(s)
Liked 4,001 Times
It looks to me like the pin go tightened until the ears hit and chipped the paint. Shouldn't happen. That may well have been done in an attempt to secure a too small post, closing up the whole lug in the process.
Nice bike. I'd take this to a frame builder and let him make the call.
Likes For 79pmooney:
Quoted: 3306 Post(s)
Liked 2,146 Times
Research says it should be 27.2 but your measuring tool says 26. I would be questioning the measuring tool and getting a digital caliper. You do not want to force a too large seatpost. FWIW, Sheldon’s site lists every Serotta using a 27.2, so possibly a prior owner used too small a seatpost and forced the tubes together.
Likes For Steve B.:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3921 Post(s)
Liked 6,560 Times
Do you not have a seatpost you can try?
The seatpost lug looks fine. I would try a couple different sizes of seatpost (26.8, 27.0 and 27.2) and simply use what fits the most snug.
Likes For SurferRosa:
I tried a 27.2 post and it did not fit. I figured it was probably better to try to fix the collar rather than just put a smaller post in.
Likes For J_Climacus:
Quoted: 2369 Post(s)
Liked 2,899 Times
I would measure both seatpost and seat tube interior
you could take a train to Philadelphia and have Bilenky cycleworks take a look https://www.bilenky.com/
Quoted: 999 Post(s)
Liked 1,674 Times
Simple:
1 - Clean out the seat post. Do it right. Take out the bottom bracket and clean and even sand it out.
2 - Check its round. Very important, at the midway point and its top. The top of the seat post is likely messed up.
3 - Take a pipe and wrap tape tape around it till it fits snugly in the seat post mid way to the top.
4 - Measure the diameter of the tape and thats what ya need.
Don't be surprised if the diameter does not meet the expected specifications. That happens allot. Also note that this is not, The Way but just, A Way of doing it. I always shoot for a seat post diameter well below the top of the seat post.
Likes For zandoval:
señor miembro
Liked 6,560 Times
Likes For choddo:
Don't remove any metal on the inside of the seat tube/lug, to make it larger, that will weaken the area.
Resizing something like that, in my opinion, would require either a) "ball resizer", that is how we swaged the interior of precision tube in industry, or b) a "tube expander", like they use with automotive exhaust systems. There will be "springback", this takes skill.
Dial calipers are not the best tool to measure the inside tube diameter. A machinist will use "telescoping gages", a T-shaped tool (different ones for different ranges), that has plungers on each side 90 degrees to the handle, you put inside the tube at an angle, tighten *very slightly*, cock the handle over past parallel to the tube, the plungers will stay in at actual measurement, then you *very carefully* measure the gage with a micrometer, that'll measure within 0.0001 inch. Then you check the hole all around, from different angles, to see which way it is ovalized, and that will help a skilled framebuilder or metalworker, expand the hole properly to get back to original size.
Telescoping gages can also measure much deeper down inside the tube, to verify the actual tube size before squeezed too far smaller.
Likes For Duragrouch:
Mad bike riding scientist
Quoted: 6257 Post(s)
Liked 4,280 Times
Stuart Black
Stuart Black
Quoted: 4554 Post(s)
Liked 1,697 Times
I would also treat this like it is a good frame, because it is.
Something you could try, as long as you take your time, is pull the seat binder bolt out, thread it in from the left side and slip a penny or dime in the slot so the bolt pushes on it as the bolt is tightened. It shouldn't take a lot of this to push the ears apart until the proper 27.2 greased post will fit. If it does, you can decide to deal with it like that, or take it somewhere competent to get fixed. If it doesn't, definitely take it to somewhere competent like Bilenky.
When this kind of thing happens, it doesn't generally make the diameter smaller - it just pinches the opening into a teardrop shape. So whoever fixes it is primarily bending those two ears back out to where they belong.
Likes For Kontact:
Quoted: 5900 Post(s)
Liked 2,772 Times
The first step is to stand behind the bike and eyeball the slot. These are cut with a saw of fixed width, so should be the same width top to bottom. If not, the top was pinched closed.
You can reopen the top by careful prying. Being steel, the frame is maleable enough to allow spreading back to size without harm. So your only worry is cosmetic.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 4231 Post(s)
Liked 3,940 Times
Yes, terms matter and the "seat post" is really the frame's "seat tube".
