Need advice on Disc Brake upgrade
Old 10-15-11, 08:40 PM
DVC45
DVC45's Avatar
Quoted: 13 Post(s)
Liked 3 Times in 2 Posts
I need opinions for a Disc Brake upgrade
I have a 2006 Raleigh Mojave Hybrid. It came with a Promax disc brakes. I would like to upgrade.
What is a better mechanical disc brake out there?
DVC45 is offline
Old 10-15-11, 08:53 PM
cobba
Quoted: 126 Post(s)
Liked 14 Times in 13 Posts
Avid BB7
cobba is offline
Old 10-15-11, 08:57 PM
dsprehe89
dsprehe89's Avatar
Bikes: 2013 Stumpjumper HT
Originally Posted by cobba View Post
Avid BB7
+1. I just got the BB5's for my MTB, and they are amazing. The BB5's are literally the exact same as the 7's from what I understand, except the 7's are easier to adjust from what I understand. All I know is that my 5's stop me on a dime.
dsprehe89 is offline
Old 10-15-11, 09:00 PM
DVC45
DVC45's Avatar
Quoted: 13 Post(s)
My current brake levers and rotors don't need replacing, right? Just the calipers and pads?
DVC45 is offline
Old 10-15-11, 09:09 PM
dsprehe89
dsprehe89's Avatar
Your levers shouldn't need replaced, but I can't say 100% for sure, mine didn't and I had standard V-Brake levers. As for the rotors, the rotor diameter and thickness must match up with the calipers that you buy. If your current promax rotors are fairly old, I'd just suggest getting new rotors also. Rotors don't wear as quickly as pads, but they do wear and need replaced just like all other parts. I got my Avid BB5 rotors, calipers, and pads both front and rear for $75 off ebay, so it really isn't that expensive if you just shop around.
well biked
biked well
well biked's Avatar
Quoted: 91 Post(s)
Liked 26 Times in 21 Posts
No, the BB7's use a completely different brake pad.
well biked is offline
Old 10-15-11, 09:12 PM
dsprehe89
dsprehe89's Avatar
Wish I would have known that when I bought mine, cause I was debating between the two. I read on here somewhere that they were the same except the inner pad adjustment screw. Thought it was weird that mine were adjustable without having to use a tool cause that was what I read was the difference. Was that the old models that were the same with just different adjustment?
Old 10-15-11, 09:14 PM
DVC45
DVC45's Avatar
Quoted: 13 Post(s)
Thanks so much everyone!
DVC45 is offline
Old 10-15-11, 09:31 PM
cobba
Quoted: 126 Post(s)
The BB5 & BB7 have never been the same.
Both the BB5 & BB7 have inner pad adjusters but only the BB7 has a outer pad adjuster.
The BB7 has larger pads then the BB5 which can be seen in this photo.
cobba is offline
Old 10-16-11, 05:29 PM
gps_dr
GeoBiker / Mapper
gps_dr's Avatar
Bikes: 2007 Gary Fisher Piranha & ~ 1984 Ross Mt Whitney
Help!
Took the advice on brakes and upgraded my bb5 160mm to bb7 180 G2 rotor.
I was quite unimpressed with the bb5. Small pads wore quickly with me being a heavier rider.
They cost as much as the bb7 pads, and was tired of replacing pads several times per yer.
Lack of outer pad adjuster didn't help any. The new rotors have more slots to assist cleaning, cooling.
Bought two sets for $54 each. Front went on easily with post mount adapter.
When I took off rear caliper, noticed cable frayed under clamp. OK, got new cable & sleeves.
Problem is that the 180 rotor hits the back of the caliper slot w/o axle fully into it's slot!
The 20mm bracket that came with it should work, but it has the same offset as the 160mm bb5 adapter that was on my 2007 Piranah.
Going to larger rotor should mean more offset is provided by bracket.
Instructions with brakes were useless! don't even indicate which way the arrow on the bracket should point.
tried both ways, no noticeable difference.
gps_dr is offline
Old 10-16-11, 07:18 PM
cobba
Quoted: 126 Post(s)
Does the adapter have 180 R on it ?
The arrow on the adapter always points in the direction that the wheel spins.
Some photos of the set up might show where the problem is coming from.
cobba is offline
Old 10-16-11, 11:31 PM
gps_dr
GeoBiker / Mapper
gps_dr's Avatar
The adapter on the new/larger rotor/caliper combo says "20mm IS" bought two sets,
both had same adapters. My bike has a post front mount and the 20mm IS "post adapter" worked there.
The tab 20mm IS adapter isn't working on the rear for me.
gps_dr is offline
Old 10-17-11, 12:37 AM
cobba
Quoted: 126 Post(s)
The adapter on the new/larger rotor/caliper combo says "20mm IS" bought two sets, both had same adapters.
Adapters are front and rear specific, it sounds like you didn't get the right adapter.
Where did you buy the brake kits from ?
Some adapters for fitting a PM brakes to IS forks can can be turned around and used on the rear to fit a smaller rotor
eg. 160 front = 140 rear, 180 front = 160 rear, 200mm front = 180 rear
Forks/Frames can be either IS or PM and brakes can be either IS or PM.
If you have a PM fork and a PM brake you wouldn't use any type of IS adapter.
* You could use your new BB7 with the old 160mm rear adapter and 160mm rotor on the back till you get a new 180mm rear adapter, depending on your riding style and where you ride you mightn't even need a 180mm rotor on the back.
cobba is offline
Old 10-17-11, 03:17 AM
Digital_Cowboy
Digital_Cowboy's Avatar
Bikes: Specialized Hardrock Mountain (Stolen); Giant Seek 2 (Stolen); Diamondback Ascent mid 1980 - 1997
Quoted: 62 Post(s)
As is shown by my signature, I have an '05 Specialized Hardrock MTB. It has mechanical disc brakes on it, of late I have been thinking of upgrading it to hydraulic disc brakes. Any suggestions?
Digital_Cowboy is offline
Old 10-19-11, 12:36 PM
gps_dr
GeoBiker / Mapper
gps_dr's Avatar
Jensen is sending the correct bracket today. (no rear bracket was included in kit sent).
gps_dr is offline
Old 10-19-11, 02:02 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 7165 Post(s)
Liked 692 Times in 450 Posts
IRD has an interesting caliper, their 'Dual Banger' pinches the disc from both sides,
all others push the disc into a stationary pad.
In that, they, the double acting mechanism,
are more like Hydraulic brakes in that way..
hydraulics self adjust for pad wear, mechanicals, it's something the user does.
fietsbob is offline
Robbo2015
Bicycle Mechanics
14
08-25-14 11:49 AM
bengreen79
Bicycle Mechanics
1
08-23-14 11:30 AM
rgdenis
Bicycle Mechanics
2
01-17-13 03:59 PM
seymourson
Mountain Biking
4
04-05-11 08:50 PM
