Does anyone know what the model of this wheel is and how to repair it?
Quoted: 2394 Post(s)
Liked 2,950 Times
not repairable Dead
Life is too short not to ride the best bike you have, as much as you can.
Quoted: 1111 Post(s)
Liked 1,050 Times
If those are cracks around 9 and 3, the simplest repair is a new wheel. Doubt there's anything special enough about the hub to worry about saving it and the cost of a replacement rim plus rebuild is probably the cost of a new wheel.
Quoted: 2625 Post(s)
Liked 3,174 Times
If you want an exact replacement, look on the Reynolds Wheels website.
Senior member
Quoted: 948 Post(s)
Liked 666 Times
What I get from the photo is one missing spoke and a broken rim. if the hub is in good shape, it can be rebuilt with a new rim, (any 50mm 24 hole rim does not have to be Reynolds).. It's the sort of job I do routinely.
Quoted: 5973 Post(s)
Liked 2,881 Times
You might get more specific answers if you offered details about what needs fixing.
All I see is a photo of a wheel, which may or may not be perfectly OK.
Likes For FBinNY:
Quoted: 574 Post(s)
Liked 615 Times
Cracks at 2:30 and 9:00 make it a very dead rim and at least one spoke gave up as well, probably can be rebuilt but not cheap, perhaps only hope is finding a good used replacement.
Agree with all above. Interesting failure mode; Usually rims fail by cracks at spoke hole. The cracks shown are in areas loaded in tension as the wheel rolls. The deep rim section makes it a lot stiffer in bending that way, and increases the tension loads on the inside diameter. (sometimes more flex actually reduces stress) So could be fatigue failure, or just pothole impact load, however given there are two cracks, I'm thinking fatigue. How many miles on the rim?
Liked 2,881 Times
Finally got a chance to look more closely at the photo. While I don't know what it implies, I find it very curious that the 2 "cracks" are just about 180 degrees apart, and perfectly straight and exactly radial. So I suspect something more closely related to how the rim was made than to some event later on.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
I find part failure cases interesting. My equivalent of reading mystery novels.
Join us in unraveling the enigma of a mysterious wheel! As we delve into the quest to identify its model and learn the art of repair, let's not forget the joys of Streaming Binge. In the midst of solving mechanical mysteries, take a break and indulge in a binge-watching session. Because every adventure needs a pause for entertainment, right? So, if you're intrigued by both wheel mechanics and the allure of streaming, this thread is the perfect pit stop for you. Let's spin tales and uncover knowledge together! 🎡🔧📺
Quoted: 564 Post(s)
Liked 504 Times
Likes For grumpus:
This is a BF pet peeve of mine. Someone posting a photo that is usually completely out of focus, at a strange angle, at not enough angles, and/or too small to be useful, and then asking a generic question.
Bikes: 1972 Motobecane Grand Record, 2022 Kona Dew+
Quoted: 168 Post(s)
Liked 153 Times
OP's fairly new, maybe's just curious or asking "for a friend" kinda thing.
I'd like to see a couple close-ups too of those cracks, and some taken of the other side where those cracks appear. Maybe the broken spoke's hole as well.
We often learn from others' mistakes after all, don't we?
Darned good question. If the cracks on this side were on the rim flange, it might be different on the other side. But since the crack is originating from the inner V of the rim where both sides converge, I think very likely the crack exists on both sides. However, if there were no cracks on the other side, that's important, as it may indicate lateral forces on the rim, either high magnitude and/or high occurance, instead of the crack being from radial forces. Like from using the wheel as fulcrum points to straighten a bent frame. (referencing another thread)
