Saddle Salvageable?
Bikes: 1971 Gitane TDF, 1974 Gitane Interclub, 2001 Serotta Rapid Tour CS3, 1986 Bruce Gordon touring bike, 1972 Gitane Super Corsa, 1978 Michal Johnson, 1972 Lambert Professional Grand Prix, 1983 Vitus (resto project), 1972 Raleigh Professional (resto)
Quoted: 43 Post(s)
Liked 34 Times
Saddle Salvageable?
Received an older Brooks Professional saddle earlier today that is dry as the desert and maybe, just maybe has some life left in it. The issue is that the large rivets are no longer flush with the leather surface. I’ve reconditioned leather saddles before but nothing as challenging as this. Mrs. Flying G would like to use the saddle but doesn’t want to be bitten in the backside by these exposed rivets. Maybe the saddle is shot and nothing can be done to return the saddle to usable condition.
Or . . . . . Someone on this forum might have some sage advice on how to transform this into a useable saddle at least for a few more years.
Photos attached and thanks in advance for your replies!
Quoted: 2304 Post(s)
Liked 2,740 Times
lots of threads on this, but go conservative, start with a good coat (top and underneath) of proofide
I would expect it will start to swell up with some coating, tightening in the gaps there.
Quoted: 3782 Post(s)
Liked 3,285 Times
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Hmm, thanks, guys! maybe I should have my user name changed to Don Rodolfo, eh? Has a nice ring to it.
Anyway yeah, rubbing some proofide on there might help. The leather may be so dried out that it can't hold a rider's weight for long, but no point in speculating about that. And no point in putting on more Proofide than the leather can absorb. If it's really that dry, I would let it soak up some neatsfoot oil. It can probably soak up a lot of neatsfoot oil before you notice any difference at all. Whether the leather can really be saved, I can only guess. Don't use heat to melt Proofide into the leather; the heat will further damage the leather.
As for the rivets, that's not a difficult fix. Hold the saddle against an anvil of some kind and tap the edges of the rivets down with a hammer. You won't need to hit them very hard. Each tap of the hammer should make a difference, but you will need to hit each one several times,
www.rhmsaddles.com.
www.rhmsaddles.com.
Likes For rhm:
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Think of saddle leather as skin, which it is. What do we use when our skin is dry and nasty? Water and lotion. I've revived worse saddles than this one using only cheap hand lotion. The magic happens here because cheap lotion is an emulsion of oil and water. Slather it in. The water will soften and dry, and the oils remain. You may have to do this several times to get the effect that you desire, but it'll work.
Old fart
Quoted: 3571 Post(s)
Liked 3,367 Times
You have nothing to lose by trying a little Proofide or other leather treatment. But the prominent central ridge suggests to me that it has been over-softened in the past, so keep your expectations appropriate.
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
Bikes: Still have a few left!
Quoted: 462 Post(s)
Liked 496 Times
Try and see how it turns out. I did one in similar condition recently, proceeded cautiously and only had to hammer down 1 rivet. You can still see some lanolin leather conditioner in the cracks. It's still a little hard a year later, so I plan some more conditioning over the Winter. Don
Quoted: 2350 Post(s)
Liked 1,728 Times
I wonder if it would help to find a socket that's about the same OD as the rivets, and tap on that, in order to spread the force out around the edge. You'd have to rock it around some, to accomodate the curvature of the rivet heads
2-Wheeled Fool
Liked 677 Times
Sure, why not? However, you can easily just use a small hammer and give it that hand-hammered look that we usually have to pay extra to get. I've replaced a lot of those rivets. Also, if you need new rivets, or just want to upgrade the rivets in your B17, Use copper roofing nails. Cut them off to the right length and hammer them nicely. They are about $0.06 each vs the $6.00 apiece that Brooks will charge you for essentially the same thing. Once they are hammered-in, they are indistinguishable from Brooks OEM rivets.
multimodal commuter
Liked 574 Times
Yeah, something like that, but it could be anything with a head small enough to fit inside the concavity of the cantle plate. I suspect most of us have something that will serve the purpose. I have a cutoff piece of I-beam that works very nicely, for example. In the past i used the head of a pickaxe, one end embedded deep in the ground, the other sticking up.
www.rhmsaddles.com.
www.rhmsaddles.com.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3846 Post(s)
Liked 6,437 Times
Quoted: 4493 Post(s)
Liked 6,297 Times
Agreed, but still can't hurt to play with it, see how it goes, get a feel for this sort of thing.
