PSA, Inflate tire to 80% psi
#101
Expired Member
Quoted: 3799 Post(s)
Liked 5,798 Times
Likes For shelbyfv:
#102
Quoted: 7143 Post(s)
Liked 11,330 Times
Likes For Koyote:
#104
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 1033 Post(s)
Liked 710 Times
...and I guess I could stop at various points of a ride to adjust psi to road condition...
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
#105
Quoted: 1111 Post(s)
Liked 1,050 Times
If you can't get around the word bouncing, call it vibration instead.
If we look at the most important chart of the earlier mentioned article
We notice that with a 25mm Continental GP4000S the break point for smooth asphalt is at 110psi after which the tire will start getting slower rapidly. At 140psi on new asphalt the rolling resistance is as high as it would be when the tire was inflated to under 60psi.
On coarse asphalt the break point is at 100psi and at 140psi the tire will be slower than if you ran the tire under 50psi.
#106
You aren’t interpreting the data properly. The bike doesn’t “get slower”, the rolling resistance goes up. That translates into more power needed to maintain a given speed. Yes, that means that for a given power output, the bicycle would slow down but the magnitude isn’t what could be called “rapid”. The data in the chart is also for one mass data point…190 lb or 86 kg. Changes in mass in either direction is going to have an impact on the “break point” since that is a measure of where the tires stop conforming to the surface and start to lift the bicycle in a vertical direction. Without more data points with more mass, it would be difficult to tell where that break point would be for a heavier or lighter rider.
Also on that vein, the need for different pressures for different weights is something I thought was obvious. As in, obvious enought that I shouldn't need to constantly in every message emphasize that. Of course the break point depends on the weight! It also depends on the tire, width, surface, and had you read the articles that were linked by me and others, rider body fat!
Come on!
Also the only way to accurately tell your particular break point for any particular tire and road combination is to use the Chung method yourself. Most of us have no time for that, but luckily there are pressure calculators which give a pretty good approximation of the correct pressure for any given condition. Personally I've found the Silca calculator to be fairly accurate. At least I notice pretty quickly if I go above the recommendated pressure.
Only just and the difference isn’t all that large. But, as with all of these “studies”, I see no indication of what the error in the measurement is. Without knowing what the error in the measurement is, we can’t draw many conclusions about how large the difference is. It’s an interesting result but without that error measurement, that’s all it is…interesting. It’s not necessarily conclusive.
Neither of these tires are good choices for anything other than smooth pavement. But that has been well known for decades. However, you are missing another reason for using narrow tires. That is one of constraint and design. Some bikes simply cannot use anything wider as they aren’t designed for them. Many road bikes…particularly older ones…will not accommodate anything wider than 25mm and that may be a stretch.
No, that is the wrong conclusion. To avoid pinch flats use the proper pressure. That’s going to depend on the weight of the rider/bicycle and the road surface. It’s not practical to go around constantly changing pressure on a single ride for varying road surfaces. If there is a section of pavement that has been rotomilled, it’s not practical to reduce the pressure from that used on smooth pavement just so that you have a smoother ride on the rotomilled surface. Use your legs…the Real® suspension on the bike.
Here's the thing. For some reason when people disagree on these forums they suddenly become very stupid (not you, others on this topic). What I mean by that is that when a variable or a data point is given, people lose the ability to consider things around said data point and will only argument based on that particular data point. That was the case here. A 25mm tire fares badly on rough surfaces so the diehards suddenly feel that you either must swap tire pressures constantly or some other silly thing.
The correct way of interpreting said data point would have been to do what people have always done. Set the tire pressure to suit what they want it to suit. If your ride consists of 90 % smooth tarmac and 10 % of gravel use the tarmac pressure. If it's the other way around do the opposite.
What I was aiming to do is to make a point to smd4 in a somewhat abrasive and pointed manner as he seems to have an extremely high resistance against logical and well mannered argumentation. And also facts. But the point was, that there are better ways to set your tire pressure than pumping them to 140psi. Finding and using the break point will make the ride both faster and more comfortable. However smd4 has in multiple topics stated that he does not care about speed, so I'm not sure why he bothers harking on topics which relate to speed...
Using your legs is viable but only for short sections. That's something you'd usually consider when setting tire pressures for the ride.
Finally, pinch flats are a symptom, not a problem. If your bike can accommodate wide tires…and even it if can’t…a pinch flat tells you that you have too little air in the tire for the conditions. A pinch flat should tell a rider that they are about to incur an expensive repair because their rim is bottoming out and is at risk of being bent. A pinch flat is a low cost repair and a warning. A bent rim is an expensive repair caused by an ignored warning.