I see chips on the seat lug's ears right where one might place the tip od a screwdriver to try to pry out/bigger the seat post fit. IME this suggests a too small post was once used and the lug closed up some and someone tried to "fix" it. Or perhaps the post had just started to seize in the seat tube and the prying was an attempt to free up the post.
What most have said is good advice. The safest solution with the least "non reversable" result is to use a small enough post. Next up is doing mechanical working (blacksmithy with slightly small posts or pipes) on the lug area to open up the fit at that point. Running a hone down the seat tube top portion to remove burrs is a good idea regardless of what path is taken, honing doesn't remove hardly any bulk but is great at small high points. Last would be running a reamer, which is designed to remove bulk, in the tube and a honing follow up.
But when reaming it can be tricky to track what is actually being removed, one wants to avoid tube wall removal below the lug's lower edge (as that's only the tube wall below). Having said that often the critical area of heat deformation is right where the two different wall thicknesses meet (wall 1 being the tube and above that wall 2 is the lug/tube combo with braze filler between). I have seen more than a few frames where the seat tube was heat bulged significantly just below the lug, How far the resulting "correction" can be done can be limited by the frame's condition.
A commit on the OP's assumptions- One metaphor I like to use in talking about post fit is one of choosing a pair of shoes. One picks a "size" that fits the feet, regardless of what a shoe sales person thinks they have measured (such a word, filled with so much presumed fact) you feet as. Or at least we hope the actual fit is the final guidline and not the suggestion of having foot surgery to have your foot be able to fit in a shoe. Of course there are situations where foot surgery is the right choice (I have two TI plates in my toes...) but I think we can agree that we should do our homework before cutting skin.
I also question the OP's measuring methods, tools, results. There have been a few seat post fitting threads here recently and my advice here is the same as with the others. The only measurement that really counts is how the post fits and is secured. Very small amounts of diameter "drift" result in 22/7 (3.1415) huge amounts of circumference increase. And the sear lug has to clamp around the post's circumference. Given the OP's challenges with basic tool/measuring challenges I suggest they get someone who is more experienced to help out. Perhaps even show the OP some tool tips. Andy
AndrewRStewart
AndrewRStewart
Liked 2,772 Times
In any case, the slot tells the story. Multiply the difference in slot width, top and bottom, by 3 and you have the difference between top size and true size.
I spread frames that were closed by clamping to undersized posts using a pair of wedges I made from 2 old cone wrenches, using a belt sander.
Solving the OPs problem.is a 5 second job.
Bikes: Bicycles? Yup.
Quoted: 492 Post(s)
Liked 1,653 Times
Or just get ahold of a seatpost sizing gauge.
I'm un-ovalizing a seat tube today, and will post pics later...assuming everything goes to plan.
Liked 4,280 Times
Why wouldn’t it work? I used a seatpost gauge on hundreds of different frames as part of my work at the local co-op and never found a frame the gauge wouldn’t work on. Seatpost get stolen regularly and we have to find new ones. The gauge makes it simple.
Stuart Black
Stuart Black
Likes For cyccommute:
Hi all, thanks for the responses so far. Responding to a few specific points below.
My hesitation with using the closest fitting post is that I may run into post slip down the road. If it's ovalized, which I suspect, I do not have confidence that the clamping force will make it all the way around the post, leading to the post slipping or turning. It seemed like a better option to return it to factory spec, if possible.
I know that no offense was intended in this comment, or in some of the other comments questioning my ability to use a caliper, and no offense was taken, but I have to stand up for myself at least a little bit lol. I recognize that my initial post was probably a bit too vague. But my measuring tools and ability to use them are fine - I'm using a digital caliper from harbor freight. It has crappy, soft plastic jaws, but it works. The reason I am unsure of the source of the measuring variance I've experienced is that the ends of the calipers are plastic, and burrs/imperfections/dirt in a tube can impact sizing by margins that we're talking about (tenths of a millimeter). It's possible for me to hold the calipers in certain ways in even non-damaged seat tubes and get different measurements, depending on the angle I'm holding, if a spec of hard grime gets in the way, etc etc. Go try to get different measurements on the inside of a tube an old, non-pristine bike - I'd be willing to bet if your digital calipers have plastic ends, you will be able to get slight variance. Using a caliper on the outside of a tube is simple. Using it on the inside of a tube, at least in my experience, creates room for error. My assumption is that my tube is ovalized, resulting in the variance, but because the variance is minimal enough to be invisible to the naked eye, I didn't want to claim to be certain.