I would treat it and ride it a little bit for fun and evaluation then most likely save it for display on something as equally well loved.
Quoted: 43 Post(s)
Liked 34 Times
Great feedback from everyone and I do appreciate the responses and photos. I decided to take a slightly different approach to reconditioning this saddle. Didn’t have any neatsfoot oil and only limited amount of proofide which I was saving for the other leather saddles in the bike barn. I did have some clean mink oil on a shelf and decided to give that a shot.
Left the saddle and can of mink oil in the sun in the backyard during this morning’s club ride to warm things up a bit. Applied a layer of the mink oil, top and bottom, and worked it into those tricky hard to reach places near the adjustment screw. Let the saddle absorb the oil for about 4 - 5 hours and then wiped it off and used a horsehair shoe brush to buff it up a bit.
Results? The leather absorbed some oil and looks much, much better on top and underneath. The leather itself is still pretty tight but flexes a tad now. I reapplied a small amount of the mo to some dry spots and will let sit overnight. Do plan to tap down the rivets but suspect that this will be pretty easy to do.
Ran out of sunlight for photos but will post a few tomorrow afternoon so you can see the results. Suspect that I’ll need to mount the saddle, ride it a bit and re-apply the mo or proofide and do hope that the saddle is willing to reshape itself but not holding my breath. Fortunately, didn’t pay anything for the saddle so expectations are suitably low.
Don’t know why I get a kick out of these funny restoration projects but I do! Maybe there is an inherent pleasure in refurbishing what others cast off!
MTF!
MTF!
Quoted: 43 Post(s)
Liked 34 Times
As promised, here are the "after" photos of the saddle. Applied and rubbed one coat of mink oil into top and bottom of saddle - about 45 minutes of effort. Tapped the copper rivets to flatten them out using the suggested pickaxe in the ground and tapping with small sockets and hammer - about 2 minutes of effort.
Results? Even with low expectations, am pleased with the outcome. Leather cleaned up nicely, expanded a bit and looks less neglected. Stretch marks are more visible, especially around the rivets and left side of saddle but hey, don't we all fight that battle as we age? Rivet edges are flatter and less likely to leave bite marks in the backside and tear shorts. Would have tried to persuade Mrs. Flying G to give the saddle a try but one of her friends just gave her a black, unused B17 that needs a little love and proofide. All in life is timing.
Attempted to recreate the same photos but struggeled with light and shadows. The leather actually shows some gloss.
Copper rivets are now less dangerous.
Liverwort on the nose and stretch marks on the left side. We call that "character" where I come from!
Included 3 photos to give readers a sense of the progress of the efforts. Please excuse the poor quality of photos (old iPad) and shadows/lighting but I'm a low cost operation right now until I get things sorted out!
Old Saddle Restoration Score: 4 successes (Ideale 80, 88 and 92 and Brooks Pro) and 1 failure (B67 that exploded on first ride).
Thanks for the suggestions and ideas and I'll order neatsfoot oil for the next saddle challenge!
Quoted: 1858 Post(s)
Liked 605 Times
No it's not.
I just restored an Ideale Saddle that was much worse than that. Loosen off the adjuster bolt.
Soak it fully submerged in water for at least 24 hours, then let it dry out comepletely for at least a week.
After that apply generous amounts of Mink Oil top and bottom let it soak in and keep applying till it doesn'tsoak in any longer. My Ideale took a full 8oz bottle. After that "slowly" turn the adjuster bolt about a half
a turn daily until you find the desired tautness. As a previous poster stated leather is skin and it needs
moisture.
moisture.
Likes For Wileyone:
2-Wheeled Fool
Liked 677 Times
señor miembro
Liked 6,437 Times
señor miembro
Liked 6,437 Times