I can't recall ever having pinch flatted. Back in the day I used high tire pressures and when I learned about this new fangled stuff about break points I just decided to Eff it. At my weight I need something wide enough to give me reserve for the really nasty occasions. Hence, I ride 40mm tires now. Also because we have a lot of gravel. I don't see a downside. If I decide to build me a set of aero wheels I may need to use 28mm with those.
And to dispel any hybrid bike zingers, those 40mm Terra Speeds are only 5 watts slower than the fastest tubular on the market (drum testing, break point watts unknown). For me that's a rounding error.
#107
You realize that based on the chart you posted, your comments here are total BS? The only time they run the tires below 60psi is on the drum, the rest of the data points start at 60psi and your estimate for lower pressures is an extrapolation of what you think the result would be based on the curve. The reason they probably didn't go lower for any other surface is something well understood by those of us who started racing on narrow tires; pinch flats suck and walking is slower. Again, my reply to you was that when it came to 20 and 23c tires, dropping down to low pressures would result in pinch flats, this is real world experience. Your "proof" is specifically for 25c tires, even the testers don't go below 60psi, and the optimal pressure for a 25c tire over the surfaces I generally ride is a solid 100psi, not some ridiculously low pressure. Not that I think smd4 has the right idea with his 140psi, personally I think that's nuts, but arguing an equal extreme in the other direction won't get you any further and ignoring the tire size he says he pumps up to that ignores the way these data points change with tire width.
Granted, 140psi is unlikely to result in pinch flats, but it is more likely to result in loss of traction when cornering, loss of control on rough sections, increased punctures due to penetrations etc.
As I mentioned earlier in my reply to cycco, the need to vary pressures with a particular tire, width, rider weight etc. is such an obvious self explanatory thing, that I didn't really see the need to emphasize it separately. I see now that I may have been wrong. Perhaps in the future I'll need to mention in every post that gravity is a thing and that is causing all kinds of effects you need to prepare for. And to remind people that they need to breathe during rides. And not to ride bikes underwater. You see where I'm going with this?
#108
You love being slow and bouncy. I can respect that.
What I can't respect however is that you come in every topic regarding speed and start behaving just like this. Your way is the best and when someone points out that's not great for speed, comfort or some other reason, you turn to the "BUT I LIKES IT!" -fallacy.
It's a waste of space. You never contribute. You're useless here.
#109
Expired Member
Liked 5,798 Times
And yet, Finland has been crowned (for a record 6th time) the happiest nation in the world....
#110
Liked 1,050 Times
You missed the point entirely. The point was to emphasize that it is as bad to use 140psi as it is to use 60psi. Both are slow. It is best to use a tire pressure near the break point, which in the case of the test behind said graph was around 110 psi +-10psi.
Now, if you want to argue something valid, should I make my daughter's tires 140psi on the basis of that chart since the surface of the velodrome is smoother than fresh blacktop being smooth and finished concrete and therefore closer to the surface of the drum?
#111
Quoted: 3643 Post(s)
Liked 3,082 Times
So why are you so obsessed by telling everyone your tires aren't slow? Correction, high rolling resistance. It's you the tires are making slow.
So I think you are being highly disingenuous when you say I'm "constantly obsessed by telling everyone [my] tires aren't slow." I certainly don't come in on every topic regarding speed--because, as you've noted, I don't care about speed. In case you aren't clear on it, the topic of this discussion isn't speed--it's inflation pressure. Go ahead if you don't believe me: read the title and the first post.
All of which begs the question: Why are you so obsessed with speed? Is that really all there is to cycling for you--just...being able to go from place to place as quickly as possible? Seems you might be missing out on the wider world of what riding a bike can be.
I'm really not into "speed," your conclusions to the contrary notwithstanding. I don't race; I don't ride in group rides where I'd need to keep up; I ride the local roads solo, or on the MUPs (known as "greenways" down here) with family. I go exactly the speeds I like to go. I don't feel exhausted at the end of rides, or feel like I got "beat up" by the road. Why for you is the end-all, be-all of cycling "going fast?"
Oh, and enjoying the ride I get isn't a fallacy, as much as you may wish it to be. I know--you don't have any way to argue or refute that point, and I suppose it's frustrating. Again, I'm sorry.
Likes For smd4:
#112
Quoted: 4597 Post(s)
Liked 1,754 Times
And there's where your over generalization fails and makes your argument pointless, because there are tires at which it isn't as bad to use 140psi as it is to use 60 and you're not getting it. You're working off 25c tires and going up from there, but plenty of people still ride 23c and I would suspect, for a few more years there will still be more modern road bikes that can't take wide tires and will have to run 23c. I just sold my 2015 road bike that with velocity a23 rims couldn't fit a 25c without tire rub. And the difference between 60psi and 140psi is so little that I would bet that a similar testing of 23c would have no difference and maybe even go the other direction. But you're so set on being right that you're willing to wipe away all variables to be correct and base everything on a test of a size that isn't even being discussed by those you are trying to correct. So yes, for generic rider A on a 25c tire you're correct, yay and congrats, now stop trying to tell someone who isn't generic rider A, and who isn't using a 25c tire, and probably isn't using modern width rims, that they're over inflating because you have no basis for making a broad, generalized statement.
