Group enabling: AD-SLE Project.
#126
Edumacator
Liked 3,590 Times
Its the bronze chainrings, isnt it? i have this weird urge to buy up every bronze biopace ring left on the planet to make sure i always have one.
The "dont worry, I am a volunteer firefighter" hydrant lean pic I took to post to the "look at my bike leaning against stuff" FB group im in.
I took the straps off the pedals yesterday for my ride as I was going down roads I had not seen before and wanted to be able to easily bail if needed. The strap loops rattled like loose change so those are going back on immediately. Id rather flip down a hill attached to my bike than listen to that.
When you do finish the gold cabling, you might want a smaller loop to the rear derailleur.
Likes For jdawginsc:
#127
StillNewbieButInGrey
Bikes: 1982 Austro Daimler SLE, Eastern Alpaka 29er
Liked 214 Times
I agree. Definitely alot floppin around back there. Cabling seems to be an entire art form all in itself. I've got to get that done soon though because the black is killing my soul. I'll probably do it the next "week of rain" that we get, I don't want the bike apart on a beautiful day like today.
#128
Liked 214 Times
Alright. I couldn't take it anymore.
A bit of a hack job but it's gold.
Next up will be the FD cable. And when I change out the bar tape I will do the front brake, I think I am starting to get the hang of it....not really I didn't have anymore of the little end caps that keep the cable from fraying but I did have a box full of electrical connectors from back in the day so I snipped the tip off of one a clamped it down on the cable to keep it from coming apart and stabbing me.
Likes For Strawbunyan:
#129
Liked 214 Times
So I took some measurements and did some math.
I appear to have atleast 18mm of clearance on at the tightest points between the tires and any rub zones. I lowered that to 15 to be conservative and used the tire size= gap-3mm×2+current tire width formula
(15-3)×2+25=49
Can this thing really fit that big of a tire? or have I failed too many math classes?
that is a 1.95 inch tire and seems insane.
I am not interested in that large of a tire, I really think skinnier tires look cooler on these bikes and, as we all know, looking cool is priority numero uno. But if it really will fit that, the world is my oyster for tire selection it seems.
(15-3)×2+25=49
#130
Edumacator
Liked 3,590 Times
(15-3)×2+25=49
(15-3)×2+25=49
Also remember, the rear tire goes in closer to the seat tube, then gets pulled back into the drops, so you need a bit there to keep from having to deflate the tire when installing or removing.
#131
Bikes: A bunch of old bikes.
Liked 1,090 Times
My thought is that you should keep the AD on the tires you have now. You've written about the feel of the bike and the way it moves. Should you go wider, I think it will lose some of that.
Should the need for non-paved surface riding become greater, consider building a more gravel suitable rig. This can be done starting with a 90's hybrid without a great expense. Something in the 35-42mm tire size will be better in the small gravel without being miserable on pavement.
Likes For daverup:
#132
Liked 214 Times
The critical rub zone is between the chainstays at the crimp. I am pretty sure that was the limiter for me when considering tire sizes. I think I guesstimated a 32 was the max size.
maybe the 90s neon Japanese gremlin I have planned for the future will see bigger tires.....but probably not, I really do like the smaller tire look LOL. And as you mentioned i obviously love the way they roll. the fact that I don't have anyone to ride ride with and won't be joining any "gravel" races as I am not interested in driving 100 miles to ride my bike means I can choose my routes, so if I find a road the bike won't handle, I'll just stay off of it. If I decide in the future that I want one to be more friendly for harsher roads I will probably build a separate wheel set with the larger tires and only use them for those "events" but i wont hold my breath on that....most gravel racers i see on TV at current might as well be riding mountain bikes....it is just "XC light"..they have even started adding suspension as.. though it is a new invention they just discovered
The hippest thing i might do as a cyclist is tour the natchez trace and that is nothing but smooth pavement.
#133
Francophile
Liked 673 Times
Re tire size, on a bike like that I've found that the Grand Bois 30 mm wide tires work very well. They are a bit more forgiving than the Herse 28mm tires (which I have on other bikes and really like) yet do not look out of place on a racing frame.
Likes For Aubergine:
#134
Liked 214 Times
Obligatory drive side photos for the fans. 2nd commute to work, 3rd commute overall.
and a question.
My RD (and chain maybe?) makes a whole mess of noise when i go over heavy bumps. Is this normal? Should it be bouncing around like that?
EDIT: I am the world's biggest moron....the sound is my bike lock.
and a question.
#135
Liked 214 Times
I reallllly need to stay off the internet.
is it just me or do I absolutely need these levers and brakes for this bike?
WOW!
And look at this RD :O
Whhhhaaaatttttttt?
WOW!
Whhhhaaaatttttttt?
#136
Edumacator
Liked 3,590 Times
Derailleur is pretty, but likely limited.
Its definitely a rabbit hold I have found myself in! Bike part shopping I mean.
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
#137
Liked 214 Times
They are pretty for sure. No cable adjusters on the calipers would give me pause and it looks like the gold is worn off at the finger part of the levers.
And yes, this has become a much deeper hole than I imagined,my wish list has become a lot larger than originally expected. luckily my boss would kill me if i spent any more money on this stuff ATM, she keeps me down on earth level headed where I belong, so its all on paper for now and not strewn about my house hahahahahhahaha
#138
Edumacator
Liked 3,590 Times
I noticed the lack of cable adjusters and the ad said "untested" so I figured this particular example of them was probably going to need a second set for parts hahahah. I actually liked the wear on them....as that one country singet said...nothinn ain't cool till ya wear the new off
#139
Liked 214 Times
Really windy today, So I decided to get rid of the last of the black cable housing today.
I watched a video and read a few articles that said bar tape can be removed and rewrapped so I decided to just go for it.
it was not a success. The bar tape came off in multiple pieces and is going to be unusable. Ill have to go ahead and find a color i like and get it in route...Atleast I won't feel rushed with the housing now is cloth tape difficult to use? I saw something about shlaque?(I wish autocorrect could understand the words I butcher..no way I spelled that correctly...thick lacquer type substance).
Is leather bar tape a thing?
#140
Francophile
Liked 673 Times
#141
Liked 214 Times
That is the company I was looking at. I was on their web page and saw a that they have a lot options. I am assuming i dont need huge rolls of it, i saw that they sell it from very little to way too much.
round about estimate of the length one needs for a single set of bars? Should I order their SHELLAC(woo-hoo spelling) ? Or will any old shellac do the trick?
I know I can Google all of this but i am trying to stay involved with other humans and contribute to the forum however I can as opposed to just asking the AI bots. If my silly questions get annoying just let me know
#142
Francophile
Liked 673 Times
thank you!
#143
Edumacator
Liked 3,590 Times
thank you!
#145
Edumacator
Liked 3,590 Times
I have that one in my stash waiting for the right project...funny you picked that one!
Likes For daverup:
#147
Francophile
Liked 673 Times
