Just Bought a Brompton, Need advice on Mods
Old 08-06-07, 02:05 PM
android
Bikes: BikeE recumbent, Bridgestone MB
Hi,
Just bought a Brompton T-5, and I need advice from other owners what mods they would suggest. It's stock, with 18% gear reduction, otherwise standard. Brakes? Grips? What about handlebars? Seats? I'm curious if there is a cheap fix for the poor braking. Any advice would be greatly appreciated.
android is offline
Old 08-06-07, 02:10 PM
spambait11
Señor Mambo
Bikes: TST roadie, Cannondale CAAD 3, Surly Karate Stokemonkey Leap, Tern Cargo Node, Helix Alfine; 36er and 29er Triton Unicycles; a couple Bike Fridays; one Brompton; RadPower Radburro
Quoted: 54 Post(s)
Liked 28 Times in 12 Posts
Originally Posted by android
Hi,
Brooks saddle.
Brooks grips to match the saddle.
Kool Stop salmon brake pads (levers are optional).
A Nashbar or Wald cruiser bar that is not as upright as the stock M-type bar.
Schwalbe Marathon tires.
Longer bolts for the hinge clamps.
Extra spokes, just in case.
Front carrier block.
Open basket for front carrier block.
You're looking at a few hundred $$$ in enhancements.
spambait11 is offline
Old 08-06-07, 02:21 PM
delwong
I have a T-5 and an L-3 and here's what I've done:
1) Upgraded the brakes to the current generation design; and most important is to replace the Brompton pads with the grippier compound from Kool-Stop;
2) Replaced the brake calipers with Shimano R-440's to get a sleeker look and more efficient lever action;
3) Replaced the steel seat post with the titanium seatpost - nice weight saving;
4) Replace the seat with the Brompton (Fizik) Vitesse and added the Penta Clip.
5) Added the carrier block and purchased the basket as well as the S type bag for a range of toting options.
I've kept the handlebars stock.
What I'm contemplating doing but no time soon is:
A) Replace the cranks and bottom bracket;
B) Remove the generator and carrier - I don't use them enougfh for the weight penalty they cause
c) Add the Pantour suspension hub for the front wheel - but still collecting information.
delwong is offline
Old 08-06-07, 03:29 PM
14R
Bromptonaut
14R's Avatar
Bikes: 1994 Diamond Back Racing Prevail ti; Miyata 914, Miyata 1000, 2017 Van Nicholas Chinook
Quoted: 23 Post(s)
It all depends on what you want. I currently have my Brompton significantly heavier because I am using it daily without the need of folding or carrying it at all. Under this config., I have bar ends (that compromise the fold but gives me more cockpit room), Non-folding clipless pedals, front block with S-Type bag and fenders.
On August the 18th I will be traveling with the same bike: no fenders, no dar ends, no clipless pedals.
Now what I permanently changed:
Chainring, cranksets and BB;
carbon fiber bar;
salmon pads;
brake levers;
handgrips;
Extended seatpost, Thudbuster suspension and Specialized seat;
Upgraded rolling wheels.
What I am contemplating doing but no time soon is:
Add more gears (front derailleur with smaller ring);
buy a Brompton rear rack.
14R is offline
Old 08-06-07, 03:55 PM
pm124
Car free since 1995
pm124's Avatar
Bikes: M5 Carbon High Racer, Trek Emonda SL6
Quoted: 14 Post(s)
Liked 10 Times in 6 Posts
14R, why the dual suspension? What do you do for the front wheel?
Beautiful bike, by the way.
pm124 is offline
Old 08-06-07, 04:16 PM
14R
Bromptonaut
14R's Avatar
Quoted: 23 Post(s)
Thank you. I did nothing to the front wheel, basically because I am not aware of anything that can be done besides a front suspension mod from Japan( only thing I've seen is 1 picture), or the pantour hub which I read bad things about it.
But I wasn't happy with the standard elastomer as my only source of anti-bumping. I assume I ended up used to most of the vibration coming from the front, but my internal organs were really feeling when I would jump something and land seated. I guess the fact that I had a thudbuster laying arround didn't hurt either.
14R is offline
Old 08-06-07, 05:45 PM
donlab
donlab's Avatar
Bikes: BF Llama,Birdy,Xootr,R20,Moulton
Hi,
Were you the one who just bought 2 Brompton T5s for $1000 on Craigslist?
donlab is offline
Old 08-06-07, 06:12 PM
delwong
carbon fiber bar;
salmon pads;
brake levers;
handgrips;
Hi, what are the specs of the changed bottom bracket, chainring and cranks? I'm thinking of this mod in the near future as my OEM set up needs renewal. Much obliged.
delwong is offline
Old 08-06-07, 06:31 PM
14R
Bromptonaut
14R's Avatar
Quoted: 23 Post(s)
I got a TSA 53T chainring, cheapest road bike crankarm and BBs available at the LBS. Not sure about the brand of the bbs. For a while, I tought I had the original one from Brompton.