Do you understand?
#113
Liked 1,050 Times
The data shows that the pressure vs rolling resistance plot is a trough, with the lowest rolling resistance being between low and high pressure. There is one of those charts for every tire size - including 23c. That doesn't mean anything other than riding well above or below that pressure is stupid.
Do you understand?
Do you understand?
#114
Mad bike riding scientist
Quoted: 6284 Post(s)
Liked 4,323 Times
If you read up on the Chung method you can evaluate the error. Especially in the Silca test they did a lot of runs which would with the Chung method render potential error to pretty small amounts. Also the Chung method is probably the only accurate way find the break point of any given rider as it does take the rider into the equation. That's the problem with drums as they do not include the rider.
It's not the wrong conclusion. It is A conclusion. You can make different ones.
I don’t know about you but “setting a tire pressure for the ride” would be very difficult for me in most cases because the surface of the ride varies widely over any given ride and changing pressure constantly would impede progress far more than Silica’s “impedance” would. We all use a pressure that is convenient and generally stick with that pressure independent of what we think we are going to ride on.
Now that is an interesting topic. Because if you need to use pressures that are above the break point for the majority of the ride to avoid pinch flats, that just tells me your rig is not optimal for the course. That can happen and frequently does. However if it's a regular ride one does often, it might warrant for getting a more optimized bicycle for said course.
Stuart Black
Stuart Black
Likes For cyccommute:
#115
Liked 1,754 Times
Right, and you've made no effort to show where that trough is on a 23 or 20c tire, nor that being on the high side of that trough is worse than being on the low side for those sizes, you've just made grandiose statements with no proof, now do you get it? For the tire sizes that were being discussed YOUR CHART IS MEANINGLESS AND HAS NO BASIS FOR COMPARISON BECAUSE TIRE SIZES MATTER TOO MUCH, which is why I can run my 2.25 mtb tire over roots at 30psi but can't make it down the block on my 23c tire at the same pressure. You're argument would be valid for a 25c tire based on that chart, but you jumped in on 20 and 23c tires and those numbers are going to change considerably. From memory, 90psi on an 20c was asking for a pinch flat, which is why people stopped using them, but even 70psi on a 23 is getting close to the point you will dent a rim on a crack in the pavement. Get it?
So you are just upset that there isn't a chart for every tire size and loading?
I don't see that as necessary since we already have tire charts that show ideal preload pressure. So unless the example with the 25c tires is wildly different than the recommended pressure charts, you can pretty much presume that ideal pressure recommendation is at or just below the break point, since the impedance is caused by not have the necessary 15% droop.
#116
Liked 1,050 Times
Grandiose?
#117
Liked 1,754 Times
Likes For Bald Paul:
#119
Quoted: 571 Post(s)
Liked 428 Times
It appears that the OP just makes up stuff.
Like they have in other BF threads here.
I'm quite sure they are just smiling happy at all the attention they are getting!
Likes For soyabean:
#120
I currently ride these:
https://www.walmart.com/ip/Kujo-Trib...0&from=/search
They have max psi 65 and I inflate to about 52 psi which is 80%. They're working fabulously for me.
I have a 2019 Honda Accord LX with max psi 51, which I inflate to about 40 psi which is a little less than 80% max psi. Door jam says 32 psi. I think car manufacturers are biased towards telling you to underinflate care tires because they want you to have a "smoother" ride. And from a previous question no, the most wear is on the front tire (because it's front wheel drive) and on the outer sides of the tire, not middle. I don't pay to rotate car tires. Just let the front ones wear down, then get a mobile installation via tirerack.com. Get the new tires installed to the rear and the rear older tires moved to the front for stability.
#121
Really Old Senior Member
Don't feed the Trolls.
#122
Liked 3,082 Times
Using “ignore” is the BF equivalent of putting your hands over your ears and yelling “NA NA NA, I CAN’T HEAR YOU!”
#123
However the silca article also had a previous test result made with 23mm tires. The break point was very near that of 25mm tires, which isn't surprising as there isn't a huge difference tire size or air volume.
#124
[QUOTE=smd4;22899353]You seem upset, having to resort to ad hominem attacks. I'm sorry you feel that way. Your command of the English language is exemplary. I admit I had to look up "besserwissering." So I'm not going to let you use your status as ESL as a crutch.[/QUOTE]
Takes one to know one.
