Rigid Fork vs Susp Fork on Road/Light Trail Bike
#51
Expired Member
Quoted: 3788 Post(s)
Liked 5,781 Times
Likes For shelbyfv:
#52
Habitual User
Quoted: 5075 Post(s)
Liked 8,375 Times
When I was commuting, I rode my road race bike. It served my needs just fine.
Likes For Eric F:
#53
Quoted: 216 Post(s)
Liked 68 Times
Light trail on the weekend. Generally hard-pack dirt some hard gravel.. And 25km commute weekdays in dense urban areas mostly in segregated bike lanes but some curb hopping necessary to stay alive.
deposit is in. I can bail on the deposit but unless the geometry issue with the rigid fork is something I’m just not comprehending, I will stick with it.
#54
Habitual User
Liked 8,375 Times
Likes For Eric F:
#55
Quoted: 568 Post(s)
Liked 425 Times
It's your money, do whatever you want.
That's what I do.
That's why I never, and have never asked for bicycle advice ever, here or anywhere.
I do what I want, so I don't bother bringing it up otherwise I'd be trolling.
That's what I do.
#56
Quoted: 216 Post(s)
Liked 68 Times
If I knew stuff about bikes I might take that approach. I rode the same Norco hybrid bike to work for 25 yrs and never once read anything online or otherwise about bikes.
between forums and Google you can build up some knowledge pretty quick.
Knowledge is power
that’s my strategy
Knowledge is power
that’s my strategy
Likes For MikeDeason:
#57
Commuter
Bikes: Main Bikes: 2023 Trek Domane AL3, 2022 Aventon Level.2 eBike, 1972 Schwinn Varsity, 2024 Priority Apollo 11
Quoted: 317 Post(s)
Liked 452 Times
This is too hardcore of a bike for commuting. Rack & fender options are severely limited.
Raising and pulling the bar back far enough for this upright comfort you're after is going to mess up the steering geometry. Front end will get ... nervous, at best. I know because I did this on my Aventon Level.2. Can't ride no-handed any more; it immediately starts to wobble. With the stock stem, it was a non-issue. When I go grocery shopping and put 40 lbs. of groceries on the back rack, it's even worse; I have to be careful. I'll probably put the stock stem back on it.
I also question why you're stuck on a flat bar. What do folks think is so great about having only one hand position? ...or two if you add the silly-looking bar ends ...or having one's arms spread wide, so the torso catches the wind like a sail? With the kind of riding you're saying, you don't need the leverage of a wide bar.
I think you'll find out in the fulness of time that I'm right.
Anyway, I hope I'm wrong, and I wish you the best and I hope you'll keep us updated on how she goes.
#58
Quoted: 425 Post(s)
Liked 995 Times
This is way more bike than I’d ever buy to commute, but it’s gonna be one hell of a fun commuter. I assume you’re not taking out a second mortgage or selling a kidney to afford it. If it were me, I’d go with the rigid fork, throw on a Ritchey Kyote handlebar and some decent 2ish inch tires. No rack mounts is a con, but there are solutions to that, like frame bags or bike packing racks.
#59
Habitual User
Liked 8,375 Times
#60
Quoted: 425 Post(s)
Liked 995 Times
#61
Quoted: 1587 Post(s)
Liked 1,226 Times
I don’t see the point in trying to compare this bike’s handling with a (no offense) fairly low end e-bike with front suspension. Also I think it’s more than reasonable for someone to prefer a flat bar for commuting, even more so with bar ends, even if someone thinks they’re ugly
I think my bike is quite 'pretty' and well-suited to this old b_gg_r's riding ... but that's just me.
#62
Expired Member
Liked 5,781 Times
In the fulness of time OP will regret choosing the Orbea over a budget ebike?
#63
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 344 Post(s)
Liked 247 Times
Knowledge is power
that’s my strategy
Knowledge is power
that’s my strategy
If not, hopefully you’ll love the new carbon fiber beastie.
#64
Quoted: 216 Post(s)
Liked 68 Times
Here’s what I don’t get.
