Road brifters + MTB hydro brake ?
Old 08-27-16, 01:59 PM
Celika
Celika's Avatar
Bikes: Raleigh Maverick '15, Dahon Speed D7 ~2007, and a lot :)
Quoted: 12 Post(s)
Hello
I'm sure I'm not the 1st to think to this, but I wonder why there is no more exemples of it on the net. To connect the brake cable from road brifter to a MTB hydraulic brake, to have a powerfull an rather cheap brake upgrade on a disc road bike or gravel/CX. Like here:
https://www.lfgss.com/comments/9386609/
https://www.lfgss.com/conversations/246792/
There is 3 problem I see:
1-possibility that the MTB lever broke, or the cable connection
2-22.2 MTB bar diameter VS ~23.8 road (or 26/31.8 on central)
3-more weight than just a mechanical brake
But, for me (personnal opinion):
1-it's possible to made a connector without drill the lever (or with a lot of reinforcement), and if cable broke there is always the MTB lever to use (like CX additionnal lever), even if it's not really usefull on an emergency braking
2-it's just about ~1,6 mm at diameter, possible to grind with a dremel and I don't guess it will weaken that much the lever (depending of the model), sadly it would be hard to put it on central part of dropbar. There is some people using grinded MTB thumb****fter on road bar.
3-ehhh... more weight, yep , but not that much looking at the efficience of hydro brake
So, do you see others problems or cons-indications ? Some advice ? I would be happy to have others point of view .
I dislike to make Mcgyver-like hack on brakes, as it's pretty essential for safety, but have hydro brakes while keeping the normal brifters, and furthermore get additionnal levers, seems cool for me.
Celika is offline
Old 08-27-16, 02:22 PM
dabac
Quoted: 906 Post(s)
Liked 80 Times in 61 Posts
There are adapters made for that purpose. Rather sleek boxes that go below the stem. The only one I remember straight off was called a "doppelmoppel".
dabac is offline
Old 08-27-16, 02:27 PM
Celika
Celika's Avatar
Quoted: 12 Post(s)
Yep, i've seen some cable => hydro adapter, but pretty expensive (~150-200€).
There is hybrid cable/hydro brake too, like the TRP (about 100€/brake). It's basicaly the same than a hydro sytem compacted into a caliper, actuated by the cable.
Celika is offline
Old 08-27-16, 02:40 PM
jimc101
Quoted: 345 Post(s)
Liked 13 Times in 13 Posts
Well, can think of a few reasons -
It's ugly - There are better looking commercially options available, Hope do a converter box to start with - V-Twin or mechanical to hydraulic calipers like TRP HY-RD
The levers need adapters / machining to get them to fit( the levers are 22.2mm, where they are clamped on the handlebar in the image looks to be at the 31.8mm section), that's more work than most riders are able to do with out access to a machine shop/power tools.
The components (the Shimano disc brakes) in the image are several generations old, pre-mainstream road disc acceptance/availability, and they aren't readily available anymore. Also, that generation of Shimano disc brakes had some issue with temps (below zero) and the lever going wooden.
jimc101 is offline
Old 08-28-16, 03:09 PM
Celika
Celika's Avatar
Quoted: 12 Post(s)
Thanks for your answer
Personnaly I rather like the look it gives to bike, some mad Max style , but taste and colours ...
Seems the bar on the pic is a 26mm (no OS at the center, and anyway grind the lever to 31.8 would be pretty hard/impossible), as tools a milling machine or a press drill + adapted bit would be top of course, but a dremel + some sand paper cylindres + about 1,5 hour should be enough.
I don't think the model of brakes are that important, as long as the lever is far enough from bar to place the cable stop behind. But thanks for information about this model.
Celika is offline
Old 08-28-16, 06:47 PM
well biked
biked well
well biked's Avatar
Quoted: 91 Post(s)
Liked 26 Times in 21 Posts
There is hybrid cable/hydro brake too, like the TRP (about 100/brake). It's basicaly the same than a hydro sytem compacted into a caliper, actuated by the cable.
Sorry, but it's not basically the same. The selling point, of course, is to get near-full-hydraulic brake performance even if you are using brake levers with cables. The reality is that it's not much like a full hydraulic brake system in the way it performs, feels, etc. It's not necessarily a bad brake, but it's more like a cable actuated disc brake than a full hydraulic brake in regard to performance.
well biked is offline
Old 08-29-16, 01:52 AM
gsa103
Bikes: Bianchi Infinito (Celeste, of course)
Quoted: 630 Post(s)
Or you could just buy hydraulic levers...
gsa103 is offline
Old 08-29-16, 08:31 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 7201 Post(s)
Liked 718 Times in 465 Posts
The main companies are now making a Brifter with a Master-cylander on them and the Mechanical shifter too.
So the Cable to Hydraulic Under the stem converters are getting phased out.
TRP has had one, Hope UK, and Trickstuff DE.
Now The Combination of Gevenalle modified TRP Hylex Hydraulic Masters and a Indexed lever on the front
is being offered .
https://gevenalle.com/product/hydraulic/
But if you are un willing to pay the Current Market costs of your desires, Quench those wishes
and get something else with in your Budget dropping the Hydro part, likely, would be the first to Go.
the Same company Makes a Regular set cable brake & Shifter ..
fietsbob is offline
Old 08-30-16, 11:04 AM
Celika
Celika's Avatar
Quoted: 12 Post(s)
@well biked: of course it's not as good as a full hydro, but you get double piston system, better to tune.
