I need to check chain wear, are these short chain wear tools good to use?
Quoted: 5899 Post(s)
Liked 2,762 Times
When these chain checker tool arguments arise, does anyone else scratch their head at the comments that say chain checker tools are inaccurate, and steel rulers are the only way to go? If using a steel ruler is your preferred method, more power to ya. But why would an otherwise very reputable tool company suddenly jeopardize their reputation and put their brand on less-than-accurate tools? If the QA in the tool’s production is questionable, why can the QA in production of a steel ruler be questionable? — Dan
This won't hurt those selling them, because no actual harm is done. Who's to know how much longer a chain might have lasted, or whether leaving it on longer might have hurt the cassette, or not.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 4854 Post(s)
Liked 3,992 Times
A crude example to demonstrate how this becomes a much greater issue for chain checkers than a long ruler. With a ruler, the rollers never enter into the calcs. It is just pin to pin distance. Your typical chain checker pushes 2 rollers apart and works with that distance. So there is the "stretch" between those X number of pins plus the slop of the two end rollers. A chain could be made that had that slop from day one. It simply wouldn't matter to you, the bike or the shifting. But that chain would flunk from day one.
I believe some chain checkers use methods that do not have this issue. I haven't studied this as it never mattered to me. I just use the ruler. Works. But if I had to get a checker, I'd do that research and fully expect the checkers that do it right to be considerably more expensive. And that's before considering quality. Just, is this designed to get the right answer or just measure the total stretch and calculate what should be acceptable from that?
Mad bike riding scientist
Quoted: 6255 Post(s)
Liked 4,280 Times
The issue of “over-estimating” wear, is something of a red herring as well. Let’s assume that a chain is worn out at 0.75% which is about 3/32” over a 12” chain. Let’s also assume that that happens at 3000 miles as well as assuming that wear is linear (probably isn’t but the math is easier). If the chain checker reads 0.75% at 2500 miles, that’s 500 miles of chain wear you are missing out on.
And how far off are the chain checkers? I’ve done my own tests with several and found them to be spot on, independent of the type of chain checker…short, long, roller isolating or not…when compared to a rule or tape measure. If the checker were off by 10%…which they aren’t…that’s going to be 300 miles too little mileage. If they are off by 1%…which they might…that’s 30 miles. Either one is hardly something to get all hot and bothered about. Chains should be cheap or, more correctly, an expensive chain doesn’t provide for a significant increase in wear mileage. Paying more for a chain is just paying for cosmetics for the most part.
I also have questions about the accuracy of using a rule. I find the photos of people using a 12” rule and then estimating 1/8” and claiming the method to be “more accurate” to measure chain wear highly amusing. You cannot not have an accurate measurement if estimation is involved. If you measure the 1/8” directly, that can be accurate but that depends on other factors as well. Was the chain stretched when the measurement was made or was there slack in the chain? If a tape measure is used what is the variance in the measurement due to the movement of the hook end of the tape measure? The hook can easily move that 1/8” depending on where the hook is in relation to the end of the tape.
Stuart Black
Stuart Black
Sr Member on Sr bikes
The one I use, the Park CC-4 is 9 inches long. I.e. it checks the wear over 9 inches(9 links). Using a steel ruler, presumably 12 inches/12 links. Most of the wear check tools I’ve seen are similar, and check the wear of several inches/links, rather than just a couple of links. So is the 3 more inches using a steel ruler going to make that much of a difference?
Dan
Likes For _ForceD_:
Droid on a mission
Quoted: 320 Post(s)
Liked 283 Times
Thanks, I should have checked and seen that
Quoted: 1135 Post(s)
Liked 1,233 Times
I use a Park CC4 or Pedros Chain Checker Plus for quick on the bike checks. Between my wife and I we have 10 bikes I maintain, including 8, 9, 10 and 12 speed road and MTB. I've switched the 8 and 9 all to 10 speed chains, fwiw, to simplify. I do have one of the smaller, older Park chain tools (3?) but switched to the above versions because the 12 speed AXS flat top chain recommends them. I haven't actually compared the results. Maybe I will.
If the tools show wear, I would take off the chain and hang it from a nail and double check with a steel ruler. But, it's hardly worth the effort - like someone said, the possible over-kill with the chain checkers is trivial in the big picture. SOmetimes I think we over think things.
Liked 3,992 Times
Dan
Dan
Liked 4,280 Times
The rollers hardly matter. Wear occurs at the pin. Just measuring from pin to pin without taking the elongation of the chain into account will lead to inaccurate results as well. The chain needs to be pulled tight to measure correctly. If the chain is off the bike, hang the chain to measure it or if it is on the bike, it would be best to measure the chain on its bottom run where the derailer spring puts tension on the chain. Or just use a chain checker that isn’t as inaccurate as many would lead us to believe.
