Lever vs allen bolt thru axles
Bikes: '23 Devinci Hatchet Carbon Apex1 '19 Norco Bigfoot 6.1 ,'12 Motobecane Turino (killed by dog crash), '12 Trek 3700 Disc
Quoted: 149 Post(s)
Liked 128 Times
My new bike is the only one I've ever had with TA.
The TAs have handles that pull out from inside the TAs so they look clean with no protruding handles while not requiring any tools to remove/install.
Can't say I have a preference as these are the only ones I've ever had and haven't even used them yet. lol
One weird thing is that my forks have a "blind hole" on the drive side - from the drive side there is no visible axle component.
Quoted: 7139 Post(s)
Liked 11,315 Times
It would be funny if it weren't so sad: for decades bikes have had q/r front and rear, and tire removal/re-installation was a no brainer. You are seriously telling me that in the 21st Century, cyclists once again need a (allen) wrench to remove wheels, like in the (bad) old days of threaded axles? Just say it ain't so!
Likes For Koyote:
Over the hill
Quoted: 1017 Post(s)
Liked 1,255 Times
Sounds like the TA still provided the bigger weight savings.
It's like riding a bicycle
Quoted: 6352 Post(s)
Liked 4,955 Times
I thought I'd miss the old quick release skewer's we had before thru-axles. My last new bike came with just a plain thru-axle that you have to use a allen key. Prior to purchasing it I thought for certain I wanted to get one of the thru-axles with the lever. However 3 years later I just simply have not ever been inconvenienced by not having QR's or a thru-axle with a lever. It's too quick and easy to to get the hex key from my bike bag under the seat or out of the tool box drawer when in the shop(garage).
And aesthetically the looks are more pleasing without the lever.
Likes For Iride01:
Habitual User
Quoted: 5095 Post(s)
Liked 8,404 Times
I want to find a different solution for the lever TAs on my gravel bike. On the opposite end of the lever, there is a knob for adjusting the clamping tension. It works great, and I like having the lever for efficient removal and reinstallation. However, the internal mechanical parts rattle, and it's annoying.
On this bike, I would prefer to stick with a lever on the front. Maybe at both ends. Recommendations?
Liked 11,315 Times
Likes For Koyote:
Quoted: 1454 Post(s)
Liked 2,056 Times
Originally Posted by Eric F
Recommendations?
DT RWS thru axle ?
more an option than recommendation - because I have not used the RWS axle for thru axles ... (I have used the DT RWS skewers however)
Recommendations?
DT RWS thru axle ?
Likes For t2p:
Quoted: 1158 Post(s)
Liked 1,267 Times
There are (were?) issues with QR and discs, where, as I understand it, the contact point of the braking on the disc could cause the axle to loosen or even eject from the dropout. Partially from the forces from the brakes near the axle as opposed to the rim, and partially from the QRs not being strong enough or applied strong enough. That's just what I've read; no personal experience except with more current disc/QR designs ...
Hmmm, seems more like user error, to me. We (my wife and I) have been riding a tandem with disks and QR axles for about 10 years, and I have the front wheel on and off frequently to get it on the rack. I've never had a problem with the axle loosening under braking. The dropouts are standard vertical, not the forward facing ones (front).
However, I am looking forward to my new (single) bike, which will have disk brakes and a through axle, because I have noticed a little bit of fork flex/chatter during braking on the tandem. (It's noticeable, but not annoying and certainly not dangerous.) Suppo're sedly one of the advantages of the through axle set-up is that it reduces/eliminates fork flex under braking.
I bought my first new bike since 1987 5 years ago. My first one with QR axles and seat post. My first thought was that makes too easy to steal the wheels (especially the front) and the seat. Since I don't take off my seat or adjust it often the dealer installed a bolt clamp.
Once I understood how to tighten these QR axles I'm quite content with them. And I do lock the bike and front wheel sometimes. But i do wonder how strong they are. 5 mm isn't much steel .
Habitual User
Liked 8,404 Times
Likes For Eric F:
Liked 1,267 Times
Likes For Camilo:
Over the hill
Liked 1,255 Times
And that's the one thins making me consider replacing the lever ones instead, although I can't tell exactly what size I need (I know I have 12x100 and 12x142, but they seem to vary in overall length and thread length). I could probably just measure mine, but that would require, you know, effort.
Quoted: 4322 Post(s)
Liked 1,400 Times
Likes For njkayaker:
I thought the QR skewers where under a lot of stress. I never paid much attention to them, But just Googled them for a more detailed look. I understand more about them now and feel more comfortable with them. Thanks.
Also most the stress on the axle is on the outside, So with a sufficient wall thickness little strength is lost if we bore a small hole in the center for the skewer.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 276 Post(s)
Liked 461 Times
I have to admit I have two for my Domane. I screwed up the threads on the the rear thru-axle the first week. The axle still worked but I could feel the messed up threads. I panicked and bought a new thru-axle from Trek which came with a handle/lever.
I just noticed I don't see the icon to insert emojis in the computer browser like on the phone browser.
Liked 2,056 Times
That's pretty much how I feel. It just wasn't enough of an issue to go out and buy new ones.
of course - always a good idea to pull the axle and determine if the specs are printed on the axle
(gotta be diligent - some bikes use different thread / pitch on front and rear ... i.e. 1.5 thread on front, 1.0 thread on rear)
Likes For t2p:
Liked 3,130 Times
Clean looks good imo. I would like to have a TA, seat post hardware, stem cap bolt, & stem bracket bolts to use the same size allen key.
that's asking too much.
-Oh Hey!
-Oh Hey!
Quoted: 4605 Post(s)
Liked 5,144 Times
They are different sized threads and therefore different fastening torque. A 4 mm Allen key for a TA is too small and would risk rounding off at the correct torque.
Liked 3,130 Times
it wouldn't "round" out if the depth was far enough for the key to go into the head for the aforementioned hardware. Also, the torque values are not thar extreme in the grand scheme of things.
-Oh Hey!
-Oh Hey!
Bikes: '87-ish Pinarello Montello; '89 Nishiki Ariel; '85 Raleigh Wyoming, '16 Wabi Special, '16 Wabi Classic, '14 Kona Cinder Cone, 2023 Surly Disk Trucker
Quoted: 708 Post(s)
Liked 415 Times
I have LAD's ("Leverage Application Devices") on my Surly Disc Trucker. I like them because I can do an easy quick-check on tightness before each ride.
Likes For mattcalifornia:
Randomhead
Liked 3,796 Times
All the TA bikes I have with QR-style cams are really awkward to actuate. There is always some trick required to unthread them. I fail to fully understand why making it more difficult makes it safer, I think the opposite is true. It seems like on production bike TA's with a hex head are winning. I always carry a multi-tool in the same bag as the tube, so it's no big deal. And with tubeless, flats are a lot less frequent.
Likes For unterhausen:
Liked 5,144 Times
I get the availability of why, but it would require an engineer to hybrid hardware thread designs to match a single head key size.
Liked 3,130 Times
make it all 6mm then, it doesn't matter as long as they're accepting the same key head.
-Oh Hey!
-Oh Hey!