Raising/lowering the seat post and angling and or raising or lowering the handlebars makes the geometry adjustable.
#65
Habitual User
Liked 8,375 Times
Those things adjust your body's position on the bike, but they do not change the geometry of the bike itself. With bicycles, the term "geometry" typically refers to lengths and angles of frame tubes, or segments of the frame.
#66
Rider. Wanderer. Creator.
Bikes: Bike Friday Pocket Rocket, Cinelli Hobootleg, Zizzo Liberte
Quoted: 424 Post(s)
Liked 883 Times
That Orbea certainly is sweet loooking! A couple of things to note about mountain bikes vs. the hybrid that you currently are using:
1 - Mountain bike bars are often quite wide for maximum control. Do you have any narrow gaps on your commute?
2 - Mountain bikes are usually specced with longer crank arms than road or hybrid bikes. You'll notice it if you're a spinner.
Also, that Thudbuster will no doubt smooth out the ride but the Orbea has such clean lines that it'll look like a roof rack on a Ferarri. Someone else mentioned a cleaner suspension seatpost. I'd recommend that, or just try it without a suspension seatpost at all at first and find a tire pressure that rolls and if comfy.
Best of luck. Be sure to post pics and a ride report when you get it!
JohnMFlores.com | YouTube: JohnMFlores
Insta: JohnMichaelFlores | TikTok: @johnnymotoflores
Likes For john m flores:
#67
Quoted: 344 Post(s)
Liked 247 Times
it isn’t adjustable, it’s the way your frame is designed, and it’s a big part of what makes bikes different from each other.
#68
Quoted: 1956 Post(s)
Liked 2,200 Times
If you are intent on adding some dampening, you might be able to use a Lauf fork if you can get the right axle-crown/offset to match your rigid fork.
Redshift makes stems that will also provide some dampening.
John
John
#69
Commuter
Quoted: 317 Post(s)
Liked 452 Times
Yes, I think so. At least if he was open-minded enough to even consider an eBike, which a lot of you aren't. Instead, you're fixated on how high-end brands and components are considered. They're not for everybody, just people who want to be able to choose how much work they do or who want to be able to choose to go fast even when conditions aren't right for it on an mBike.
Now this is not a put-down to the OP. He's gotta do what he feels is right. I was just trying to make the point that a mountain bike was not a great choice for his stated use case. He WANTS a mountain bike anyway, so he went for it. Fine. I just think he's going to learn later that he bought the wrong tool for the job and then spent a bunch more money trying to adapt it to the job, rather than just buying The Right Tool to begin with. (and for the same money) My position just didn't consider his WANTS as much as his NEEDS. Wants are important too.
Likes For Smaug1:
#70
ignominious poltroon
Quoted: 2296 Post(s)
Liked 3,529 Times
Likes For Polaris OBark:
#71
Habitual User
Liked 8,375 Times
Likes For Eric F:
#72
Liked 3,529 Times
First 3 words ...
#73
Expired Member
Liked 5,781 Times
No, they are both correct though the one L spelling is mostly used in religious context. I actually appreciate an interesting phrase, that's why I repeated it. I don't disagree with much of what you've posted, only that 1) OP has already ordered the bike, can't leave the LBS on the hook for it. 2) From the beginning of this multi-post journey he made it clear he only wanted specific high end components. He never asked for advice about suitability. I say let him run with it, see how it works out.
Likes For shelbyfv:
#75
Commuter
Quoted: 317 Post(s)
Liked 452 Times
The OP was very forthcoming with the fact that he is not (yet) what he would call a bike mechanic. He's learning as he goes. I thought I would point out things I learned in a similar journey.
{tangent}I too have had my mind set on a bike that turned out to not be the best possible purchase, but which I HAD to have anyway. Most recently, it was my 1972 Schwinn Varsity, which is 37 lbs. and has junky brakes, but it looks THE BUSINESS to me!
One guy even recommended I buy it, but rather than spend money fixing up a low performance bike, just hang it on the wall, since what I REALLY want is to look at it.
1972 Schwinn Varsity: steel EVERYTHING
{/tangent}