Stuart Black
Stuart Black
Likes For cyccommute:
Here’s the thing about comparing a checker tool vs. the steel ruler. On the checker tool (pictured) the difference between OK, 0.5, and 0.75 is just that little notch that I have the nail pointing to. That’s a small measurement. Between making sure the chain is tight, and holding the ruler still, and precisely in the middle (or the edge) of a rivet (and dealing with anything else that could affect the measure like light/shadows, etc)…how can you know that you’re not off by just a smidge, and thereby getting an inaccurate measurement? The chain checker tool takes care of that. — Dan
Likes For _ForceD_:
Liked 4,280 Times
Stuart Black
Stuart Black
aged to perfection
Quoted: 852 Post(s)
Liked 1,282 Times
I like this chain indicator. it's longer than the other tools and therefore the span of measured chain is longer, so more accurate, which is why the little short tools don't work. Can't measure chain elongation very well over a span of 2-3 links, the level of precision required is just too great.
Sadly I do not know where I got it or who made it.
/markp
/markp
Bikes: Schwinn Broadway, Specialized Secteur Sport(crashed) Spec. Roubaix Sport, Spec. Crux
Quoted: 186 Post(s)
Liked 176 Times
/markp
/markp
Sir Mark, Knight of Sufferlandria
Liked 2,762 Times
The amounts involved in chain wear are in the range of 0.001" or so. They wouldn't be measurable with the tools at hand except for cumulative effect. Measuring over greater lengths creates the multiplier needed for the job ie.0.001"/pin x 100 links = 1/10", easily read with the naked eye.
Also, when measuring with a method that conflates roller slop and pin wear, a greater span reduces the effect of roller slop, making the method truer to one for pin wear only.
So, as they say, "Size matters."
Quoted: 1237 Post(s)
Liked 192 Times
/markp
/markp
https://www.ebay.com/itm/124645390485
Looks neat:
Liked 2,762 Times
Called the Speedtech CW-1089. Pricey for NOS but some cheaper used ones.
Looks neat:
Looks neat:
Maybe I should have hung onto a few.
FB
Chain-L site
FB
Chain-L site
Quoted: 186 Post(s)
Liked 176 Times
Sorry, but no.
When I had excellent eyesight I could read a 64th inch scale on a rule. Frank you seem to be claiming that with a rule, which most advocate a 10 inch one, that you are looking for .010" over ten inches. That's a hundredth of an inch! Parallax errors are greater than that. It is the method of measurement that gives one accuracy, not the distance measured. But no one is actually measuring chain wear, tools that act as a go/ no go gauge do not measure, they indicate wear limits. Exceed those limits and you risk damage to your drivetrain such that a new chain no longer fits.
Liked 2,762 Times
It's a case of typing faster than thinking, compounded by a typo.
I actually meant 0.1" stretch over 10", based 1% stretch. Divided by 20 links that would be 0.005" per pin.
But the point that measuring over more length improves accuracy still holds.
FB
Chain-L site
FB
Chain-L site
Quoted: 186 Post(s)
Liked 176 Times
Mia culpa. I don't know who Frank is, but assume you meant me.
Really Old Senior Member
A tenth of an inch is much more noticeable. We'll have to agree to disagree on the accuracy statement. 1% is 1% no matter the difference in measuring length. I submit that if you wait until 1% elongation then you will be replacing the rest of your drivetrain much sooner. If you replace the wear item (chain) before it damages your cassette and chain rings then you are better off.
A longer span will provide greater resolution. That will allow one to READ the results more accurately.
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 1001 Post(s)
Liked 679 Times
Recent rides with a friend, his wife came along, she was experiencing a skip/jump under load but "there's nothing wrong with my bike!" Couple of days ago, he and I replaced her chain (I've converted him to waxing)... problem gone.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Liked 2,762 Times
However, I think you might have misinterpreted my point, possibly owing to a poor choice of words.
Yes, 1% is 1%, as 1/2% is 1/2%. However, whatever replace point you prefer, it's easier to measure if you multiply the tiny difference by measuring the accumlated wear over a greater distance.
FWIW I don't buy into the chain gauge arguments. Whatever guideline one chooses, it's just that ----- a guideline. Just as you wouldn't stop and look for service stations if you odometer reads 3,000* miles since your last oil change, I use a broad strokes approach and use measurement to decide that's it's time to consider changing when convenient.
*if that's when you change oil, otherwise pick any number.
Likes For FBinNY:
