Show Us Your 650B Conversions
#51
Go, CroMo, go!
Bikes: Custom Bantam AdventureBike,93 Bontrager Race mtb, 07 Lemond Poprad disc cyclocross, Black Mountain Cycle Road, 86 Bridgestone Mile 112, 89 Bridgestone MB-2, 93 Trek 750, 90 Trek 750, 90 Trek 930, 90 Diamondback Ascent.
Liked 25 Times
Hey, that gives me an idea. I just picked up a pretty cherry 83 Trek 400 that I'm thinking would make a fine 650b conversion. My questions - and excuse me if any have been answered elsewhere.
First, are there any issues in converting from 27 inch wheels to 650b that are not covered in the 700-650b discussions?
Second, are 650b wheels spaced for a 126 rearend fairly easy to find?
Third, I've got access to a couple good used parts stores and can probably find Mafac Racers (though Raids have proven elusive - and have you seen what they go for on ebay) or diacompe whatevers. What do folks recommend? Thanks.
#52
Quoted: 3854 Post(s)
Liked 6,962 Times
Most new wheelsets will be for 130 or 135mm spacing, so you can either cold set your frame or swap the axle if it's a hub that'll allow that.
Neal
#53
Go, CroMo, go!
Liked 25 Times
Hope I'm not hijacking this thread as I don't yet have a conversion to show off. I checked on freewebs.com and compared their numbers with the Trek 400. They recommend 371mm as the maximum distance from axel to brake bridge and this bike is about 368 (center-center). At 320mm from axel the inside chainstay width is about 44-45 mm, so I think I'm good. Will Mafac Racers work with those dimensions? If not, what are the Weinmann model I should look for if I can't find Raids? The bike WILL have fenders - either Honjos or Blumels. I will keep the rear at 126 spacing, and probably have a wheel built on a freewheel hub running a 7-speed freewheel (If I can't find one). Then my choice will be drop bars and downtube shifting, or go with moustache and bar-ends. Hmmm.
#54
Liked 6,962 Times
They're not beautiful calipers, but they'll do the job (and with polishing will look pretty good).
Neal
#55
Liked 6,962 Times
Here's a recent conversion for me: a 1978 Raleigh Competition GS w/ Sun CR18 650B rims, Col de la Vie tires, long-reach GB Sport brakes, Belleri bars, Nitto Technomic stem, Tektro R200 brake levers, SunTour bar-end shifters, TA Pro-3 crankset, Campy NR mechs, Velo-Orange 650B alloy fenders. To get enough tire clearance on the back, I have the axle pulled to the very back of the dropouts, and that amazingly allows the Campy derailer to work with the 32-tooth freewheel cog.
Neal
Neal
#56
Location: Rio de Janeiro - Brazil - South America - World
No exactly vintage but is 650B. Fixed Gear (61 gear inches), Caloi 10 frame (70 or 80?). 650x45B Wheels (Here in Brazil, 650B is the commonest size. The Caloi 10 originaly is 27").
#58
Bikes: Motobecane Mirage fixed gear, Nashbar Alpha Road 5000, Bianchi Grizzly, Coppi Fiorelli, , Schwinn Trike, , GT All Terra, Old Peugeot, Nishiki 3 speed, Bugatti, Cannondale Black Lightning, Dura All, Bianchi Touring, Bridgestone T700 & more
Ya! What gives? Might be time for a vacation.......I could probably pay for it with some extra luggage on the return trip! The exchange rate is pretty good isn't it? Maybe you could make a nice chunk of change on the side by selling the 650b goodness on eBay?
#60
Yes, is easy to find on popular bike shops (but in the touristic places is not as easy, the most bike shops there sell imported bikes - and tires - to upper classes).
But there are no much widths to choice, I know only 40mm (Pirelli "Selo Branco", 40-584), 45mm (Pirelli "Manga Turbo" 47-584) and 50mm (Pirelli "Manga Turbo" 54-584). See https://www.pirelli.com.br/pt_BR/brow...alogo_BIKE.pdf. There are also other brands (I dont know what tire widths), but the best slick tires are Pirelli, indubitably. The name most used here is 26 1.1/2.
The "barra forte" or "barra circular" are theses bikes (there are thousands in all places here, and all uses 650B):
#61
Peace, Love, Bikes
Bikes: Schwinn Le Tour III
Not to bump old threads, but this seemed the best place to tap the knowledge.
I'm looking at getting a new (to me) bike-really looking at a project frame to learn on-and love the idea of 650b. I started riding my 3 speed around and love the feel of smaller wheels.
