JTek shiftmate
JTek shiftmate
I'm thinking of putting 2009 Centaur shifters on my road bike, which has a Shimano-compatible wheelset. I was going to use a Centaur RD with an Ultegra cassette/chain and a JTek shiftmate #1 to alter the cable pull. When I spoke to a shop about this, they insisted that this would yield sub-standard performance (i.e., they just don't like the JTek device).
It was my impression that this worked -- does anyone have any direct experience?
Thanks,
Daniel
Thanks,
Daniel
Works fine for me. Veloce 9 speed shifters and deraillers shifting Shimano cassette. (Until I find a cheap Campy hub and cassette)
The JTek adjusts the cable pull perfectly...
Guest
Posts: n/a
Quoted: Post(s)
Thanks,
Daniel
Thanks,
Daniel
note - shifters are the key components here.
Should work. I'm using one with my Campy 10 shifters and derailer since I still have several 9 speed chains and cassettes I never got around to using.
Shops may be wary of using them if they have little experience with them.
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
use an sram RD with the campy shifter, it will index shimano cassettes perfectly.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Batüwü Creakcreak
Quoted: 230 Post(s)
Liked 289 Times
Ah, good idea AEO.
I have campy shifters and campy RD with shimano cassette, and it works fine with no shiftmate. Give it a try first. No issues swapping cassettes either.
Bikes: Trek 1000, two mtbs and working on a fixie for commuting.
I have heard the JTek works better than the conversion cassettes. And I think the sub-par performance is something that average rider would not feel.
Bikes: Diamondback centurion. Home built tandem
Liked 6 Times
I work at a shop, and I've personally got 3 on my own bikes. I've got nothing but good things to say about them.
Shiftmates work great.
BUT - I recently tried the rear wheel from my Campy equipped bike on my SRAM equipped bike, and other than adjusting the limit screws on the SRAM rear derailleur, the Campy wheel shifts perfectly.
That Campy wheel, of course - has a 10 speed Campy cassette on it.
So - you might want to give it a shot WITHOUT the shiftmate first....you might not need it.
Campy cog spacing is 4.15mm and Shimano SRAM is only 3.95mm. Even with careful centering, you'll have a positioning error of almost one millimeter or over 20% off location as both ends of the cassette.
The positioning error can be reduce by deliberately clamping the shift cable further away from the clamp bolt, to increase the lever arm length and reduce the travel.
I've done the opposite, grinding the clamp bolt threads down to the root to increase the actuation ratio to use a Campy 10 RD with 11 speed.
The Shiftmate works fine. I've heard it's better than a conversion cassette and it's definitely better than just trying to use the system with no pull ratio conversion. The only downside is it increases the cable friction a bit, but this shouldn't be a big deal now that they use actual bearings in the pulley rather than just a bushing.
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
Quick follow-up: I bought a set of Centaur ultra-shift derailleurs and a JTek #2 shiftmate, which are shifting an Ultegra RD and SRAM cassette (9sp). Works perfectly. It's even shifting my random old (late 80s) 105 front derailleur (nothing to do with the JTek, of course)...
Bikes: giant TCR campy-shimano mix/ Trek fuel 80/ Fuji track
10 speed campy shifters and 10 speed shimano everything else. Works 100%
Bikes: Litespeed Liege, Motorola Team Issue Eddy Mercxk, Santana Noventa Tandem, Fisher Supercaliber Mtn. Bike
Quoted: 14 Post(s)
Liked 11 Times
https://tour-de-france.velonews.com/article/73404
here is the pdf that explains how to mix and match, also include info on jtek
https://www.hearingoffice.com/downloa...ion_screen.pdf
