Carbon Fiber Bikes - the material science
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2686 Post(s)
Liked 5,937 Times
Rust is real.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Quoted: 7696 Post(s)
Liked 3,605 Times
As it happens repairing CF is probably the easiest, since it is just a matter of mixing epoxy and wrapping layers of CF cloth (I have a CF repair kit on hand just in case,) but as with any repair ... get it wrong and maybe you won't know ... until you hit a bump on a 40 mph descent and you die when the frame collapses.
However ... that is an issue of Crashing ... not frame material.
Quoted: 4227 Post(s)
Liked 2,491 Times
Rust is real but it's also a highly exaggerated problem. Steel frames rusting out is a non-issue for most people and majority of steel frames will outlast their owners. I have never seen a steel frame that was rusted out so bad that it was not safe to ride. I have two steel framed bikes which are 16 years old and used on salt covered roads here in Canada during winter time both frames have been treated with rustproofing oil on the inside and I don't worry about them ever rusting out.
Quoted: 8397 Post(s)
Liked 9,312 Times
Your post raises a pretty good point. Damage like that is pretty easy to spot, and like you said can be simple to fix. More importantly, at least to me, is the rider probably had ample warning something was going to fail.
Carbon doesn't seem to have an easy way to detect pending failures. I also have questions how gracefully it will be when it does.
A limited lifetime isn't really a big issue as long as one knows when the frame needs to be retired. How does one know that with a carbon part?
Habitual User
Quoted: 5064 Post(s)
Liked 8,350 Times
Liked 9,312 Times
Habitual User
Liked 8,350 Times
Likes For Eric F:
SE Wis
Quoted: 2754 Post(s)
Liked 3,422 Times
https://www.motor1.com/news/492625/m...-carbon-fiber/
Mad bike riding scientist
Quoted: 6270 Post(s)
Liked 4,299 Times
I have an aluminum frame that is16 years old with 22,000 miles on it with a carbon fiber fork that was OEM that was only retired because I wanted a different color bike. It’s still in my garage and might see service again. I have a 12 year old Cannondale T800 with 10,000 miles of loaded touring on it that was also retired only because I wanted a different colored bike. My supposedly invulnerable steel framed Miyata Ridge Runner which was the first frame I broke, has roughly 3000 miles on it when it had broken the 4th time…first it broke at the steer tube on the fork, then it cracked on the chainstays at the bottom bracket brace, then it broke at a dropout when an axle broke, and finally, it broke above the repaired chainstays. My steel Specialized Rock Combo lasted 4 years and 3800 miles before it broke.
In fairness, I broke two aluminum frames. One was a Specialized Stumpjumper Pro with an M2 frame which is known to break. It lasted 5 years and twice as long as the steel frames. The other aluminum frame broke because I put a HellBent seatpost with massive set back on it. But it was repaired and was still in use several years later.
In my experience, steel is rather delicate. I’ve had other steel bikes that have lasted longer than the two that broke and didn’t break when they were replaced with upgrades. I’ve also had other aluminum bikes that have seen long service. No material, be it aluminum, steel, titanium, magnesium, or carbon fiber is going to asplode because it is used in a bicycle. The material isn’t really taxed all that much by the light duty that bicycles put the material to. As I said above, there is a whole lot of exaggerated problems in bicycling that are indeed exaggerated and not nearly the problem that some people make them out to be.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 4,299 Times
I think you missed Professor Marrow’s point. All materials degrade. Steel oxidizes to iron oxide, aka to the layman as “rust”. Aluminum oxidizes to aluminum oxide which is could be called aluminum rust. Titanium can be oxidized to titanium dioxide. Carbon fiber, most specifically the matrix, can be degraded by UV. Each material has its strengths and weaknesses.
In the case of the epoxy in the matrix, the epoxy doesn’t necessarily fall apart or change state like metals do. The UV causes the matrix to further cross link and become more brittle and less flexible and, thus, more prone to cracks.
Stuart Black
Stuart Black
Habitual User
Liked 8,350 Times
I, admittedly, don’t know everything about carbon fiber composites as a material for bike frames and parts, but I’m still pretty confident in saying it will never rust.
As for UV degradation, the “paint” defense strategy seems pretty effective. There’s also the “keep the bike out of the elements when you’re not riding it” defense strategy. Oddly, all of my bikes - metal and plastic - get the same strategy.
Also, my previous comment was specific to the post I quoted.
Liked 4,299 Times
Did you miss my TED talk in post #15 of this thread? I invite you to review it.
These are examples of the “exaggerated problems” seen in bicycle discussions all the time.
Stuart Black
Stuart Black
Quoted: 524 Post(s)
Liked 688 Times
...that was only retired because I wanted a different color bike. It’s still in my garage and might see service again.