14R is offline
Old 08-06-07, 07:29 PM
LittlePixel
Raleigh20 PugFixie, Merc
LittlePixel's Avatar
Bikes: 1982 Raleigh Twenty Hotrod Fixie; 1984 Peugeot Premier Fixie, 2007 Merc Lightweight folder
Liked 4 Times in 4 Posts
[Coughs]... Pantour suspension hub?
All is needed is a tiny bit of filing (< 1mm) for it to fit in ze dropouts...
I know this 'cos I did it to the forks on my Brompton/Merc lightweight - (still to come out from garage as it awaits new rims and birdy rear elastomer)
LittlePixel is offline
Old 08-06-07, 07:52 PM
jur
Quoted: 321 Post(s)
Liked 7 Times in 6 Posts
*coughs* Did you miss 14R's comment about the Pantour hub...?
jur is offline
Old 08-06-07, 08:17 PM
SesameCrunch
Eschew Obfuscation
SesameCrunch's Avatar
Bikes: 2005 Fuji Professional, 2002 Lemond Zurich, Folders - Strida, Merc, Dahon, Downtube, Recumbent folder
Do you recall the size of the BB?
Also, in the picture of your bike, are the bar-ends pointed in towards you??
SesameCrunch is offline
Old 08-06-07, 08:49 PM
spambait11
Señor Mambo
Quoted: 54 Post(s)
The bottom bracket is rather long: 119mm for the L & T models, and 127mm for the C model.
165mm cranks are a good upgrade for this bike, as well as dual folding pedals, which 14R already mentioned.
Old 08-06-07, 09:01 PM
14R
Bromptonaut
14R's Avatar
Quoted: 23 Post(s)
I do not recall the size of the BB, but SB seems to know what he is talking about.
In the picture the bike is without the bar-ends.
14R is offline
Old 08-06-07, 09:02 PM
14R
Bromptonaut
14R's Avatar
Quoted: 23 Post(s)
LP: I heard these hubs have a very short lifespam.
14R is offline
Old 08-07-07, 01:28 AM
LittlePixel
Clearly I did for some reason; Sorry bout that. Hey - nice to see the bouncy pictures though eh?
Old 08-07-07, 08:24 AM
imosqueira
Hi,
What exact model from Kool Stop is people using? I need to order them through my LBS, and this is the first time they see aq brompton, so I need to give them the exact specification.
Thanks,
Iago
imosqueira is offline
Old 08-07-07, 08:27 AM
ICU Doc
Prodigal Son
Bikes: Cervelo R3, Cannondale CAAD10, Brompton
I will be picking up an S2L pretty soon....this thread is great. Is there any reason NOT to replace the stock axles with quick-release axles so that flats can be more quickly fixed?
ICU Doc is offline
Old 08-07-07, 11:08 AM
spambait11
Señor Mambo
Quoted: 54 Post(s)
I use Kool Stop Continentals: they're short, and made for road-type brake calipers. The caveat is that the threaded post is too long when folding, so you have to cut down this bolt, otherwise it will scratch up your frame. I got these pads on advice from Yahoo's Brompton list and was warned about having to cut down the threaded post ahead of time. Great pads, and tremendous stopping power - no joke.
An old poster, wavshrdr, said he successfully used v-brake type salmon pads. I'm not sure which model though.
Yes. You won't be able to keep the chain tensioner installed. If the chain tensioner is not installed, it won't take up chain slack when you fold the bike. Furthermore, since the hub gear relies on its specific axle, you won't be able to change gears.
For the front wheel, you'll need to get the correct size quick-release in 74mm or make your own. You might also have issues with the clip, the part that attaches the front wheel to the chainstay when folded.
If you're really worried about flats, just use Marathons and be done with it. You probably are not racing this bike anyway.
Old 08-07-07, 11:39 AM
folder fanatic
folder fanatic's Avatar
Liked 3 Times in 2 Posts
Hi,
My own Brompton C or Companion model was purchased new, no frills, very basic. I only needed to: change the stock brake pads to Kool Stops, rotate the brake levers a slight upwards postion as not to impede folding and vastly improve the leverage and reach of my smaller hands, change the stock shifter to a nice metal traditional Sturmey Archer shifter, add a Nirve cruiser saddle with springs for added suspenion, and a both bought and made a bag to take it around Southern Calfornia on buses and trains. I will add better Schwalbe Marathon tires, complete dual brake system with levers and all, and a luggage block with luggage options in the future when needed. So don't worry, there are plenty of rather inexpensive options available to you.
For photos, see my Flickr pages below:
folder fanatic is offline
