Learning bicycle mechanics
Quoted: 574 Post(s)
Liked 517 Times
That requires a basic understanding of physical principles that many people seem to lack - bits of geometry and Newtonian physics that make things "obvious" to some, and totally obscure to others.
For more advanced and proprietary stuff…
I believe Trek shop mechanics (probably not the guy that gets $15 to assemble an entry level bike, but a higher level wrench) will get factory training on how to service the isostrut on the supercaliber.
For us home wrenches, YouTube is a big resource. Having time and the courage to screw up something expensive also helps. 😀
In my neck of the woods, the chain shops may focus all their shock services in one location. No need for every location in a metro area to be experts on shock/fork service. That’s a good indicator (to me) that I don’t want to invest the time or tools to do that.
Quoted: 574 Post(s)
Liked 517 Times
I'm all self-taught, and I would recommend that for working on your own bikes, the plethora of helpful videos online helps, I would look on Park Tool first, and Youtube second.
If I were seeking a career as a bike mechanic, I would take formal courses, due to the *vastly* increased variety of designs and complexity, and I have a degree in engineering and 50 years experience working on my own bikes, but for new stuff, there is tons I don't know. I know there are schools available, a local bike shop mentions in their job postings, United Bicycle Institute, and Barnett Bicycle Institute as a basis, but they are only two-week courses and not required for an apprenticeship at their shop. Just off the top of my head I can think of very distinct segments:
- The basics: Bearings, brakes, cables, hydraulics, wheelbuilding and truing, tires tubed and tubeless, racks, accessories, fitting of rider, heavy-touring setup for stability, safety recommendations, and basic bike shop operations.
- Internal Gear Hubs and Pinion transmissions.
- Electric bike drivetrains and controls.
- Framebuilding and service, each type of frame a course in itself; Lugged and brazed steel, welded steel, welded aluminum, carbon-fiber-composite, welded titanium.
- Frame stripping and painting.
Wheel building and bike fit aren't basics, they're extra credit like IGH and e-bikes. Frame prep i.e. facing/reaming/tapping where necessary is a mechanic's job, but you'd hope the builder had done it - all other frame work belongs to framebuilders not mechanics. Except maybe finishing - you don't have to be a frame builder or mechanic to be a painter, and frame builders and mechanics don't need to be painters. Not sure about frame alignment, some mechanics do it but should we expect them to go beyond checking it?
Car engine basic service used to be simple, and heck, I was an engineer in industry. Now, I need the big manual or youtube to simply replace a distributor (and now all cars don't even have those), to find the hidden terminal to shunt the PCM to not advance timing so I can set "base" timing, and even to find the timing marks, they are that hidden. On the plus side, a new distributer with cap and rotor was $80 on amazon, versus $400 at the local auto parts store.
Quoted: 2409 Post(s)
Liked 3,007 Times
check to see if there is a park tool school near you https://www.parktool.com/en-us/park-tool-school
Life is too short not to ride the best bike you have, as much as you can.
