Trek 730 MultiTrack Curb find- Operation WetTrek
#51
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1330 Post(s)
Liked 3,799 Times
Just wanted to jump in again in this one to say you’ve got a special bike. The ‘98s I believe were the only year to come with a rear cable stop for the rear brake. All other years it was just a cable tube/guide to run cantis. With the stop, the bike came with V brakes which to me are heads and tails above cantis. After that the 730 was no more. At least not made in USA.
Ive got a roughly ‘96 750 and I might just be keeping an eye out for one of these 1998 730s. The perfect ‘do it all’ jack-of-all-trades bikes. Get a spare wheelset, set up one w/ fast rims and narrow tires, and the other w/ beefy rims and gravel tires, and BAM! Ready for anything!
#52
Deraill this!
Bikes: 18 Cdale Quick 1, 94 S-Works M2, 98 730 Multitrak, and a few others
Quoted: 154 Post(s)
Liked 475 Times
I do have two sets of wheels for it. I finally decided that to grab the 70x35c Marathon GT Tours from my Quick 1 for it. Great tires and virtually indestructable but too bit heavy for the Quick. Later on I'll set up the original wheel set for the 11 speed cassette and install some wider tires for gravel.
#53
Deraill this!
Quoted: 154 Post(s)
Liked 475 Times
I took an afternoon break and cut down the bars, installed the brake levers, shifters, and grips. Also swapped the front tire from my Quick 1 to the $40 wheel set. Wow, I can't believe I forgot how hard those tires are to mount.
This bike just makes me smile 😃
*** "Master of the Messy Desk" coffee mug is lost somewhere on the workbench
Likes For Trav1s:
Likes For bboy314:
#56
Deraill this!
Quoted: 154 Post(s)
Liked 475 Times
Yesterday I got a little time with the 730. I relocated the shifters, finished up shifter cables, and hunted down setup info for the derailleurs. I've done research into the 11 speed cassette adaption too. 1.8mm is not much but enough to cause problems. My daughter has discovered the front 105 hub spins very fast and easily while on the stand. I'm excited to explore the local trails on this one.
#57
I bought one of those aluminum UPAN Bike silver handlebars off Amazon for a cheap-ish project I was doing. I figured that a little paint remover would take the painted on lettering right off. Nope. That lettering is underneath some type of clearcoat they use on them.
Likes For tkm:
#58
Ride, Wrench, Swap, Race
Quoted: 1574 Post(s)
Liked 1,316 Times
It sounds like you've researched things, so know that the 11-34t version of 11s road cassettes fits properly on the older 8/9/10s freehubs.
Those rims might be a weak point if the bike gets cornered hard off-road using the upright bars, I've folded even a stronger Open Pro rear rim after catching traction mid-slide (and I'm a lightweight rider on properly-tensioned wheels).
I really like those bars, and I like riding hybrids even without today's fashionably-wide tires.
#59
Happy banana slug
Quoted: 1562 Post(s)
Liked 1,579 Times
I lost track; what's wrong with 2 x 9?
#60
Deraill this!
Quoted: 154 Post(s)
Liked 475 Times
Thanks for the heads up on the wheels !This one will spend time covering the local paved trail network and get some time on the OTET. I still I have the original Acera wheels and can set those up with larger tires if I want to explore singletrack. I've already converted it to support the 11-34t cassette.
Likes For Trav1s:
#62
Happy banana slug
Liked 1,579 Times
And 8- and 9-speed chains are nice and sturdy.
#64
Likes For tkm:
#65
Deraill this!
Quoted: 154 Post(s)
Liked 475 Times
The probability of 1x conversion in the future is highly possible. I get the challenges of more gears. Just a reminder, the crank and derailleurs were zero cost additions since they were removed from another bike and sitting on the shelf.
#66
Happy banana slug
Liked 1,579 Times
Blech. 2x is more versatile, but you do you.
#68
Happy banana slug
Liked 1,579 Times
#69
Deraill this!
Quoted: 154 Post(s)
Liked 475 Times
Until then, I'll go with it as it sits and enjoy it. #hurryupspring
Likes For Trav1s:
#70
Deraill this!
Quoted: 154 Post(s)
Liked 475 Times
CS-HG700-11 looks to fit the bill
#71
Deraill this!
Quoted: 154 Post(s)
Liked 475 Times
today’s update - grabbed the HG-700 again and gave another try… this time with the spacer removed from the back.
Other than a missing master link for the chain and rear derailleur adjustment, it’s all together. I sat on it and I’m really happy with the feel as built. I can’t wait to fine tune the fit.
Likes For Trav1s:
#72
Deraill this!
Quoted: 154 Post(s)
Liked 475 Times
#73
Quoted: 66 Post(s)
Liked 288 Times
Likes For daywood:
#74
Deraill this!
Quoted: 154 Post(s)
Liked 475 Times
Looking good! Looks like you still have ample room between your smallest cog and the dropout. Was your previous spacer keeping the cassette from fitting at all? Is a spacer under the cassette still a possibility if you find you have a problematic chain line to the largest cog? I like to run the pedals backward with the chain on the largest cog. If the chain chatters or doesn’t want to stay on it, I look at whether I need a cassette spacer, or if I need to reconsider the length of my bottom bracket, or if I’ve just gone a cog too far with my cassette selection. Yours may be fine. Just asking’.
The cassette spacer ring stuck to the back of the 11-34 cassette when I tried it on the 105/mavic wheel. After tons of additional reading, I tried it again... but not until I checked the back. With the spacer remove, it went right into place. I think spacing looks good on the drive side but it might be a bit wide. Since I converted the 105 rear hub from 130mm to 135mm I'm not sure which sided needed more spacing. I added 2mm to the drive side and 3mm to the other and need to figure out the chainline as you mentioned. I think it sits to far to the non-drive side of the bike but the wheel is nearly centered between the chain stays. If all else fails, can move the spacers to shift the assembly towards the drive side.
I need to order a new chain for this one, replacement cassette and tires for the Quick. More hurry up and wait for me.
Also, I found a 46 tooth sprocket for the FSA crank that is currently on the bike.
Likes For Trav1s:
#75
Deraill this!
Quoted: 154 Post(s)
Liked 475 Times
The official name for Operation WetTrek is The Dadillac!
Likes For Trav1s:
