Old Mixte ID?
Old Mixte ID?
So this showed up in the Cincinnati fb marketplace (“vintage road bicycle” is the ad headline). It is a cottered crank mixte with what looks like a Simplex/Nervar combo. The rear brake is Mafac and is seat stay mounted with a pulley in the cable run. I looked at Gitane catalogs and Ficelle threads here. There appears to be only one decal, on the fork, and it’s not like a Jeunet or Le Jeune or whatever else my limited knowledge can come up with. Wondering if this admittedly low-res capture from the fb ad rings a bell with anyone. Thanks in advance. Maybe it’s a “J” or an “F” or maybe a “T” ??
Quoted: 3817 Post(s)
Liked 3,356 Times
ye shall receiveth not a great deal of assistnce with a single image o' the fok crown area
Bad example
Quoted: 841 Post(s)
Liked 251 Times
It is probably French. It has a Simplex front derailleur and shifters, and a Huret Allvit rear derailleur. Patterned chrome rims. Normandy high flange hubs, Mafac Racer brakes, what look like Lyotard pedals, and a cottered steel crank. Pretty standard French Bike Boom creation.
I've built up and worked on a ton of old French bikes. They are almost always a pleasure to ride even in stock configuration with the steel rims etc. The only parts I prefer to replace are the Simplex front derailleur and the chromed rims. i'd also consider replacing the Allvit on this bike because although it works well enough, the shifting takes some time to get used to. Once the derailleurs and rims are squared away the bike will be fun to ride even if it is heavier than bikes with more aluminum bits.
As an example, this Peugeot still has a cottered crank and mostly steel parts. But it has aluminum rims and the derailleurs work fine. And it was marketed as a racing bike! When I ride it, it certainly feels like one, despite its weight.
Was wondering what this one was, not because I’m buying it, but sheer curiosity.
