My new 2024 Domane SL 5 is .95# heavier than it should be.
OM boy
Bikes: a bunch
Quoted: 545 Post(s)
Liked 688 Times
A lb seems like a lot, considering that not only is a 50cm frame smaller than the 56cm reference, but it also has 4cm narrower handlebars, 2cm shorter stem and a 4cm shorter seatpost. Interestingly though the 50cm comes with a wider saddle (155mm vs 145mm).
I know you have tubeless tires, but to confirm, the bike is setup tubeless and doesn't have tubes installed? Are there any tools included/not included in the in-frame compartment?
Ride On
Yuri
Quoted: 6326 Post(s)
Liked 4,915 Times
The listed weight for the bike is without the pedals. And it's just a there about weight and not a precise weight.
Perhaps for bikes that come from the factory with pedals that are included in the specifications for the bike, then the weight might include them. But I've not seen spec's for a Domane that included pedals.
Advocatus Diaboli
Quoted: 4761 Post(s)
Liked 1,542 Times
This is a joke right? A manufacturer builds bikes in a factory overseas and the weight is possibly slightly off but it wasn't measured by Trek for you and then the time it was measured was with un-measured pedals and tubeless tires that also probably has unmeasured sealant, valves and rim tape? Why do people buy these bikes then care about weight that may or may not be off.
If you care seriously about a lightweight bike, a bike listed at 19lbs would be heavy and you would build your own and make it light.
A Domane SLR frameset only supposedly saves 1/2 lb over the OP's Domane SL frameset. The premium for the SLR frameset is $1700 over the cost of the SL. If he had instead purchased an SLR bike and it actually weighed 1/2lb over what an SL bike would have supposedly weighed, you might be a bit upset about not understanding what your $1700 actually bought you.
Bikes: Columbine, Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Quoted: 190 Post(s)
Liked 110 Times
If you’re concerned, send an email to the Trek CEO. He is very responsive.
Cheers, Mike
Cheers, Mike
Clark W. Griswold
Quoted: 4451 Post(s)
Liked 4,112 Times
My take on the OP's question was his suprise, given the published approx weight by the Manufacturer, that a lb.+ is a significant deviation from what was published. Especially given his smaller sized frame/bike. All the components are a know quantity, quality frame should also not have much deviation, so a lb+ is a lot.
My post was mainly to 'confirm' that what he found was probably 'reality', not a major anomaly in just his bike.
In my case, I bought the bike fully knowing what I was getting, and not expecting more. Also fully expecting to be making some changes. Having ridden 'THIS' bike before committing to purchase.
Not unhappy with the bikes I currently ride a lot. If I can make this new bike feel as 'nice' as those - great! AND fully intending to make changes, upgrades if that fits, to see what might have a significant effect on 'ride', and see if 'weight' also is part of the story. It's an experiment...
If I can bring it to level of my current road bikes, which are all 10 yrs old or older, then Great ! If not, I'll sell it for whatever it might go for... No issues, no problem.
It's not the money, I have a bunch of fun learning what this experiment might teach me.
If I had spent 4 times what this bike cost me, I'd have very, very high expectations, and hopefully, mostly have them met... My expected changes will cost about half again of the bike cost, which would still be considered a bargain compared to the price of a similarly fitted 'Off the Shelf' bike cost.
I think most knowing riders also know that 'weight' isn;t everything, but it is a 'thing'.... So for a bike with $3400 MSRP, one might expect it to be in the 'light' road bike category... 21+ lbs is not that, compared to the similar bike, 19ish lb, of 8-10 yrs ago which prolly sold for $2K-$2.2K.
SO, with this thread a lot of questions get asked, some answers might be found, some not.
And, it also addresses expectations, so met, some not even close.
So, if one has expectations to be able to get a 'light bike from TREK (and other bike makes?), well under 20 lbs, it might not be met by even a $5k bike... ?
For some this might be an important consideration.
Ride On
Yuri
and , yes, I prefer my 2014 Tarmac well over any of my old gaspipe, and many of the 'great' newer bikes I've had some opportune miles to log a few miles on...
Not a plug for Spec or Tarmac, it's just a bike I like a lot. But had the experiment be able to be done with an ORBEA, WILLIER, CERVELO or RIDLEY, instead of a TREK, I would have quickly jumped on that.