Finding decent quality vintage steel in this town seems a bit tough. I've found 2 bikes so far that may work. Saw a Nishiki Sport today at the Co-op with 27" wheels and a busted rear axel. It's just a bit tall on me. Wondering how well 27" to 650b would work? I've seen a few on here.
I may find the measurement guides for the conversion and go back at the next open shop to see if it would work. Don't know if it will drop it enough, though.
#62
here's my conversion, 1988 Schwinn Tempo
Just finished this weekend. Only modifications needed were the wheels, obviously, and the brakes, also obviously. I used Tektro 556 and I went with Velocity Twin Hollows with Deore hubs and straight gauge. Had to spread the rear triangle as per Sheldon's (may he RIP) instructions. worked like a charm. I'm posting because I couldn't find info about a Tempo conversion anywhere else. For those who are interested, convert away, there's limited but adequate clearance at the chain stays for Col de la Vies and it works fine.
#63
Sorry, the title didn't post. This is a 1988 Schwinn Tempo that I converted to 650b. Hopefully anyone looking for info on a Schwinn Tempo conversion will now be able to find this.
#64
Quoted: 147 Post(s)
Liked 8 Times
It typically requires a long reach brake. 80s road bikes are good 650B conversion candidates. You'd have to install a brake with longer reach if you are sizing down from a 27" or 700C bicycle. In practice, it presents no real problem and a mid-sized Panaracer Col De La Vie 38" tire is equivalent to a 19" 700C tire. The medium width tread makes its useful for all around commuter tasks.
#65
27" to 650b should work very well. 27" inch wheels are 630mm in diameter whereas 700c wheels are 622mm. You'd only need 4 more mm of reach from the brakes to convert from 27" than you'd need to convert from 700c. Tektro R556s have something like 55 mm to 73mm in reach. If you're riding a 27" bike that uses short reach brakes (39mm to 49mm) the Tektros should work OK with the pads all the way at the bottom of the calipers.
One other issue that might crop up is the axle width on the rear triangle of a 27" wheeled bike. Most 27" bikes were built for 126mm wide axles. Most 650b wheels, at least the prebuilt ones, come with 135mm wide Deore MTB hubs. You'll probably have to spread your rear triangle to accomodate them unless you build a set of wheels with 130mm hubs. LIke I said in my post, it's surprisingly easy to do if you follow the directions on Sheldon Brown's site.
#66
bear
Bikes: '06 Scott S20, '04 Trek 3700, '88 Schwinn Tempo, '86 Schwinn Tempo, '85 Centurion Le Mans RS, '84 Univega Gran Tourismo
I suspect the part of the reason that you didn't find anything about a conversion on the Schwinn is that there aren't any fender braze ons. Most guys are looking to put fenders on when they do the conversion. I have that same model Tempo and considered it for a conversion, but ended up choosing a Centurion that had the fender mounts.
#67
Randomhead
Liked 3,802 Times
my LBS says that they have had a boom in interest about this conversion. I saw a nice bike in there getting 650b. Previously it had thin 700c.
#68
consilio et animis
Bikes: It's not 'bout the bike!
#69
Now, the dirty little secret of 650B: 650A is a very common tire size for wheelchairs. If the promoters of a modern implimentation of an intermediate bicycle wheel size had gotten behind 650A instead, wheelchair users could have benefited from a greater selection of good tires and lower prices. Post snippy little personal attacks if you want, but I'm sorry that benefitting the larger society wasn't important to the able bodied, highly mobile bike folks that made the 650B decision.
Best,
tcs
Best,
tcs
#70
#71
Peace, Love, Bikes
Quick search shows Schawlbe, Panracer and Michelin all make 650a. Seems like there is some good quality out there.
#72
cs1,
Not "the opposite". It's a matter of math and depends solely on the brake reach on the 27" wheeled bike. If the 27" bike uses 39mm-49mm short reach brakes, the Tektro R556 should work fine. The Tektros have a reach from 55mm-73mm. Using your own figures, lets assume that the 27" bike used the short reach brakes with pads dropped all the way down to 49mm. If you switch to 650b, you'll need an extra 23mm of reach. What's 23mm plus 49mm? 72mm. The Tektro R556s should have just enough room (up to 73mm). If the 27" bike used brakes with a reach longer than 49mm, then the R556s wouldn't work and you'd need a longer brake, most likely an old centerpull.
soma2x
soma2x
#73
You're probably right murphjam. No fender mounts. My back got soaked this weekend riding around the block in the rain and I could have used fenders. I gave up on fenders for other reasons, the rattle annoyed me and the stays also tend to bend a bit when I put my bike on the rack. Then I have to straighten the stays and make sure they don't hit my tires... Also, I prefer the look without the fenders.
#74
cs1,
soma2x
soma2x
#75
bear
