[Results and question] I restored an old Martano rim to a more matte finish
[edited to remove some inaccurate bits]
I thought I'd share the experiment I did tonight and ask your opinion on the results. I was trying to restore an old pair of Martano rims.
The rims are far from NOS, but I don't see anything immediately that indicates they are past the point of using. (I want to note here that I am very much a novice when it comes to mechanic work, so if you see something alarming please let me know.)
I wanted to shine them up but I don't have a buffing tool. So instead I got wet sandpaper in grits 800/1000/1500/2000/3000 and some simichrome. I wet sanded with each grit, and then dried and spread a thin layer of simichrome on.
The rims certainly look better, but they don't look new and a still have a few scratches. They are kind of a matte finish, and not a mirror polish, but I think I might be ok with that. But do any of you think my finished product looks cloudy or subpar? Did I need to start with a lower grit?
Also, should I keep sanding until they are fully smooth, or call it quits here? I was worried about going overboard with the sandpaper.
I took pictures of one of the rims after restoration next to one of the rims.before restoration. I also took one with a Mavic rim that I only cleaned up with soapy water. That one has a noticeably shinier finish which is one of the things that makes me wonder if I did something wrong.
Quoted: 3464 Post(s)
Liked 2,831 Times
Pretty sure those are Pista rims, the sides are not machined. One of the advantages of Mariano rims.
the brand graphic is later, a 1974 Masi would have the “winged’ or “ziggaurat” style graphic.
You need access to a bench or post mounted buffer and aluminum rouge.
Likes For repechage:
I think I will edit my post to remove some of those inaccurate bits but leave the stuff up about polishing. Maybe someone will find value in the photos of what sandpaper and simichrome will do for you.
I'll also try to track down a photo of the correct label... I could have sworn this one was right.
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,481 Times
Pick a small section of the rim and try repeated polishing with the Simichrome and a soft cloth to see if you can't bring out more of a shine.
Brent
Brent
"I have a tendency to meander sometimes." B.G.
Bikes: 1981 Bianchi Specialissima, 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1, 1950 Hetchins, 194X James Fothergill, 1971 Paramount P15, 1973 Paramount P12, 1963 Legnano
Quoted: 280 Post(s)
Liked 956 Times
I've never used Simichrome, but I use other polishes extensively. You should expect a mirror like finish even if polishing by hand. I would follow Brent's advice above and polish an area repeatedly with a little elbow grease and make sure you do a good buff at the end with a clean cloth.
Likes For SwimmerMike:
Quoted: 913 Post(s)
Liked 515 Times
Liked 2,831 Times
Visual reference-
one rim with old graphic
Wheel with grooved machined brake track
alternate not shown, flat.
Liked 2,831 Times
Quoted: 1143 Post(s)
Liked 1,758 Times
Looks like it's working good, I probably would wear gloves and may have started with 600 grit, then 1000, switch over to oooo steelwool, and finishing with your polish.
Note, the MA2 rim, you won't be able to match the finish. That rim is silver anodized.
