Moulton 16" wheels needed
I am in need of a 16" wheel set for my wife's Moulton project. I am willing to have custom wheels built (might try building them myself) or would be happy to buy prebuilt if that avalable to meet my needs. Need assistance with the following
1. Hoop recommendations, looking for a durable resonably priced hoop with a good braking surface that is avalable in the USA.
2. What kind of inturnal 3 speed hub should I buy? I am looking at the SA S30 with no brake. Is this a good choice? Is there something better in the same price range? Unfortunately I need to stick with a 120mm spaced hub as the trailing arm on this bike is not easy to spread for bigger hub spacing.
3. Any recomondatins for a prebuilt 16" wheel set with a 3 speed hub?
4. Any other wheel advice for a 16" build?
Thanks for any help
Thanks for any help
Bikes: Mezzo I4, Trek 1200, Rudge (Montague) BiFrame, Bickerton
If you are building the wheels yourself there is some useful info here: https://www.bikeforums.net/folding-bi...ng-thread.html
which 16 ? 349 is used by Bike friday for their Tikit, read they can get 24 spoke .
Brompton uses a 349, 28 spoke..
305 is on Da hons,etc ..
Sutherlands lists 5 more 16" rim sizes between those 2..
front hub folding bikes 74 mm wide , most others 10cm wide,
rear hub is needing the frame spread too ..
as I said Bike friday, or Calhouns in MN .. front as custom builds .. they are a Brompton retailer
SJS in UK is too ..
S-A does Make a 28 spoke hubshell .. simple ,, narrow enough, is buying a Brompton BSR, Wheel
its a NIG AW3.
for 24 hole rims , a 36 hole hub is used and holes are skipped.
chrome?, I see offered Below below, it has and will suck for braking , with rim brakes ..
the velocity aeroheat double-walled rims, being aluminum would be better ..
SJS in UK is too ..
its a NIG AW3.
I recommend the Velocity Aeroheat 349 as built by peter white. Scroll down to Aeroheat 349 near the bottom of the page:
Velocity Rims from Peter White Cycles
Quoted: 151 Post(s)
Liked 10 Times
85 for the velocity hub
40 for spokes
50 for labor
250.. for the front wheel..
seems reasonable
$95
16 x 1-3/8" Front Wheel - ISO 349
havent tried a new axle and cones and some spacers in mine ,
I took off when I got a $99 dynohubwheel there, but these are just $60.
https://www.calhouncycle.com/productc...idcategory=222
as said, it's also a 'takeoff'..
those 2 steel rims as a trailer wheel pair might be OK. ..
or a coaster or drum brake build.
in NYC that storage space for that cost a lot more than my Basement here..
another advantage to folding bikes . even pack-ratting is compact.
Possibly interested in the aeroheat built up front wheel and the hoops
Thanks
Dave
