What's the popular opinion of riser stems?
climber has-been
Quoted: 3584 Post(s)
Liked 3,766 Times
After years of testing in wind tunnels and ergometers, people now know that lower is not always faster, and TT positions are now more upright than they used to be.
Supporting evidence: That 2012 Cervelo P2 in a 51 frame size had a 90mm head tube. The 2019 P2 had a 97mm head tube. The current P5 has a 101mm head tube.
Granted, 2 inches is a lot more than 11mm. But the important TT position is the height of the aero bars and elbow pads, not the "bull horn" bars that don't get that much use. Adding stack to aero bars is trivially easy.
Likes For terrymorse:
Quoted: 4882 Post(s)
Liked 4,048 Times
@VegasJen, my take? Fit rules. The job of a stem is to put the handlebars where you need them to support your body as it functions as an engine to drive the bike in a manner that is comfortable and as aero as you need to be. the great advantage of all the unusual shapes and sizes of stem (and seatposts) is that we can try all sorts of stuff to find "the fit". (Good thing - when you are there, you will know. You'll be doing rides at new speeds, feeling good and it's fun! This is assuming you are coming from a fit that wasn't there yet. If you are say a pro rider, burned out on a hard campaign, it may be that your body is just spent, even though you were riding that perfect fit. In that case, only rest works and possibly no bike ride will be fun.)
Jen, I recall you posting a while back of a ride or rides where you felt in the zone. Was that on this bike or a previous? Do you have records of the fit? That is what you want to document. And if the next bike requires a goofy stem to get it, well get used to looking goofy. Your body will thank you. And next bike, look for a frame that will put you there with a regular stem.
The other piece of the bike fit puzzle is bike handling. That is a matter of frame and steering geometry (stuff you cannot change) and the weight balance of you over the wheels. That weight balance is directly related to your fit for your best physical performance. I strongly advise against tailoring your fit to improve bike handling unless you have no choice but to ride that criterium on a bike that fits you poorly. Crashes cost too much!
Quoted: 574 Post(s)
Liked 615 Times
Jen as you say you ride tri bikes all the time I would agree with 79pmooney as handling is important. As I have aged and arthritis found me my speeds have dropped, I stay out of traffic and I avoid fast declines so ugly stems have not been a threat to my handling and allow for infrequent use of my recumbent trike.
Good, bad, indifferent?
Yesterday I picked up a 2012 Cervelo P2 for a steal. Well, not totally a steal. I did have to put a few hours into it to get it road ready. But I took it out today for a test ride. Rode 34 miles and honestly, by mile 15 I was almost ready to leave it by the side of the road. Everything about the bike is good, except for how aggressive the position is.
I ride tri bikes all the time, so I'm used to, and even prefer, the geometry of a typical tri bike. But this thing is so aggressive, it's literally painful. The steerer tube barely comes up to the lowest seat post height, which bends me over far more than I can hold for any length of time. But there's really no additional steerer tube to go up. All the stack is already used. And I can't go down any further on the seat post without hip angle issues.
So I need to go up about 2 inches, give or take, on my stack. I don't have any steerer tube left to go up, so my thinking is one of those jacked up stems at like 45*. I think that can get me another inch or so. Then I can take the elbow pads up with spacers to get me in a position I can hold for time. I certainly don't want one of those adjustable angle stems because they just look hinky to me. I'm not happy about it, but I think a fixed 45* stem could be a cheap solution to this problem.
Is there anything concerning about using a stem to get me up a little higher?
Back in the days of quill stems, I had a Look Ergostem. Anybody remember those? Double articulating stem that allowed a range of positions from extended gorilla to bolt upright. There wasn't anything like it.
It had a fair amount of flex, but it came in super handy when setting up a bike, almost like your own fit machine for bar position. I'd dial in fit on the Ergostem, then find a rigid stem with the same rise and extension or as close as possible.
These days, I use a Ritchey adjustable threadless stem the same way. Dial in the fit on the adjustable, then transfer that to a rigid stem, or as close as I can get with what's available.
This avoids a lot of the guesswork involved. Also, if you can't get a good fit even with an adjustable stem, chances are that's not the bike for you.
Quoted: 3261 Post(s)
Liked 2,581 Times
They're trending upward?
Likes For seypat:
climber has-been
Liked 3,766 Times
Method to My Madness
Quoted: 2068 Post(s)
Liked 1,561 Times
Steerer extensions, recalled
And it took a while… they recalled all the way back to 1998
If the stem riser shifts during use of a regular handlebar (either a drop bar or a flat bar), imagine how much worse it would fare with a TT bar mounted and more body weight on it.
