Wanted - New Hole In The Head
Klaatu..Verata..Necktie?
Quoted: 10632 Post(s)
Liked 12,255 Times
If I don't, I'll just blame you!
I'm currently haunting FedEx tracking while the frame makes its way to me, and of course thinking about any parts I'll need that I don't already have.
Likes For genejockey:
Quoted: 3641 Post(s)
Liked 3,078 Times
Liked 12,255 Times
To be fair, though, Giovanni Battaglin won the 1981 Giro with a triple.
Liked 3,078 Times
Likes For smd4:
Liked 12,255 Times
Liked 3,078 Times
Liked 12,255 Times
Liked 12,255 Times
I love the minutiae of a new project, like just last night I discovered that LeMond 853 frames have 31.8mm OD seat tubes and no FD braze-ons, and Shimano didn't make the FD-7410 in 31.8mm clamp-on. I thought about buying a 31.8mm FD-7700, but didn't. Then I thought, "Maybe Shimano made an adapter that will let me use the braze-on FD-7410 I bought for the Litespeed's second iteration?" and sure enough, they do.
Problem solved!
On to the next - what size stem will I need? Should I use the Cinelli Nerve bars I took off the Battaglin when switched to Soma Highway Ones? Or go with Highway Ones? What model stem? LeMonds came with Cinelli XE, which AFAICT is the same as the XA. If I go for the Nerve bars, I should go with a Cinelli stem, surely!
Problem solved!
Crawlin' up, flyin' down
Quoted: 1062 Post(s)
Liked 2,632 Times
genejockey: If you are really looking for a hole in the head, I'd be happy to bring a cordless drill to the next Peninsula Ride. Jus. sayin' . . . .
Liked 12,255 Times
Bikes: Columbine, Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Quoted: 247 Post(s)
Liked 165 Times
Pics please
Cheers, Mike
Cheers, Mike
Likes For PromptCritical:
Liked 12,255 Times
Every build prior to this one, if I was changing the headset and/or BB, I'd take it to my LBS, where they have the right tools. But this time, I'm thinking maybe I'll get the tools and do it myself. The BB is a Shimano Ultegra cartridge unit, and I'll be replacing it with a Dura Ace cartridge unit, so removal and install both require the same tool. For the headset, the removal tool is universal, as is the headset press. So, do I trust the Cheap-And-Cheerful ZTTO headset press?
Decisions, decisions!
Liked 2,632 Times
Do you want pics of the frame/bike, or pics of the new hole in genejockey' head? Either one, or even both, is fine with me.
Likes For bikingshearer:
Liked 2,632 Times
The universal headset race removal tool is a godsend. Using a hammer and screwdriver is suboptimal at best.
As for how I know about the "hammer and a block of wood" and "hammer and screwdriver" methods, all I can say is we were all cash-strapped teenagers once upon a time.
Liked 3,078 Times
Liked 12,255 Times
For installing the headset, considering one can get the job done with a hammer and a block of wood (not that I'd recommend that method), I think you can trust the ZTTO press on a steel frame. I have an ancient VAR press and have managed to not muck things up using it, so you certainly have the ability. Heck, you could probably fashion an acceptable if kludgy headset press from items found in the nuts & bolts section of any hardware store. Rocket science it ain't. (On a CF frame, however, all bets are off and I would want the pros from Dover to do it.)
Quoted: 247 Post(s)
Liked 165 Times
Cheers, Mike
Cheers, Mike
Liked 12,255 Times
FedEx tracking is maddeningly nonspecific. The frame left Ohio 4 days ago, and nothing since. I just have to trust that it really will arrive tomorrow between 11:30 and 3:30. By comparison, USPS tracking practically lets you know when the driver stops to pee.
Liked 12,255 Times
So, for the headset, I'll need:
1) Something to remove the fork crown race
2) Something to remove the top race and bottom cup from the head tube
3) Something to install the new crown race.
4) Something to install the new top race and bottom cup.
For the bottom bracket, I'll need:2) Something to remove the top race and bottom cup from the head tube
1) A Shimano cartridge BB tool
2) A nice long crescent wrench. This is the one tool I have.
Quoted: 1009 Post(s)
Liked 1,694 Times
Liked 3,078 Times
Liked 12,255 Times
As it turned out, I went a different direction on the frameset, so I can now reveal that what I HAD been thinking of was a Moser Leader AX. Silver fillet brazed, no lugs, no seatpost clamp - it uses a quill seatpost. I couldn't get one in the form I wanted it without either spending a ton to strip and repaint a naked frame, or get a complete bike with an entire groupset I don't want, and which would duplicate a lot of parts I already have and have no use for.
Which reminds me - Anyone in the market for a mid-90s Chorus/Racing T 8-speed groupset?
Liked 12,255 Times
I figured. I did want to make the list so I wouldn't get part way through a headset swap and say, "Oh, crap! I need (insert tool name here)!!"
Quoted: 247 Post(s)
Liked 165 Times
Uhhhh, not a fan of USPS, even though their tracking reports are more frequent. I recently had an order go missing (on its way to San Diego from Portland) and USPS couldn't find it or report anything about for two weeks. A couple of years ago, my daughter sent me thank you letter and it took 11 weeks to make its way across San Diego......
I do wish UPS and FedEx provided more info. Since I have a similar problem with bikes, I get a lot of shipments, and it would be nice to know who the shipper is. I don't mind not being home if something small and inexpensive is going to arrive, but really want to be home for expensive stuff.
Cheers, Mike
Cheers, Mike
Liked 12,255 Times