@gsa103 and Fiesbob: it's the easyest way, but rather expensive (about 300 at least for the pair of brifters), while you can get a used pair of ultegra brifters + a brand new complete system of hydro deore for ~130: it's why I was thinking about this assembly.
Another way to have the MTB lever without grind them could be to use some extender like that
and put a MTB old handlebar in. But much more ugly, and less ergonomic (levers are more far from principal handlebar).
Celika is offline
Old 09-16-16, 01:34 PM
Celika
Celika's Avatar
Quoted: 12 Post(s)
Hello
No other point of view ?...
Thanks
Celika is offline
Old 09-16-16, 01:45 PM
jimc101
Quoted: 345 Post(s)
Hello
Thanks
The thread is almost a month old now, and until you bumped it, was well off the 1st page, like most forums, once it's off the first page, it's not likely to get many/any more replys (till someone re-resurrects this thread in 10 years time).
I think it had all the comments it was going to get, it's a pretty unusual question (as in very few people are ever going to use this setup), which has been well answered in this post.
jimc101 is offline
Old 09-16-16, 01:48 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Compile the Hydraulic Engineering data..You need the fluid displacement data on the Master Cylinder end
and the application volume requirement on the slave end.
Your turn, do the research.
fietsbob is offline
Old 09-16-16, 02:03 PM
redlude97
Quoted: 1924 Post(s)
Liked 177 Times in 129 Posts
They are more like hydraulic brakes than cable actuated brakes if set up correctly with compressionless housing. I am currently using both on the gravel bike and cyclocross. The brake force required and modulation is more similar to full hydraulic road levers. The self adjusting pads are more similar to hydraulic. Those only real difference is in weight. Whereas mechanical discs need constant adjustment to get full stopping power and prevent noise.
redlude97 is offline
Old 09-16-16, 06:09 PM
cobba
Quoted: 126 Post(s)
Liked 14 Times in 13 Posts
A bike shop in Switzerland used to do that sort of conversion a few years back.
Archived web page: https://web.archive.org/web/20110908...konverter.html
Maybe they still do it: https://www.dbikes.de/?rub=11&id=29&pg=det
cobba is offline
Old 09-17-16, 04:59 PM
Mr IGH
afraid of whales
Mr IGH's Avatar
Quoted: 347 Post(s)
Hello
Thanks
I didn't see what you had done the first time through. I like it, the cost of MTB hydro brakes is very reasonable.
How is the modulation?
Did you experiment with both pull ratios for the mechanical brake levers?
Mr IGH is offline
Old 09-18-16, 02:49 AM
Celika
Celika's Avatar
Quoted: 12 Post(s)
Sorry, I guess there is a misunderstanding, I haven't done the sytem for yet, just planned to do it but I would like to be sure before sacrifice a pair of brake lever and possibly make something dangerous. The idea seems so "basic" that I wonder if there is not a problem that I haven't see.
@cobba: thanks for the link, it's interesting to see that a shop have done that (but right now it's better to buy a pair of hydro brifter looking at the price ).
Following it, I've found this page:Cannondale F4 frame equipped with Campagnolo/Shimano/Grimeca/Formula/Miche components and a carbon rigid disc fork on velospace, the place for bikes ; the result is pretty strange but look like it work (brakes actuated by derailleur cable ).
@jimc101: sometimes a topic fall far away from 1st page, and maybe people concerned with it not always search in other pages, so maybe an UP could be interesting.
Celika is offline
Old 09-18-16, 09:39 AM
jimc101
Quoted: 345 Post(s)
That's the nature of forums, that if a topic falls off the first page, there will be less interest, unless you can change this, that's the way it will be.
jimc101 is offline
Old 09-18-16, 09:55 AM
wgscott
Occam's Rotor
wgscott's Avatar
Quoted: 2366 Post(s)
Liked 1,193 Times in 622 Posts
Personally, I wouldn't do it. What happens in a panic if you grab the wrong brake levers (i.e., the road ones that have been disabled)? You can get hydraulic road levers for about $250 now.
Shimano RS685 Road Disc Brake | Chain Reaction Cycles
wgscott is offline
Old 09-18-16, 10:39 AM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1405 Post(s)
Liked 291 Times in 176 Posts
Check Santana Tandems.
Way back in the late 90's Santana had a disc brake master cylinder that connected via a cable to a brifter brake lever. If they still have a supply of the parts, they are not going to be cheap and, if you like a clean minimalistic look, this ain't gonna be it.
Retro Grouch is offline
Old 09-18-16, 10:40 AM
Celika
Celika's Avatar
Quoted: 12 Post(s)
@wgscott: Why disable a brake lever ? The big idea is to use both the MTB and road lever (like a CX additionnal brake lever), depending on the position you have on the handlebar.
@Retro Grouch: it's near to the TRP Parabox and co ? Funny to see that the idea is not new !
Celika is offline
Bike Gremlin
Bicycle Mechanics
9
02-12-16 08:32 AM
bikeman732
Bicycle Mechanics
5
01-10-14 05:13 PM
Plow13
Bicycle Mechanics
3
08-30-12 03:43 PM
Plow13
Bicycle Mechanics
2
08-21-12 10:43 AM
nbrinto
Bicycle Mechanics
4
09-07-11 02:06 PM
