Anyone using a 46/30T crank on a road bike?
#126
Erect member since 1953
Bikes: Trek 520 Grando, Roubaix Expert, Motobecane Ti Century Elite turned commuter, Some old French thing gone fixie
Quoted: 121 Post(s)
Liked 38 Times
From FSA. I wrot ethem about wanting their product for my commuter bike:
ETA for the 170mm Mega Exo type Omega 46/30t cranks has been set at 4/24/2017. Which means they will be available for sale about 4-5 business days after. Use the below part # to place an order for a set around that time via most bike shops. You will what to find out what bottom bracket standard Motobecane used. The below Omegas fit and come with an BSA (English) threaded bottom bracket.
330-0158BJ3261 Omega Adventure ME 46x30 N10/11 170mm SB black V17 w/o BB,CK-4002ST/WT $ 156.99 retail.
#127
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Rereading this thread as I'm considering the Sugino OX901D crank and just wanted to acknowledge this beautiful bike and thank the owner for his informative posts.
@Mark Manner, how does Sugino deal with chainline? Spacers? What bottom bracket are you using?
My frame is PF30 and I'm using an Enduro TorqTite PF30 to Shimano 24mm bottom bracket with Ultegra compact road cranks. If I need lower gears the the Sugino would be my choice and I'm hoping that it would drop in without having to change out an expensive bottom bracket.
-Tim-
-Tim-
#128
Quoted: 37 Post(s)
-Tim-
-Tim-
Best, Mark [and thanks for you comment on my bike]
#129
- Soli Deo Gloria -
Liked 736 Times
The bike I'm building comes with 46/36 on some of the factory builds so chainstay to derailleur cage clearance shouldn't be an issue but thanks for bringing it up.
https://www.bikeforums.net/recreation...rdo-build.html
I'm tempted to just go with the Sugino OX901D and be done with it. It is soooo pretty.
-Tim-
-Tim-
#130
Quoted: 37 Post(s)
-Tim-
-Tim-
#131
- Soli Deo Gloria -
Liked 736 Times
I agree, they really are pretty. One thing a bit different about them is that you really do need to retighten the compression plug after you tighten the crank bolts. On my shimano cranks, the compression plug is pretty much just used to tension the cranks before tightening the bolts, and I have never had the crank arm loosen or move outboard after torqueing the crankarm bolts to spec, whether I tightened the compression plug afterwards or not. However, on the Sugino, I found that if you don't tighten the compression plug snugly after you tighten the crank bolts, the crank arm can move out. I had it happen today while riding and re-read the Sugino instructions and tightened the compression plug afterwards as they recommended.
Extremely interesting.
The Enduro TorqTite bottom bracket has angular contact bearings and the compression plug is used to set bearing preload. According to Enduro the stainless version gets only 3Nm. That's not much.
I'm thinking that tightening the compression plug again to keep the crank arms on tightly might cause too much bearing preload. I'd hate to decommission an expensive part like the TorqTite.
Do you think the Sugino crank arm pinch bolts don't hold the NDS crank arm securely enough or is this by design? My guess is the latter since it is in the instructions. What is the plug made of? Is there a torque spec on the plug?
-Tim-
#132
Quoted: 37 Post(s)
-Tim-
-Tim-
#133
Road Runner
I've now got my 46/30 FSA crank on order at my LBS (supposedly available in mid-May). I already have a BB360EVO BB and the bike was designed for this type of crank, so I don't expect any fitment problems.
One thing to keep in mind when going to smaller chainrings is that your front derailleur has to be moved lower down to achieve the specified 1mm clearance to the big ring. With a clamp-on, no problem, but I guess it could be an issue for a bike with a "braze-on" type mounting point. Again, since my bike was designed for it, the frame mount is installed with that adjustment range in mind. Otherwise, seems like it might present a problem with a carbon-frame bike!
#134
I'm 53, live in a very hilly area... Currently I have an Ultegra 50/34T 11-speed crank and a 11-32T cassette... On some hills I could use a lower gear...
Has anyone here switched over to a 46/30T crank? I have a conventional BB shell, so I can't use BB30, and my Di2 system limits me to a double chain ring and a difference of 16T. My absolute ideal would be a drop-in replacement for my hollotech Shimano Ultegra 6800 crank.
On most climbs, the 34T front with the 32T rear is fine.
What I did was to order a 6800 cyclocross crankset. Those are 46/36. However, I wasn't willing go give up the 34, so what I did was purchase a 34 ring separately and bodge the two together so that I now have a 46/34 on the front and the 11/32 on the rear.
Most Pinarello frames have bands for the front derailleur, so no worries there. The few days I used the rig last summer on the Hiawatha Trail, (ID/MT border, picture below), went well. No problems. (Well, except that for optimal comfort on the Hiawatha Trail, one really needs a bike with some type of suspension.)
So, if one is willing to accept 46/34 - 11/32 and stay 6800, this combination might work for you. (But I have to honestly admit that I'm keeping my 6700 triple bike for the really steep stuff.)
#135
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
I do understand that the 46/34T gets you tighter spacing, but making this change doesn't get you a lower low-gear.
#136
Occam's Rotor
Liked 2,331 Times
#137
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Great. Let us know how you like it. I may get this for my wife's bike.
I got bit by that problem with my 1987 Bianchi. For awhile, I had that IRD 46/30T crank pictured in the first post mounted, and I had to shim the derailleur to get it to work (an ugly fix, to put it mildly). Ultimately, I opted for the most elegant solution: A 52-42-30 triple with the corresponding front derailleur (Athena 11-speed).
