Conti GP5000 tire life-span: how many miles did you get?
#76
Quoted: 6386 Post(s)
Liked 4,982 Times
My front tire looks like it will make it beyond 13,000 kilometers (8078 miles) Rear tires I'm getting. I don't swap front to rear when installing a new tire any more. That just seems like too much possibility of a flat from installation error for the little bit more traction the new tire provides.
I'm just using the basic GP5000 tubed black wall. The rear I just changed out last year with more than 5000 but less than 6000 miles (8047 - 9656km). Bad record keeping on my part, I failed to record exactly when I put it on. It could have gone further, but I had one skid patch showing threads and a organized ride coming up that I didn't want trouble on. No flats on either tire. I think I'm almost 3½ years since any flat.
#77
And I was out again yesterday hitting a gravel patch without issues. I really dont get how people get so little use out of these. That would really piss me off lol I mean these cost nearly as much as a car tire.
#78
Liked 4,982 Times
Perhaps you also don't look for the better deals on GP5000's or bike tires in general. The same vendor may not always have the best prices. You have to search.
#79
Bikes: SL8 Pro, TCR beater
Quoted: 1027 Post(s)
Liked 595 Times
The general lifespan of a performance top tier race tire is 5000kms if I'm not mistaken. I'm lucky if I get 3000km out of my rear Schwalbe Pro Ones.
#80
Liked 3,171 Times
when ever i used "performance" tires, the one thing I do not expect is long-life akin to passenger tires albeit all-seasons, winter, summer compound.... Even a true summer tire I don't expect to get as many miles out of them compared to general use all-seasons.
What I do expect from the OEM regarding a performance tire that they produce are minimum miles under comprehendible criteria/details that the average consumer will understand.
An example that may or may not be accurate might be: ~1,200 miles in temps between 32F & 98F wet or dry, on solid road surfaces, within the min/max sidewall PSI rating, mounted in forward arrow rotation position, & speeds not exceeding 55MPH~
That'd probably never exist, but if it did, that'd be pretty cool & useful information imo.
In short, my expectations of a "performance" bicycle tire generally applies to "performance" automotive tires.
-YMMV
-YMMV