Quoted: 7711 Post(s)
Liked 3,642 Times
Stem risers, riser bars, up-angled stem ... whatever it takes to make the bike rideable.
or, sell it. No other options that I can see.
As for popular opinion ... the opinion on function is important. The fact that a lot of people think only slammed, flat stems look good is irrelevant to me. What you think is your business.
Likes For Maelochs:
Quoted: 249 Post(s)
Liked 474 Times
If the only choice is to keep the bike and 'make it fit' then go ahead. Why would you care if someone else thinks it looks goofy? F em all, it's your bike and if it means you can ride it comfortably then that is all that matters.
But........on the other hand if you bought a bike that doesn't fit and is uncomfortable as you say you would probably be better off in the long run to sell it and buy a bike that works for you...you won't regret it and enjoy riding it much more than you seem to now.
But.......an alternative that might work would be an adjustable stem in place of a stem riser. There are a lot of good suggestions in the responses and hopefully you wind up with something that works.
Good luck and keep us informed...
Likes For Kai Winters:
Liked 3,642 Times
The issue I see is that this bike was a tri bike---and VegasJen does tri .... and it was exceptionally inexpensive. Selling it for very little and then trying to buy a bike which fits perfectly ... well, the options are to spend what it costs or to wait as long as it takes. What she has is what she has. if she can safely make it work to meet her needs ... there she is.
Clark W. Griswold
Quoted: 4505 Post(s)
Liked 4,190 Times
A stem with a higher angle is not a bad thing I use them and not qualms about using them but buying a bike that is an ill fit out of the gate probably either a good bike to strip and sell the frame or re-sell it and get a bike that fits better.
A good deal is not a good deal if the bike is not a good fit. I have seen plenty of bikes at decent prices but they are too big (usually) or too small and I just pass on them. But if just raising bars a little probably not terrible.
I would generally avoid the stem risers as many of them are not designed for carbon steerer tubes and that is a key to buying a stem. If the device you are putting on your steerer tube is not safe for your steerer tube you shouldn't use it.
My name is Jennifer and I am an addict. I buy **** I don't need. So for those of you wondering why I bought this bike, well, for one, I want to replace my older Ridley Cheetah, which has been a very good bike. But as some as you may recall, I endeavored to alter the geometry on that bike to sit farther forward. Additionally, that bike is a little heavier, being all aluminum. And lastly, it won't fit modern carbon wheels without modification because the frame can only accommodate about 23mm outer width rims.
In contrast, this Cervelo, can accommodate a wider carbon aero wheel and the seat post allows for a much farther forward position, which I prefer. Also, being a CF frame, it's marginally lighter than the Cheetah. Another advantage, which is almost worth what I gave for it, is it came with a set of Giant SLR tubeless ready wheels. And as anybody who has followed my adventures riding in rural Nevada may recall, I'm constantly battling various road hazards and have become a tubeless believer.
So, did I need it? No. I have my Shiv, which I absolutely love. But I want a second bike which I will set up primarily for hilly courses. This is the bike I intend to use for that purpose. If I get it sorted and I'm happy with it, the Cheetah will be rehomed.
Maybe. I mean, if I ran across a fork at a stupid good price, it might not. I do actually have a carbon fork/aluminum steerer tube sitting in my garage right now. I just don't want to use that because it doesn't match. But it's plenty long enough. Already have the part.
Of course, I can get a riser stem for <$50 and if that solves the issue, it's still a great deal.
It's a tri bike, so yes, aero bars. The reach is not the problem. I've compared this to another bike and almost everything is the same (or can be adjusted to the same), except the bar height.
The 2 inches is just a spit ball guess as what I need. But I think you're right about the geometry. It's very low in the front. I mean, the frame design is extremely similar to my Cheetah, the biggest difference is just the steerer tube on the Cheetah is about 2" longer. So I think this bike was originally more TT focused than triathlon focused.
And to those of you bashing for buying it despite this difference, I would argue this is something that is not so easily identified when just jumping on a bike and riding around a neighborhood for 10-15 minutes. But maybe I'm buying used bikes all wrong. Do you guys take a bike out for an hour or two before you make a deal?
I'm not being argumentative here but I am struggling to see the logic in how it puts any additional force on the steerer tube. I'm not looking for any more leverage. That I could understand. I just want to raise it up. Hell, since it's a tri bike, I could realistically leave the bullhorns exactly where they are and just raise the elbow pads. Pretty much every tri bike sold in the last 10 years has some kind of vertical adjustability in the aero postion.
