Loose Super Record headset spacer
English threaded headset. All threading correct. All races installed properly. Top nut tops out on top of threaded steerer, leaving the tabbed spacer floating between top race and nut with a bit of play. Haven’t seen additional spacers before but is that what is needed? Thx
Quoted: 2347 Post(s)
Liked 5,241 Times
Yep, just needs a spacer. No big deal.
Steel is real...and comfy.
aged to perfection
Quoted: 856 Post(s)
Liked 1,289 Times
don't trim the fork. Add a thin headset spacer.
/markp
/markp
Edumacator
Quoted: 2526 Post(s)
Liked 3,346 Times
I’m in the two thin spacer group. On top and below one each. They will blend in the shadows. 1mm each.
If you ever need to replace the Campy headset, you might need the two mm in stack height.
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Likes For jdawginsc:
Half way there
Quoted: 990 Post(s)
Liked 885 Times
Put a spacer in. It will look just fine and no-one but you will notice.
Another thought: did you use the correct bearing balls. Some Campy headsets used 5/32" while some used 3/16". The smaller bearings would cause a gap like that.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3932 Post(s)
Liked 6,591 Times
Edumacator
Liked 3,346 Times
Found that out the hard way...
Bikes: Numerous
Quoted: 1680 Post(s)
Liked 3,158 Times
I have one Record headset using the fancy spacer and interestingly and annoyingly, when I cinch down the top nut, using a set of Campy wrenches, the wrench gets pinched and stuck so that I can’t remove it. With that experience, I would use an extra spacer before filing down the steerer.
Passista
Quoted: 886 Post(s)
Liked 749 Times
Super Record is top of the line and available. Why would you want to replace it with a different one?
Edumacator
Liked 3,346 Times
May not be at some point in the future. Or economically non feasible...?
Quoted: 419 Post(s)
Liked 985 Times
Maybe someone else will own the bike in its lifetime and want something else? Maybe OP will get bored and decide they want a purple anodized Chris King headset? I can think of plenty of reasons to not permanently alter a fork when there is such a simple alternative.
No issue putting in spacers but I've got 6 other NR / SR bikes restored and none needed them before - curious why this one has a longer-than-needed steerer.
Edumacator
Liked 3,346 Times
Whats the make? Maybe intended a particular other type of headset?
Quoted: 4556 Post(s)
Liked 6,513 Times
The chrome steel one in the middle with all the other pieces you already have.
It should be perfect once you add it.
Likes For merziac:
Edumacator
Liked 3,346 Times
Great eye!
Likes For kanawa:
Liked 6,513 Times
Technically you may not be.
No joke, the steerer on the blue one is a little longer so it needs more, chances are the green and white one could fit one too if you wanted.
Many are set up with one of each, the chrome steel one can be used to protect the fancy alloy one and or take up slack.
I would not cut or trim the steerer.
My example has one at the top and bottom for symmetry.
Liked 6,513 Times
Thx. In your examples I only see one steel spacer or no spacer. I thought on the SR headsets the fancy alloy one replaced the steel one. When they shipped SR new, only the fancy alloy one was included? Looking at NOS headsets that’s all that’s included.
Presumably if you needed to stack it out higher than that, it would be left for you or your shop to sort out(?).
Still puzzling out I’ve never seen both an alloy SR spacer and a steel one on the same stack and all my SR or NR bikes are set up with either 1 alloy or one steel spacer…
Thanks for all the guidance, community.
Likes For kanawa:
Quoted: 242 Post(s)
Liked 353 Times
I have a crazy question and please don't feel insulted; if these are caged bearings, are they oriented the right way?
