Confusion about tire TALLNESS
Quoted: 518 Post(s)
Liked 660 Times
This makes no sense. The only thing a tire could do to make it "low profile" would be to thin the tread at the center of the tire, and even that would have very little influence on the height of the tire.
Likes For KerryIrons:
working on my sandal tan
Quoted: 3873 Post(s)
Liked 2,574 Times
First a correction… the tires on THIS Miyata are 700 x 23c, Michelin hi-lite supercomp. So even narrower than its spec sheet.
I did not use calipers, but simply eyeballing the rims —and dimensions look very close, The stock Fuji tires on stock Fuji rims overhang (fatness) as much as when I installed the Fuji tires on Miyata rims. It’s JUST the Miyata brake calipers that rub those tires when inflated — maybe 2mm is all I need. The Miyata frame will otherwise easily fit quite a wide variety of “fat” 700c tires.
All that said, and actually riding the 512 today, I might be okay with very good low profiles as the Michelins are not as hard as I assumed.
Something soft and quiet.
Likes For ThermionicScott:
Bikes: Gary Fisher Advance (1993, heavily modded); Fuji Absolute 2.0 (2010; modded); 1989 Miyata 512 (58cm; $50, thrift buy); KHS Classic (63cm, 12-spd); Schwinn World Sport (58cm); Schwinn Voyageur (58cm); 1987 Centurion Ironman (60cm)
Quoted: 190 Post(s)
Liked 41 Times
Just checked ... the stock tires on the Fuji are Kenda 700c x 28c. Made in China.
The Fuji accumulated only 400 miles or so July 2010- May 2020. And the front Kenda develped some sort of dry-rot crack. Replaced with 700c x 32c Continental Ride Tour.
Been riding Fuji much more these past few years, Maybe 1000 miles/year. With just gentle road use and backpack. The Conti's are holding up very well. I have used Conti's on my Gary Fisher commuter, 26" x 1.75". The quality/durability of Conti has sunk somewhat over the past few decades.
But I may still opt for, say, Continental Ultra Sport III 700x23 at $55/pair/delivered, for the Miyata. Unless someone can suggest a "better" alternative for similar $. The tire does not have to perform. But it should be quiet and comfortable and have good traction for safety.
I don't ride hard or fast and stick to smooth roads and dedicated paths.
Expired Member
Quoted: 3797 Post(s)
Liked 5,795 Times
Likes For shelbyfv:
Quoted: 6353 Post(s)
Liked 4,956 Times
However I've since found that the extra money for the better tires more than makes up for the price with their better ride, better rolling resistance and better grip.
Likes For Iride01:
Expired Member
Liked 5,795 Times
I agree. They are better than tires of yore but not much to recommend them, other than initial low cost. And that's not saying they are better or worse than other cheap tires.
Quoted: 4882 Post(s)
Liked 4,048 Times
I have learned time and time again that eyeballing things is far from accurate. Different shades of color, shadows, shapes, forced perspective, etc. can trick the eye.
That's not actually a small amount considering what you're asking. The typical rubber of the tread on a tire is probably about 2mm thick, so shaving the tire down would not help. Might be able to shave off 2mm from the underside of the caliper, but I would consider that a risky move. You could possibly change to a caliper with more clearance.
Likes For 79pmooney:
Quoted: 190 Post(s)
Liked 41 Times
Using my trusty old analog :slide-rule: type calipers, I measured the OD of Fuji rims to be 1mm more wider than originals. Didn't remove the tire so no clue about ID or vertical dimensions. I did notice that initially inflating the tire, the seat was variable; caused by missing chunks of tube liner. Temporarily, I'm only using two layers 3M magic [Super Hold] Scotch tape as I did not have any liners in the house.
climber has-been
Quoted: 3584 Post(s)
Liked 3,766 Times
Using my trusty old analog :slide-rule: type calipers, I measured the OD of Fuji rims to be 1mm more wider than originals. Didn't remove the tire so no clue about ID or vertical dimensions. I did notice that initially inflating the tire, the seat was variable; caused my missing chunks of tube liner. Temporarily, I'm only using two layers 3M magic Scotch tape as I did not have any liners in the house.
Duct tape would have been better. Or even reinforced strapping tape.
Likes For terrymorse:
Liked 2,574 Times
Clark W. Griswold
Quoted: 4505 Post(s)
Liked 4,190 Times
The Scotch tape thing would be something I would do in an emergency not at home where I have more options or ability to go out. I would use the scotch tape if I was on the road and somehow the gas station only had that and no rubber strips or candy bars or duct tape or anything else and there was no other shops for miles of any kind. Maybe I would use some ClifBar or candy bar wrappers with some Scotch tape to hold them together or something like that but I would have just said screw it and cut up an old tube and that would get me going.
Likes For veganbikes:
IME it is a trial and error thing. In the past, I have noted that Conti 4000 and 5000 had different width and height with the same labeled size. Others have noted this as well.
So, either buy what you already know works, or go to your LBS and have them install your new tires. If they don't fit, they'll drop down a size and out you go.
the problem with that is that low-profile car tires are augmented by active suspension. For most road bikes, that ~1” of air between the tread and the rim is your only suspension element. You need that height to avoid destroying your rim and/or rattling your teeth out of your head
Small thing, just for clarity. Most cars have simply "suspension", or more accurately "passive suspension". "Active" suspension is where the engine or an electric motor drive a hydraulic pump that inputs hydraulic pressure to the dampers to counteract vehicle body or suspension motion. They have also done this experimentally with electromagnetic servos instead of hydraulics. Both take energy, with a consequence in fuel consumption. "Semi active" suspension does not input energy to the dampers, but uses a small amount of electric power to control the damper valving to achieve much of the same goals as "full-active", but at far less energy cost. For example, if a vehicle corners hard and the body leans, active dampers correct that lean. With semi active, the computer senses a rapid change in the steering wheel position sensor and/or yaw sensor, and closes the damper valving to impede body rolling before it occurs. A different approach still, is the mechanically-active damper; Instead of hydraulic energy input, the damper has a self-contained mechanism that harnesses the kinetic energy of the suspension and body movement and converts that to hydraulic fluid pressure, and uses this to provide suspension/body "leveling" at zero fuel cost, for load-leveling in pitch, or leveling in roll, as the damper cannot tell which is off, it only knows that position is not correct and adjusts to desired design height.
Oh no worries. I was a specialist in the area. I was asked about the above in my job interview fresh out of university, aced it. No other candidates. Was not taught in school. I picked up from reading car mags, this was new tech on the market. I got the job.
I only ever seek to inform. Never condemn.
Expired Member
Liked 5,795 Times