...I have a 12 year old Cannondale T800 with 10,000 miles of loaded touring on it that was also retired only because I wanted a different colored bike..
Likes For wheelreason:
Habitual User
Liked 8,350 Times
Again, you seemed to have missed what Professor Marrow had to say about paint, which is another polymer that isn’t impervious to UV radiation. Granted a polymer bike isn’t likely to fall apart if some sunshine falls on it. But steel won’t rust if a little bit of rain falls on it.
You may have missed that my response to wolfchild was intended as a light-hearted needling, not an in-depth dive into materials properties.
EDIT: I finally got a chance to watch the video. It seems that Morrow's short comments about paint were related to clear coat over raw CF, not pigmented paint.
Habitual User
Liked 8,350 Times
Thanks for the info. Because of this, I just cancelled my plans to torch all my CF bike frames.
Quoted: 1276 Post(s)
Liked 1,378 Times
I am amazed that these bizarre debates continue regarding things like Carbon bicycle frames and components, even though the same exaggerations are posted from all sides. Thousands of comments have been presented, yet it begins anew at the slightest hint of chum being tossed in the water like this thread.
I also rise to the bait as I enjoy and find humour in imparting sarcastic insights to the discussion. In the real world, the carbon debate has been settled with almost unanimous acceptance at the premium end of the sport in frame materials and components. This is for a reason, as it is superior in most use cases. Luddites be damned. I mean, debating UV resistance as a possible issue, get serious.
As with everything else, decisions lie on a continuum, including frame materials. I purchased a steel adventure bike for a particular use case: a 4,000-mile ride across South East Asia next year. Steel because it is better suited for this kind of application, and the market has also adjusted for this with lots of steel options and minimal carbon ones.
On a less serious note, good luck repairing your steel, titanium or aluminum bike at home, yet carbon piece of cake.
Quoted: 18557 Post(s)
Liked 15,960 Times
Likes For indyfabz:
Disco Infiltrator
Quoted: 3133 Post(s)
Liked 2,115 Times
Most frame failures other than damage are due to design failures or build failures - or in my business we would call them escapes and nonconformances.
Salsa had a steel frame in the early-mid-2010's called the El Mariachi and it had a persistent problem with cracks at a really hard bend in the chain stays. This was not an unusual problem for that generation across the industry and newer hardtail frame designs from everyone since mid-2010's have a drive side yoke made of plate.
Their mid-late-2010's carbon suspension bikes have been developing cracks in the seat stay link.
Both of them are impossible to repair. The steel one because any repair would be weaker in the same high strain location that killed it originally and the suspension piece because it was right by a pivot and no way to make an overwrap that would not interfere with the suspension action
Full suspension bike buyers seem a lot more tolerant of cracks than roadies. Oops, it's used up, hooray time to get the newest one
Genesis 49:16-17
Genesis 49:16-17
Quoted: 2333 Post(s)
Liked 2,097 Times
I've had various things made from steel, aluminum, Ti, and Mg crack or break on my bikes.
I've never had a carbon failure and my first carbon bike was in 1986.
Airline partially crushed a carbon seat stay on the way to France, I did the ride with a partially busted tube.
Aluminum rims are garbage compared to carbon
Liked 4,299 Times
*”Colorless” is the proper term, not “clear”. Colorless is lacking in color. A substance can be clear…lacking in particles that cause light scattering…and colorless…lacking in color…or it could be brown and clear…i.e. lacking in particles that scatter light. Tea (without milk) is an example of a clear, colored solution. Water is an example of a clear and colorless liquid and milk is an example of a colorless but cloudy liquid.
Stuart Black
Stuart Black
Liked 4,299 Times
Continuing to be pedantic, probably not. Carbon fiber…the actual fiber…is formed at very, very, very high temperatures. Burning it is going to be difficult. That’s one of the problems with recycling it.
Stuart Black
Stuart Black
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 688 Post(s)
Liked 1,012 Times
Habitual User
Liked 8,350 Times
This ^^^ was my only point, and I made it half-jokingly.
I have no doubt that you are probably correct on everything you're saying. However, I have zero interest in getting into a battle about the accuracy of words. My apologies for not meeting your standards.
Also...lighten up, Francis.
Steel is real
Quoted: 688 Post(s)
Liked 1,012 Times
You have forgotten the Columbus XCR and Reynolds 931 and 921 stainless steels and before them the Reynolds 953 was dwarfing them in terms of tensile strenght exceeding 2000mpa . You can prevent rust in a classic steel by spraying rustol or antirust primer in the head tube seat tube as well as inside the bottom bracket. When a carbon frame breaks it is hardly repairable unless you know specialist but is very espensive , otherwise it becomes a disposable worthless product. Whereas with a steel, aluminium frame and titanium frame you can always have it rebrazed or rewelded.
