My FnHon Gust 16", 2023
Likes For Ron Damon:
Ride more, eat less
Liked 816 Times
Curious, how often do you actually use that 53x42 gearing? 1%, less than 1%?
Does the chain & rear derailleur actually clear the rear tire when you're in that gear?
Bikes: Several, all affordably priced, none exalted cult artifacts
Liked 829 Times
Breakfast ride
Western bloke: "Hey, is that a Brompton?"
Me: "No, it's not a Brompton."
Western bloke: "Yeah, it's a Brompton!"
Me: 🙄
That derailleur is really close to the ground.
It's gonna catch and break.... and it looks stupid.
Why don't you take a few minutes and calculate a mod for it so it's not so dangerous!
Minor skills... snip snip and perfection!
Or pay someone who can instead of leaving it looking really bad.
Maybe you should consider walking!
Liked 829 Times
Clark W. Griswold
Liked 4,553 Times
What is their to "snip snip" I doubt the chain is too long and it has a derailleur to keep it tensioned.
What looks really bad? The only thing I would complain about is the logo on the cranks and it being a knock off Dahon (though seemingly a decent frame) but in the end it does look nice overall. Good color, a good practical build. Maybe not how I would build it but nothing seems ridiculous about it or really bad and that is always going to be subjective to your own personal tastes.
It seems as if you like to comment in places you have no real knowledge or maybe you don't like folding bikes and that is fine but maybe learn a little bit before making ridiculous claims because you don't understand.
Yes if Ron had gone with a medium cage or long cage he would be very likely if not certain to hit the ground but as is he won't and I am sure he knows how to ride a folding bike as I believe he has a number of them or has had a number of them. Considering he mentioned he completed the Tour De Korea which is a decently long ride and was able to post pictures of the bike in good condition it is pretty clear the bike is fine. No need to walk when you can ride. Now if you like to walk with your bike that is fine, go for it. I know sometimes I have to and it sucks and sometimes I do it just to take a break but to say you need to do it over a folding bike is just silly.
These two pictures show that the derailleur cage obviously hit something.
Even if its a short cage, this derailleur with this big cog cassette and 50x305 wheels comes really close to the ground.
Slightly bigger wheels like 50x355 would help but this frame seems not able to accept wheels bigger than 50x305?
Liked 829 Times
https://www.bikeforums.net/folding-b...16-2022-a.html
The Shimano Zee RD currently on the FnHon Gust 16" is on its eighth year of service since 2016 across four different bikes, including another 305er (FSIR Spin 3), several tours international and domestic, and daily use. The part has has seen lots and lots of action, and has indeed taken hits and scrapes from when I've taken it off-road in veritable rock gardens. The scrape on the pulley cage is obviously a sideways glance while moving forwards. The light scrape on the RD body, I suspect, is when the bike fell on the drive side and the RD body scraped against the floor.
Knocks and scrapes not withstanding, it remains in perfect physical and operating (though not cosmetic) condition, shifting crisply, precisely and quickly. It is tour tried and tested on 16" (305) wheels. Thrice. This is what it looks like, literally, today.
There are marginally wider/taller tires in ETRTO305 size. I've shown them -- Deli Tire Lizard 57-305 and Kenda Kontact 58-305 -- on this channel before, and have them on hand for when these Schwalbe Big Apple 50-305 wear out. Well, I have two new pairs of those too for fear that they might be hard to find or discontinued in the future, but that's a different story.
The cage length alone doesn't define how low the derailleur cage goes.
The way the whole derailleur, body+cage, stretch is also important. Shimano improved the geometry of the recent rear derailleur to allow bigger cogs without having the cage going lower.
Look at the pictures below of a Shimano Ultegra RD-R8000GS 11s (the equivalent 105 is identical excepted for the weight) it has a much longer cage than the Zee but doesn't put its cage lower.
So you want to say that a derailleur that hangs 2cm below the rims edge on a 18" wheel, hangs not lower than a derailleur that hangs <1cm below the rims edge on a 16" wheel? Really? Wow...
Compare the shape of the Ultegra and the shape of the Zee: the Ultegra body is never very much tilted to the ground it is slightly tilted to the ground only when the chain is on the biggest cogs and the cage extended to the front not to the ground while with the Zee the body and cage are aligned and tilted much more to the ground with as consequence that the length of the boy and cage are combined to place the very short cage of the Zee close to the ground.
So the distance of the cage to the ground doesn't depend only of the cage length but also of the way the derailleur stretches (which is defined by its geometry) and of the chain length.
Liked 829 Times
A rough, back-of-the envelope calculation suggests that the radius of a 355 wheel with a 50mm wide tire is about 22.8cm, while the radius of a 305 wheel with the same width tire is 20.3cm. Therefore, the latter provides 2.5cm (about an inch) less ground clearance than the former, holding all other factors constant. I don't see how the Shimano Ultegra RD-R8000GS part would provide more ground clearance than the Shimano Zee RD-M640-SS part, based on these calculations and the images provided. What's more, the former part is rated only to 34T max cog. This, its rather meager max cog capacity, accounts for tl only very slight incline or angle. There's no free lunch.
How would this, on a 305 wheel with 2.5cm less ground clearance or a wheel radius that is 2.5cm shorter, be better? I'd be worse. Which begs the question instead, why is he using this GS Ultegra job when he could be using the Zee RD?
The other issue is that he's running a 34T max cog while I've run up to 37T, and as we all know, the bigger the max cog, the smaller the ground clearance.
The other disadvantage of this Road RD is the lack of a clutch. But you know, some Europeans operate under a different set of facts. Good on their bikes, bad on ours.
Liked 829 Times
Tasteful build...
...from a local folder group. Not my bike.
My only aesthetic nitpick is that protuberant front cabling.
Liked 829 Times
Change log
- Swapped pedals for wider platform Strummer PD-2033 part formerly on the FSIR Spin 5 bike
- Installed new Schwalbe Big Apple 50-305 tires
- Installed 10sp, 11-40T Decaf cogset in 9sp, 11-36T config
- Cleaned and lubed Shimano Zee RD, including disassembly of the pivot/clutch mechanism.
- Shortened & cleaned the chain
Wiped it down real good too. It's now ready for the next foreign adventure. 🌏
Worst case
