Easton EC90 aero tubular questions
Quoted: 170 Post(s)
Liked 264 Times
I have a nice set of Easton EC90 Aero tubular wheels (r4 hubs) that I'd like to get back on the road. Previously set up with glue and 22mm Conti Competitions (flatted these after 200 miles of riding).
1) I'm looking for tire recommendations. Would like to try a 25-28mm wide tire, as the roads around here are pretty bad. On clinchers I've been happy with the rolling resistance and durability of GP5000s, so something in an equivalent class would be great, if possible.
I'm assuming 30mm Pave's would be much too wide for my rims; pls correct if wrong on that: https://www.biketiresdirect.com/prod...320-tpi?sg=500
2) Would also appreciate suggestions for tubular tape. Would Tofu or Velox Jantex suffice?
thanks!
thanks!
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Do NOT use tape. I don't care what anyone says, it is not the correct way to mount tires. Pro racers are pretty much the only ones still using tubulars in large numbers and I have NEVER seen one ride a tire attached with tape. I would know because I was a pro team mechanic for over a decade including road, cx, and mtb. Your rim width isn't the determining factor for tire size, it's the brake...and what size will fit inside it. If you have disc brakes that obviously isn't an issue.
Glue your tires (or have an experienced mechanic glue them), it's the only reliable way to do it. I have pushed taped Conti tubulars right off a carbon rim, it was like there was zero adhesion. I prefer Vittoria Mastik 1 over any other glue. I've mounted well over 1000 tubulars over the years and it's the only thing I'll use. I'm sure there are others that work well but given what I can reliably get and my personal experience Vittoria is my go-to.
Likes For woodcraft:
Quoted: 170 Post(s)
Liked 264 Times
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
You're not ripping a tub off mid-race in a triathlon that was glued normally.
But, that would by far be the exception rather than rule.
Bikes: lots
Liked 2,932 Times
Thanks for in the info. Given your experience, what road tubular tire would you recommend for training? I average 250-350 miles per week, all road miles. I'd like to avoid Conti Competitions this time around as they didn't last long and the second set developed multiple punctures after 200 miles. On clinchers, I run gp5000s which have been durable enough for me (usually 3k mi for the rear and 5k for the front).
I started riding Veloflex Vlaanderen 28’s three years ago. Nothing I have ridden in 40 years on tubulars comes close. Expensive but worth every penny. They have changed their lineup with the pro tour replacing the Vlaanderen.
Now if you want to try your wheels and decide whether you like them or not the Rally’s are perfectly serviceable tires.
Quoted: 1814 Post(s)
Liked 923 Times
+1 on the Sprinters. Where other tires come back from the rides with glass cuts, embedded bits, & eventually leaky performance, the Sprinters go and go without issue (IME).
I have 23/25s on, at about 70 psi which compensates for the slightly lesser ride quality vs the nicest tires. I had older EC90s for years til they wore out- good with occasional excitement in cross wind gusts.
this was the previous 25mm Sprinter- not sure the miles but a lot, & no flats.
Bikes: lots
Liked 2,932 Times