I built up my unpavement rig with one with Di2 and no shimming was needed. Your Bianchi used a collar-clamp FD right? Or was it braze-on?
#138
Occam's Rotor
Liked 2,331 Times
No, sorry, different bike. I ran a 6-speed freewheel with it. (I also needed to change my short-cage Campy rear derailleur for a long-cage Shimano Tiagra, which had the merit of being silver-colored but was otherwise more blasphemy -- ultimately I decided to get an Athena-11 triple and a new wheelset.)
The Bianchi frame has a braze-on, but it was too high, so I tried putting a clamp adaptor below it, but could not get high enough with the braze-on there. I had the good sense (for a change) not to try to hack it off (having had the previous Bianchi frame crack there, I wasn't even going to think about it.)
My Di2 bike is a modern steel frame, and it has a clamp-on for the front derailleur, so putting the 46/30T on that (I used a White Industries crank) did not create any issues at all. Shifting is certainly smoother than with my nearly 3 year old Ultegra crank.
#139
Quoted: 188 Post(s)
@Mark MannerMark Manner out of curiosity what is the proper spacer setup for the Sugino 601D on a 10 speed set up? When I purchased mine the chainrings shipped loose with a bag of various Sugino chainring bolts and spacers and the instructions I got with it made no mention of the spacers..
#140
Quoted: 37 Post(s)
#141
Quoted: 188 Post(s)
Hi, I am not sure, I got a couple of the OX901Ds with 46/30 chainrings for an 11 speed setup, and they came assembled, no spare parts. For what it is worth, the chainline when I installed it seemed pretty close to the Ultegra 50/34 it replaced, so maybe you can find one and measure to compare. Sorry I can't be of more help.
#142
Hi, I have the Praxis in 48/32, and they are nice. However, if you wanted to use Di2 internal wire routing, the Praxis axle is too large a diameter to permit the internal wire routing through the bottom bracket. I have the Praxis on a bike with etap, and got the Sugino 46/30 for a di2 bike.
Anything different with Q factor of the Praxis...as compared to Shimano, for instance? I'm thinking of the same crank for a Ti build as well (and eTap).
#143
Quoted: 37 Post(s)
@Mark
#144
Q-Factor seems same to Shimano to me. I haven't measured it but I certainly don't feel anything different when riding this vs. a SRAM REd vs. a Sugino vs. a Shimano Ultegra vs. a Campy Record. One thing that seems to be noticeable about this crankset as compared to others I have ridden is that it feels really stiff. I think I notice it in particular on the bike I have it on, because it was a bit flexy in the BB area, and this seems to have made it feel more rigid. Maybe I am imagining it. The bike it is on is an old Ghisallo Ti. Great light frame but some flex in bb area.
Thanks for that! Very useful info.
#145
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1272 Post(s)
Liked 1,322 Times
FSA Omega MegaExo (48/32T and 46/30T and more standard options, BB30 and 'MegaExo' versions).
FSA Omega MegaExo - Full Speed Ahead
I know they do make other variants, because my wife just picked up a Cannondale 'cross bike that came stock with an FSA Omega MegaExo in 46/34T. She would love to swap that out for a 48/32T or a 46/30T...if only we could find one!
#146
Occam's Rotor
Liked 2,331 Times
I'm curious where you found any reference to the 48/32T and 46/30T variants; from the link you provided they only showed 50/34 in (3) different crank arm lengths.
Meanwhile, ...
https://www.bikerumor.com/2017/01/30...-road-gearing/
Here is one example (different from the one I originally linked):
https://shop.fullspeedahead.com/en/ty...-crankset-3781
Their website doesn't make things easy.
#147
After looking at the gear ratios again....I'm having second thoughts on the Praxis, as the difference (improvements) over my current 50/34 do seem minimal.
Considering the 40/60 White Industries now.
@wgscott have you noticed anything different with the Q factor of the WI, over your previous Ultegra? I had the same question for Matt regarding his Praxis. I'm asking because my feet overpronate outwards, and I've had to get longer spindles for my Speedplays for instance, so it's always something I consider.
Thanks!
#148
Occam's Rotor
Liked 2,331 Times
Thanks!
Thanks!
If I had to do it all over again, I think I would try the Sugino OX901D, primarily because I am not in love with the idea of having had to go back to square taper (and it would have been significantly cheaper). In addition, I was under the impression that the Sugino OX901D has a slightly smaller Q-factor than the Shimano Ultegra crank. (Double-check that, but I am pretty sure it is right.)
In retrospect, it would have been cheaper to keep my Ultegra crank and throw my Di2 Ultegra derailleurs in the trash can, purchase and install XT Di2 derailleurs, and whatever honking huge cassette I could find to go with that.
#149
Liked 406 Times
Yeah, it buys you about 1/2 a gear increment. I kind of wanted to get the Praxis since they are based in the same zip code I am, but I didn't think a 32 was significant. I can get a bigger gain by changing tires.
The Q-factor is larger, but it hasn't been a significant issue for me. However, I also over-pronate. (I got a lecture on it from my ankle surgeon, as if I was making some sort of morally delinquent lifestyle choice). My right foot also point out about 10 degrees, and as a consequence, I get a right heal strike occasionally at the center of the crank. This did not happen with the Shimano Ultegra crank (or my Campy Athena triple for that matter), or if it did, I never felt it because the profile of the Shimano Ultegra crank-arm is so smoothly rounded/tapered off.
#150
Occam's Rotor
Liked 2,331 Times
Depends on your BB shell. It, and the 30mm White Industries one, don't leave enough space in my BB shell, which is the conventional English threaded version (BSA). That's why I had to go for the square taper.
