Chain for a 15 speed triple chain ring
Quoted: 212 Post(s)
Liked 202 Times
Hi,
Would the chain length be the same as a 10 speed ?
I have a Schwinn Super Sport SP 1982.
Appreciate any and all help.
Thank you
Thank you
aged to perfection
Quoted: 856 Post(s)
Liked 1,288 Times
It's impossible to suggest the length from the info provided.
would need front and rear teeth counts, chainstay length and derailleur type at the least.
There are some ways to rough your way into the correct chain length. Looping the chain around the big - big combination, without the derailleur, is one way.
Mark Petry
Bainbridge Island, WA
Mark Petry
Really Old Senior Member
Number of speeds is irrelevant to chain length.
Wrap the chain around the largest ring & cog (don't run through RDER).
You want at least 1", but <2".
Bikes: Raleigh Competition GS, Freschi Supreme, Miyata 1000, Trek 520, Marin Pine Mountain, Specialized RockCombo, Soma Smoothie, Surly Cross-Check
Quoted: 99 Post(s)
Liked 269 Times
Advocatus Diaboli
Quoted: 4790 Post(s)
Liked 1,546 Times
Just in case you somehow already have what is currently sold as a "10-speed" chain, it will not work on your 15-speed Schwinn.
Quoted: 668 Post(s)
Liked 529 Times
Same length as the chain that is already on the bike.
Chains are sold with a standard number of links, The chain will then need to be shortened to match what you have on the bike. Chains get longer as they wear out, so easiest way to determine the length is to lay it out next to the old chain.
If the bike does not have a chain on it now, than you need to follow the directions of the park tool video
And like someone said you only count the cogs on the rear wheel when determining what chain "speed" you need. Your Schwinn will need the cheaper 5-8 speed chains.
Quoted: 212 Post(s)
Liked 202 Times
Thank you all for the very helpful advice....knowledge
I have a few sram 830 chains
I believe this will fit......minus a link or 2.
Please correct me if I am mistaken
Thanks again
Much appreciated
Thanks again
Much appreciated
Quoted: 1439 Post(s)
Liked 1,094 Times
After you size the chain, turning the cranks by hand, shift slowly and gently into the large chainring and large cog combination to be certain that the chain is long enough to not strain anything during the shift.
Quoted: 212 Post(s)
Liked 202 Times
Used the Sram 830 chain today !!
Fits perfect !!!
No links taken out!!!!
From the box to the bike. My friend who owned a bike shop for 30 years helped me.......well.........he actually did it while I watched
Thanks again for all the great knowledge and help.
Greatly appreciated
Fits perfect !!!
Greatly appreciated