I thought about getting or making this. A conical seat tube measuring post should work, but most of them are aluminum, and this would need to be hard steel. And I would worry that the same springback effect of a cold set would apply - To get it back to 27.2mm, I would actually need to stretch it beyond 27.2 to compensate for any springback. So just having a conical tube would not be as simple as it might seem (or at least I was assuming). I also would not want to DIY one myself by sanding down a larger tube - I do not have confidence that I could sand it to be perfectly spherical, which this tool should be.
While it's a decent/above average frame, I just want to put it on my indoor trainer. I am not trying to keep this as a show bike or anything. But in my opinion, trying to get it back to 27.2 instead of just sizing the post down is treating it like a good frame. If it was a trash frame, I probably would just put a smaller post in.
As to your method, with the dime/penny, it's actually the first idea I had, and is still my first option for an "easy" fix. My concern is twofold: This would stretch the tube out, but if it's ovalized, I don't know if it will regain its circularity with this method. It could theoretically get ovalized worse, and just happen to have a measurable point that gets to 27.2. My second concern is the binder and binder bolt threads. This method would put a decent amount of force on those threads. If, in doing this, I deform or break a thread, I will have a much larger problem on my hands than a slightly mis-sized seat tube.
Liked 3,940 Times
I look forward to reading of the progress and results. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 492 Post(s)
Liked 1,653 Times
My seat tube diameters at the top were 26.3 mm to the ears and 27.2 mm across the frame.
Tools; the cut aluminum pipe is key, the bore calipers are not.
When the ear slots were parallel, the seat tube was very close to 27.2 mm round. I stretched and measured 3 times to get it round.
The aluminum pipe on the ears side is about 2 mm above the beginning of the slot.
Just because I have them, I estimated the ID of this Vitus 971 to be 27.5 mm using the bore calipers.
27.2 it is and onto the next bit of surgery.
Liked 3,940 Times
"I know that no offense was intended in this comment, or in some of the other comments questioning my ability to use a caliper, and no offense was taken, but I have to stand up for myself at least a little bit lol. I recognize that my initial post was probably a bit too vague. But my measuring tools and ability to use them are fine - I'm using a digital caliper from harbor freight. It has crappy, soft plastic jaws, but it works. The reason I am unsure of the source of the measuring variance I've experienced is that the ends of the calipers are plastic, and burrs/imperfections/dirt in a tube can impact sizing by margins that we're talking about (tenths of a millimeter). It's possible for me to hold the calipers in certain ways in even non-damaged seat tubes and get different measurements, depending on the angle I'm holding, if a spec of hard grime gets in the way, etc etc. Go try to get different measurements on the inside of a tube an old, non-pristine bike - I'd be willing to bet if your digital calipers have plastic ends, you will be able to get slight variance. Using a caliper on the outside of a tube is simple. Using it on the inside of a tube, at least in my experience, creates room for error. My assumption is that my tube is ovalized, resulting in the variance, but because the variance is minimal enough to be invisible to the naked eye, I didn't want to claim to be certain."
I hope I didn't sound too condescending about caliper use. Given the state of a brazed and slotted tube end even a "best" caliper won't give you more than a good starting point. The 0.8mm (about 0.031") first referenced was a huge range, well past what I have seen for seat tube diameter ovalization. Well past what poor caliper construction or stiffness usually results in. I know of a few machinists that consider a caliper to really be an adjustable go/no go gage
The above statements you write I feel just prove my assertion why using a caliper to size a post with isn't always the final word.
As to making seat post insertion sizing pry bars- They already are out there, although not tapered. They are readily available long seat posts in a slightly smaller diameter then what currently fits. Cheap and long ATB ones (often only $10-$15 new, free if from tossed out stuff) have thick walls and the 350mm usual length is more than long enough to rework the top couple of inches of seat tube. Andy (who does own a set of lug and BB shell socket bending bars, made by Oasis Cycles)
AndrewRStewart
AndrewRStewart