Ride On
Yuri
Think of it this way perhaps with a slightly different scenario.
ignominious poltroon
Quoted: 2280 Post(s)
Liked 3,503 Times
Likes For Polaris OBark:
Quoted: 2577 Post(s)
Liked 3,081 Times
If shipping that and other high-end Trek models with tubes in the tires is standard policy, Trek could have saved themselves some future grief by specifying that the weights are fairly accurate for the bikes when they're run tubeless but that they're supplied with tubes in place, to avoid problems with, e.g., sealant pooling at the bottom of the tires while the bikes are in storage.
Bikes: SL8 Pro, TCR beater
Quoted: 1019 Post(s)
Liked 593 Times
Likes For eduskator:
Liked 3,503 Times
It is worth keeping this in perspective. A liter of water weighs about 2.2 lbs.
That is without bottles and cages.
I've never owned a bike lighter than 20 lbs.
I've never weighed less than 180 lbs in my adult life.
Quoted: 7087 Post(s)
Liked 11,203 Times
'Course, I get that he's upset that the promise is not reality. But that's usually how life works, right?
Mostly Harmless
I had to convert: 0.95lbs is 430 grams.
Maybe your pedals are heavier than you think? Did it have bottle cages attached? A computer mount? Maybe they added a lot of extra sealant? Difference in scale accuracy?
Could be many reasons, or simply Trek being optimistic in their advertised weight. Who knows.
Buy it. Ride it. Enjoy.
Mostly Harmless
I'm betting it's a combination of the variation in frame/bike weight and the inaccuracy of the scale. The Park scale is a glorified fish scale - the fact that the readout is digital has nothing to do with the accuracy of the spring system that's registering the weight.
While I understand that the importance of bike weight is somewhat overblown, bikes have definitely become porky - we're looking at 20-21lb as nothing unusual for a CF frame with decent bits - yikes
Likes For Tony_G:
Mostly Harmless
Mostly Harmless
Likes For Tony_G:
Quoted: 4548 Post(s)
Liked 5,060 Times
Bodyweight also naturally varies by 2-4 lbs over the course of a day.
Mostly Harmless
A pound difference is enormous.
Weight will vary from a bike to another as a result of manufacturing discrepancies in framesets and parts/components, but 1 pound is a lot. I mean, people will pay 5000$ more for a bike just to shave 1 pound out of the total weight.
The advertised weight for most manufacturers is for 56cm framesets so you're right saying that your 50cm should weigh less. For instance, my 2024 SL8 Pro in size 58cm came up at 7.3kg on the LBS' park tool scale. Its advertised weight is 7.16kg (size 56cm). I don't mind the 140g difference given that it's a size bigger.
Are you 100% sure that your scale is accurate? Have you tested it with other items to which you know the exact weight?
I’m not pleased about the extra weight but I am not greatly worried about it either. That’s why I came here to ask the forum, is it typical or is it outside of the normal range?
Liked 3,081 Times
It isn’t my scale. It is the bike shop’s scale. If it is reading heavy, I would think that it would be in their own interest to replace it.
Liked 3,503 Times
My guess is the shop's scale is accurate.
At some point the marketing becomes misrepresentation.
At a more extreme point, it becomes a form of consumer fraud.
Giant seems to be a bit more cautious in this regard:
Mostly Harmless
About the wider saddle I did notice that. It might be that they sell more 50’s and smaller to women than men (as also noted in this thread by cyclezen).
Advocatus Diaboli
Liked 1,542 Times
For perspective, Trek charges about $2k for every 1lb reduction you want off of their frame weights
Quoted: 7675 Post(s)
Liked 3,563 Times
I have no idea whether most bikes weigh near, more, or less than listed weights. No one really does, because none of us weight a dozen or two bikes in each frame size to know.
Liked 5,060 Times
The weight saving aspect of this cost is poor value, but you generally get a higher quality build ie higher level groupset, nicer wheels etc. it’s not only about the weight.
Advocatus Diaboli
Liked 1,542 Times
Liked 3,082 Times
waxed chain or caked with teh greaseys? Grease can get heavy.
-Oh Hey!
-Oh Hey!
Liked 5,060 Times
