1975 Masi Gran Criterium Carlsbad Made
Liked 8 Times
What would be a reasonable value for a Carlsbad made 1975 Masi Gran Criterium, 58cm center-to-top, excellent condition, original light blue metallic finish. Most likely built or supervised by Mario Confente.
Quoted: 3466 Post(s)
Liked 2,840 Times
Condition is everything, so is originality.
‘Mario was supervising in 1975 unless for a special few. Some high risk connections received his torch work, seat stays to the seat lug. The twin plate fork crown, but by 1975 that was gone, too much work.
to some, if the bike was made with investment cast vs the earlier stamped or “pressed” lugs will make a difference. 1975 was the transition year.
images of the front underside and back of the seat lug will tell the tale.
condition of the fork crown chrome matters. I do not know if they changed vendors, but the earlier bikes had better chrome.
Quoted: 609 Post(s)
Liked 795 Times
Incase your interested in the provenance you maybe able to match SN# here Masi Registry USA
Quoted: 609 Post(s)
Liked 795 Times
Found this bike registered as:
Steve Goodwin Light blue metallic C F VF 044 MC58 1975
Liked 2,840 Times
frame set appears in nice shape, I think stamped lugs, catching a hint of the seat tube tang holes. Quite a number of parts exchanges, they will knock the value to an enthusiast. Later front mech, Japanese rear mech,wrong stem, later rims and tires.
Liked 2,840 Times
A buyer at $1,000 yes
at $1,500 maybe
at $1,500 maybe
Likes For repechage:
