New Bike Day - Next Tuesday
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,035 Times
It's time to find a new home for my Diverge Comp. I got a trade-in quote today, but I'm going to try to re-home her before next Tuesday. It will be replaced with something which should provide more fun. Totally different but kind of the same.
It's 1x Dura-Ace Di-2, and Crabon as far as the eye can see! Crabon frame, cranks, bars, seat post and wheel. Hopefully it will help me get my monthly miles back up (I'm not a fan of August). I'll run tubeless, probably GP5000TL in 32mm to start with, but I could go as wide as 38mm. For some reasons I often refer to my bicycles as horses. The Diverge was the Pale Horse, the Roubaix is the Dark Horse. If I keep that up the new bike will probably have to be called the Green-Purple Unicorn.
All hints. Feel free to guess what the new bike will be. Pictures to follow next Tuesday or Wednesday.
Likes For MattTheHat:
Bikes: Most of my bikes are Single Speed Conversions
Quoted: 267 Post(s)
Liked 3,067 Times
S-works Tarmac ? 😱
Likes For OldCruiser:
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
Quoted: 267 Post(s)
Liked 3,067 Times
The S-Works Tarmac SL7 Pro is 1X 12
Quoted: 305 Post(s)
Liked 2,038 Times
Quoted: 762 Post(s)
Liked 4,035 Times
S-Works part is right. Not Tarmac or Crux or Diverge. Hint...I’m going to need to free up some space on my charging station in the man cave.
Quoted: 267 Post(s)
Liked 3,067 Times
Expired Member
Quoted: 3674 Post(s)
Liked 5,431 Times
Your miles might go up but you know with an ebike they don't count for anything. Sounds like a fun way to pass the time, nevertheless
Quoted: 305 Post(s)
Liked 2,038 Times
I didn't think you would go for electric
Quoted: 762 Post(s)
Liked 4,035 Times
I could be completely wrong, but I doubt the Creo will replace the Roubaix. I just like the idea of doing all the work myself. However...since I use the power meter to gauge my riding intensity, I’m thinking that I could likely do the same amount of work on the e-bike but just have more fun covering more miles. My primary hope is that my less intense rides (several per week) can be in the endurance range but still be fun. Right now recovery rides are kind of boring.
A secondary hope is that I can get a little bit of wear and tear off my knees. In really active months, they bother me a bit.
I rode one Tuesday and couldn’t wipe the grin off my face. But that was a short ride. It’s entirely possible that I don’t care for the whole experience on real rides. But from what I’m reading and watching that seems unlikely.
Quoted: 267 Post(s)
Liked 3,067 Times
I’d like to test ride one . 😎
I think one would make a nice addition to the stable, but it wouldn’t be my only bike .
How much does it weigh ?
Edit: I found the weight . 26.8 lbs . That’s probably less than most of my bikes .
Quoted: 762 Post(s)
Liked 4,035 Times
With the range extended that's probably closer to 30 pounds, though I don't anticipate riding with that too much. Riding with the power off wasn't too bad at all.
Quoted: 305 Post(s)
Liked 2,038 Times
That probably weights more than 80% of my bikes
Quoted: 305 Post(s)
Liked 2,038 Times
All things I’ve said to myself over the past few weeks.
Likes For cyclist2000:
Quoted: 267 Post(s)
Liked 3,067 Times
big Tires and heavy duty rims put a lot of my bikes closer to the 30 pound range . I need to weigh some of them , it’s got my curiosity up .
I can use my archery bow scale to weigh them . I think it goes up to 100 lbs .
Quoted: 762 Post(s)
Liked 4,035 Times
The bike didn’t make it to the LBS on Monday. It might have made it today (didn’t check), but the assembler was off. Hoping for tomorrow. And of course, rain here for three more days!
Quoted: 267 Post(s)
Liked 3,067 Times
Quoted: 762 Post(s)
Liked 4,035 Times
Just picked her up. I have some transparent sidewall tubeless tires to install and then we're ready for some pics. Except I think the weather won't be cooperating and I've got a 2 hour Zoom meeting tonight. Pics coming soon.