Originally Posted by terrymorse
Not necessarily. That's a 2012 TT bike, made back when "get low to get fast" was the thing. It's likely an old-style geometry, with a dinky head tube.
Likes For VegasJen:
Cantilever believer
Quoted: 566 Post(s)
Liked 1,958 Times
The original position on my race bike wasn't as kind to me as the years rolled on, and I ended up putting a MTB-type riser quill stem on it (and bullhorn bars). No, it's not the original stem and bars, but it doesn't look horrible and the bike is much more comfortable. And if a bike isn't all that comfortable, it may not see many miles - or worse, create or aggravate an injury.
Expired Member
Quoted: 3797 Post(s)
Liked 5,795 Times
Likes For shelbyfv:
hello
Quoted: 1637 Post(s)
Liked 2,733 Times
Picture always helps. When you say rise you mean angle and not an extension, correct?
Bikes: A Blue One and 2 Green One's, then there's the Yellow one. And oh, yeah, a Black One. Did I mention the Red One?
Quoted: 78 Post(s)
Liked 197 Times
Popular opinion is the ruin of our souls.
Look-up a guy named Moulton.
People have different length torso's, arms and legs.
Find a bike you like and make it fit if you want to, so what?
If money is your concern that's a different issue.
Bikes: Subject to change at any given moment but currently is...... Colnago Mapei, Colnago C40, Wilier Triestina Carbon, Wilier Triestina Ramato, Follis 472, Peugeot PX60, Razesa, Orbea Terra, Soma Pescadero and 1/2 owner of a Santana tandem.
Quoted: 341 Post(s)
Liked 787 Times
In addition to stems there are gull wing style riser handlebars that achieve the same thing. A bit more expensive proposition but they offer a comfortable flat section that is nice on long rides.
Liked 1,561 Times
That would be the Specialized Hover Bar. I got one (~ $40) and they make a big difference. Once you get over the 'wonder what the bike studs think' the riser bars are great. Not all of us can be as flexible as those more fortunate riders, and riser stems and bars can really make the difference. The steerer tube extenders that insert into a 1" tube and convert to a 31+mm stem stud are a help to get more modern bars/stems on older bikes. Just BE SURE that the cinch bolt/wedge is BELOW the threaded portion of the steerer - else you can crack the threads, and let evil leak out.
Likes For NVFlinch:
Advanced Slacker
Quoted: 2769 Post(s)
Liked 2,546 Times
If the riser stem gives you a fit you like, there is no reason not to use one and no reason to get a different bike.
If you want to maintain the same reach you will need to get a longer stem length.
Rider. Wanderer. Creator.
Bikes: Bike Friday Pocket Rocket, Cinelli Hobootleg, Zizzo Liberte
Quoted: 425 Post(s)
Liked 889 Times
Related...
Analyzing the Bike Positions of Top Pro Triathletes
https://www.triathlete.com/gear/bike...o-triathletes/
The variety of positions is kind of cray
climber has-been
Liked 3,766 Times
Related...
"Not only can Sanders maintain this position, but he can also maintain more power (330–350 W) for 2–4 hours at a time than most anyone."
That 350 W at his weight (72 kg) is ~4.9 W/kg. The 90th percentile for pro cyclists at 4 hours is reported to be only 4.6 W/kg. And they don't have to swim before or run after.
Dang!
OM boy
Bikes: a bunch
Quoted: 556 Post(s)
Liked 719 Times
Bar height... reach and rise affect that
on a bike you're already riding and feel 'accustomed to', measure from the saddle nose to where the bar is clamped to the stem - that's your current reach (not really... but it works most of the time...)
now check the new bike, same measure (once you have the saddle positioned)
measure or find the stem length that would get you to the same 'reach' number as your current bike.
Get a cheap adjustable stem - amazon or similar - a bit longer (1 cm...) than the stem you would need to get the same reach, on the new bike...
Why Longer? Because as you adjust the stem upward, it becomes shorter , down becomes 'longer'... Perfect? No, Life and cycling are not perfect.
Position the adjustable stem to the same 'saddle/bar drop' as your current bike - the vertical distance of top of saddle to top of bar... go ride for some days.... find some 'measure' of how you do - performance wise...
then re-adjust the stem downward for a further drop of 1/2cm / 5mm, go ride for a few days, then do the same, exact performance test as before
Repeat everything...
Until you find a good point of 'performance' and 'comfort' (your decision on weight of each aspect).
Once you think you have that optimum point (for the time being) - you can get a fixed stem to mimic that setting - or just continue to use the adjustable...
Ride On
Yuri