You should however consider going easy with me as I seem to have difficulty conveying the meanings of certain terms to some people.
Besserwissering is german btw.
You don't care about speed but you seem to care quite a bit that in your opinion wide tires are slow, disc brakes are slow, modern bine tech is slow etc. And when you're called out you sidestep to your "i like the ride" fallacy. It has become fairly predictable at this point.
Inflation pressure directly correlates with the speed you can maintain with a given energy, ie. speed. Also we're not supposed to be 100% constrained by the topic title. Discussing things would be difficult if we were.
Inflation pressure is free. If I can get a completely free performance boost that takes next to no effort, I'll take it even if I'm riding slowly. Makes cycling more fun when I'm not needlessly encumbered.
As to being obsessed with speed, well me using 40mm tires should have already told you I'm not all that obsessed. I don't even own a skinsuit. Or aero wheels. I might get an aero helmet though. One of the cool ones with a visor. But if I go hiking I don't just fill my pack with rocks because I can. Rolling resistance is the second biggest drag in cycling after aerodynamic drag and it's not insignificant. If I can make that resistance less with a few presses from a pressure gauge, I'll do it in a heartbeat.
My "obsession" with tire pressures (if you can call it that) comes from mountain biking where you see and feel the difference much more drastically, especially with a fatbike. The difference of 1psi can make or break riding a certain section.
Personally I enjoy the faster speeds, the wind in my hair, seeing my enemies driven before me, hearing the lamentation of their mechanics, that sort of thing. For me it is more fun to ride 30kph than 25kph for the same energy (the tires themselves don't allow that but I don't have the energy to calculate the difference).
Also too high pressures cause vibrations which are fatiguing and can cause injuries especially when you ride 1500+km per month.
Oh it's not believe me. I truly do not care if you shake your tooth fillings out (although it is a funny thought). But you invading every fun topic and spewing your retro grouch narrative how everything new is bad for everyone and only bikes ridden should be hand built cinellis does get a bit old.
#125
It's really interesting stuff.
That’s not the way it works. The author of a paper should tell you their methodology and referring to another person’s method is perfectly legitimate. But the author of a paper should never tell the reader that they can measure the error of that author’s particular experiment by making the measurements themselves. That’s not how it works. The error in a particular set of measurements is particular to that set of measurements and need to be reported with the data. No one can exactly replicate anyone else’s exact results nor should they be asked to. Without that error information, the reader can’t evaluate if the measurement is valid or not. If, for example, the error is 0.5W, their measurement are valid. If the error in the measurement is 10W, not so much. But the way the graph is presented we, the audience, have no way of knowing if the measurement is valid.
I agree that it is a conclusion…it’s just the wrong one. Most people who do go to wider tires run them at even lower pressures. People with tubeless go to even lower pressures because they don’t pinch flat anymore but they do end up with dented rims.
I use my legs as suspension for entire rides. The mistake that most people make about bicycles is that they consider the saddle to be something that they actually sit on. It’s only there for support and, when properly used…i.e. by not putting your full weight on the saddle all the time… is not as uncomfortable as many people make it out to be. Tires, especially anything under about 40mm, doesn’t offer much in the way of suspension and comfort. It offers a little but it is only a “little” comfort.
But the level of perching and riding posture probably does have an effect just like body composition.
For road I usually take the paris-roubaix mentality so it's compromise between surfaces. A bit too soft for the shiniest new asphalt and a bit too hard for the roughest stuff I'll encounter. With 40mm tires the scale isn't wide anyways. For gravel it's always gravel pressures and no care for the asphalt sections.
That “break point” in the graph isn’t anywhere near where I would expect anyone to experience a pinch flat with the exception of the rotomilled pavement. 115 psi (8 bar) is bumping up against the limit on most 25mm tires. That’s the max on the GP4000S used in the Silica paper. At this point, about all we are discussing is the music to play for the angels dance on the pin head.
I don’t pinch flat either because I use the proper pressure. The current fashion, however, is to run on pressures are low as possible…and sometimes less than possible…for “comfort”. Many people talk about running 32mm tires at 40 to 50 psi which, according to the Silca pressure calculator, is appropriate for a 120lb (54kg) rider/bike/gear combination. The people running that kind of pressure in my experience are not 100 lb (45kg) people. For my rider/bike/gear, Silca suggest around 66 psi for normal pavement. I find that a bit too low for my tastes and generally run about 15 psi above that.
it needs to be said that the silca calculator isn't infallible. No calculator is. It's a starting point. I add a bit extra to my rear tire and use the front value of the silca calculator most times.