Quoted: 267 Post(s)
Liked 3,067 Times
Looking forward to seeing the pictures . 😛
Quoted: 762 Post(s)
Liked 4,035 Times
Picked up the new bike yesterday afternoon. Installed some Roubaix Pro Tubeless in 32mm with transparent sidewalls late yesterday afternoon and removed and waxed the chain. Got a new Garmin Varia radar rear blinky light and slapped that on along with setting up the integrated computer/headlight mount. Charged the Di2 and battery. Mounted the water bottle cages, adjusted the saddle and put on my saddle bag. Rode about 25 miles this morning.
If the bike is powered on, you get power numbers transmitted to your ride computer (if you pair them). I'm probably going to reset the low power range to the smallest power boost it will allow, either 0 or 1% so I can have the power data even when riding without boost. With the power off, on the flats it's very much like my Roubaix, but a little smoother, probably because of the added weight and carbon bars. In fact, after spending 15 minutes disassembling and tightening the integrated mount in the dark, I didn't realize the bike had turned itself off. I didn't notice it for about a half mile. Very, very smooth ride without power. But, I didn't get the bike to ride without power.
At the low power setting (30% of your power added) it's kind of like riding on a great day with a perpetual tail wind. So on a very average day you can probably better many of your PRs (though Strava doesn't count them) by a couple of seconds. Nice.
At the middle power setting (60% of your power added) it's more fun. I think I like this setting the best. It's noticeably easier on the knees when spinning up.
At full power (doubling your power up to 250 watts) it a lot of fun. Interestingly, though, you notice it more when moving a lower speeds, which makes sense. It's not a natural feeling at lower speeds. Not off-putting, but very obvious. When you hammer it at higher speed though, the boost isn't as noticeable. Once you're really hammering it, it almost feels like it's not doing anything. So, cranking up a 4-5% hill out of the saddle, you don't notice the boost so much. It does make pedaling out of the saddle feel different. It's a little hard to describe. I'm not sure if it's a low cadence thing or what. Maybe at lower cadences, the boost tapers off. I'm going to have to experiment. My gut feel is that the faster climbing would be spinning about 90 RPMs in the saddle.
I'm going to need a few more rides before I have a good feel for how the bike's brain is handling the power. But it's definitely fun.
One very unexpected bonus...I don't mind stopping. On a real bike, rolling up to a stop sign, I'm making every effort to time my arrival so I don't have to stop. I just kind of slow down until right of way is yielded, and keep going...and I sure don't stop to let cars go before me if I get there first. I won't talk about how I normally handle stop lights when traffic is light. My knees just don't like the strain of getting back up to speed from a dead stop. Even at the low power level, it really takes the strain off the knees. I even pulled a nicehole and waved a van on that I beat to the stop!
Shifting is very smooth. The Praxis crank/sprocket seems much, much stiffer than the Ultegra setup on my Roubaix, which I can see flexing. Brakes are very nice. Wheels are super smooth.
Quoted: 267 Post(s)
Liked 3,067 Times
Nice looking bike !
Quoted: 762 Post(s)
Liked 4,035 Times
Thanks!
After The second ride, my numbers above are off. I think I was in the 60% mode most of the time I was thinking I was in the 30 percent mode. Whatever the case the 100% mode is the fun one.
When I really work really hard it feels like I’m working against the bike a bit. Hard to explain. The maximum benefits come when you’re putting out right at 250 watts in the full power mode. Work harder and it’s like the power tapers off.
I did find that a longer hold of the power mode button puts it in bypass mode so the bike sends unassisted power data to the Wahoo. Problem is, it’s still flagged as an e-bike ride. So, no PRs even with power off if you want power data. Without power data you could cheat and record PRs even in 100% mode. Of course, you’d never again get a PR on your regular bike.
Very interesting ride. It will be interesting to see if riding it aids in recovery.
Quoted: 267 Post(s)
Liked 3,067 Times
Sounds like a fun new toy !
