105 vs Ultegra. Is it worth $300 more for Ultegra?
Liked 3,019 Times
My last build I went with full r8000 ultegra mechanical, but swapped out the brakes for Velo Orange grand cru to allow for more than 28mm tire clearance....
as there are not enough bike pics in this forum, here is how it looks
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1351/kirkgarage1_0317e007495cb69168f4809121bbc4dd942f724d.jpg)
Life is too short not to ride the best bike you have, as much as you can.
Should Be More Popular
Liked 9,195 Times
Likes For datlas:
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Liked 942 Times
Multiple composite experts have created decent videos about the cause of the failures - and its a clear design flaw.
Where the same generation 105 cranks don't have this problem.
For me, the extra $$ for the cranks, and the zero to min performance gains you get from the 2oz weight savings - is absolutely not worth the money.
Likes For Jughed:
Liked 3,106 Times
Liked 5,004 Times
But in this case, we have history - Ultegra/Dura cranks have been failing enough for websites to be started and youtubers making videos on the subject - calling out Shimano to step up and fix the issue. This indicates a problem with design/construction, and failures occur at a higher than normal rate. This is more than 1 off failures, and these are high dollar items.
For y'all to be saying it's a design flaw is a little early I think. Proper glue bonds are strong enough whether you want to believe that or not. It might just be a occasional issue on the assembly line. And the number of confirmed failures is still extremely low.
The only R7000 105 component that I think is a bit dubious are the pedals with the plastic bearing housings. Having said that they still go the distance without causing any real world problems - just a tiny bit of play. But I do prefer DuraAce pedals because of this. Ultegra pedals are probably somewhere in between.
I think R7000 105 is hard to significantly improve on unless you go electronic. $300 is not an unreasonable upgrade cost for Ultegra, but mostly for badge honour. I can't see any practical difference and don't try to convince me that 174g weight saving makes any odds. Shimano/SRAM/Campag have done very well to cultivate these extreme diminishing returns on their higher level groups. Some people are more than happy to spend the cash for very little practical return and mainly for the cache of Ultegra and especially DuraAce on a high end bike. That's not a criticism, just a recognition that hobby purchases are not always rational.
well hello there
Liked 339 Times
Get the ultegra. Because YOU are worth owning the upgrade.
Likes For Nachoman:
slow on any terrain
I’m a little Surly
Bikes: Two Cross Checks, Karate Monkey, Disc Trucker, and a VO Randonneur
Liked 1,304 Times
I’m always in the low to mid level with shifters and derailleurs (2x Centaur, Rival, Tiagra) they shift as well as their better counterparts but don’t cost as much. I’m also not to big on groups as a whole so I use different makers for cranks and brakes.
if you’re going to keep the bike I can’t think of a good reason not to buy Ultegra.
Likes For Germany_chris:
Liked 9,195 Times
I am willing to be wrong. I do it all the time, ask my wife!
That said, I was looking for some type of proof or evidence whether "Hollowtech" refers to the hollow crankarms or the the hollow axle, and could not really find any. Maybe it's both??
Liked 3,106 Times
Shimano released the 7700 series in 1996, succeeding in achieving both high rigidity and an approximately 500 g weight reduction of the entire components series by introducing the HOLLOWTECH crankset with hollow crank arms.
Shimano History
Likes For smd4:
Liked 9,195 Times
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Liked 1,022 Times
Get the ultegra over the105, even though I would have prefered a mechnical ultegra, I am not fond of the new sti design nor the cranks design or the derailleur design. About reliability that must be seen over the very long term.
Sunshine
Liked 7,726 Times
We have lots of history of solid cranks failing too. Some where poor quality control issues that could be corrected by better manufacturing methods and the manufacturers did so. Some where design flaws and couldn't be corrected.
Nobody that I have seen in pictures of the delaminated crank arms looks like they are crushing it with watts and a crankarm should be an incredibly strong and stiff part of the bike.
You claim its too early to say its a design flaw, then offer up an unsubstantiated guess that its a production flaw. Ok, regardless of where the flaw is occurring- it really shouldnt occur at all. Just make it(design and production) strong enough to not split apart in a catastrophic manner.
Likes For mstateglfr:
https://www.instagram.com/thanksshimano/?hl=en
You can see pages and pages of pictures of these cranks breaking. Some people broke two in a row: https://carlinthecyclist.com/epic-fa...1-speed-crank/
Bikeradar has written about it and Hambini has a fairly comprehensive analysis of it as well.
This guy has six of these broken cranks:
I can't understand how on this forum some people are scared to death of carbon assploding on them, and yet when faced with the very well documented and known failure mode on these cranksets, people could just bury their heads in the sand and think it's worth taking a chance on something that can fail and put your face in the dirt in an instance.
Liked 3,106 Times
Steel is real
Liked 1,022 Times
It's occuring way too often to be one-off failures. Look here:
https://www.instagram.com/p/CXKRZ7aO...RlODBiNWFlZA==
Must be 6 isolated incidents, right?
Likes For georges1:
Steel is real
Liked 1,022 Times
the da7700 and da 7800 never had failures unlike the latest ones. Maybe the manufacturing process hasbeen cheapened ?? The newer cranks doesn't seem to be forget but glued . That is why I stay away from anything new whether 11speed or 12 speed.
Liked 3,106 Times
The 7700 at least were welded, and then polished to appear as one piece. Don't know about the 7800s. The cranks that have failed were glued together.
Liked 5,004 Times
Your pages and pages of pictures, many just more pics of the same crank don't really amount to anything but a teeny tiny fraction of all the Ultegra and DuraAce cranks out there today.
Sure, in a perfect world there should be no failures, but that ain't happening.
Klaatu..Verata..Necktie?
Liked 12,379 Times
Once you get past 2, you're doing something out of the ordinary. If you get to 6, you're doing something intentional.
Likes For jadmt:
Likes For jadmt:
Steel is real
Liked 1,022 Times
