Heavy backpack, 12 y/o boy school commute.
Quoted: 566 Post(s)
Liked 1,053 Times
I normally linger around the Classic and Vintage section but I recently bought my 12 y/o son an older MTB in his size (XS) and he LOVES this thing. He wants to start riding it to school, which is great, but his backpack is HEAVY!! I’m talking 20+ lbs. My son is ~85 lbs, 5’ tall and extremely fit FWIW.
Besides wearing the backpack like he normally would is there a better option for carrying this monstrosity? I don’t commute but I would imagine carrying that much weight relatively high up - front or rear rack over the wheel - would make handling dangerous. Alternately, putting all that weight on one side in a pannier could also make handling dangerous.
Any thoughts/suggestions?
Half way there
Quoted: 987 Post(s)
Liked 880 Times
Panniers are the way to go here. They will change the handling a bit, but since the weight is near the axle stability is good. When I commuted, I carried up to 40 lbs that way, distributing the weight on each side. I used Banjo Brothers saddle bags, that allowed me to quickly remove and carry.
Here's another option to consider: Assuming that most of the weight is textbooks, buy used copies of those books that you can keep at home. That way you reduce the back and forth load. We did that for my youngest daughter and it worked great. Most of the textbooks are common and can be found cheaply on eBay etc. Just make sure that you get the right edition.
Good luck
Good luck
Last edited by Moe Zhoost; 10-30-22 at 09:41 AM. Reason: to edit "addition" to "edition"
Likes For Moe Zhoost:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Basket is good. But consult with the kid before you drop a solution on him. Style is important and getting more important for a kid in junior high. He might choose to hang onto the backpack if it means not looking silly to his friends with some jet black grownup bag with ten pockets
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
If you can fit that bike with a rear rack, simply strapping the pack to the top of it while riding might be an improvement, while allowing him to maintain a little bit of street cred.
Likes For Polaris OBark:
Quoted: 566 Post(s)
Liked 1,053 Times
Moe Zhoost Thanks for the Banjo Brothers link. I was also thinking baskets might work, that way he can easily insert/remove his backpack but I would need to find something kinda stylish. Image matters in middle school!
Interesting idea about the text books. I’ll definitely look into that. The single weightiest object is probably his Chromebook. I’ll start rooting through his stuff and see how we can lighten the load.
Likes For RustyJames:
Quoted: 566 Post(s)
Liked 1,053 Times
Quoted: 1364 Post(s)
Liked 1,678 Times
I put my backpack on my rear rack...here's how:
Likes For BobbyG:
Quoted: 566 Post(s)
Liked 1,053 Times
https://www.youtube.com/watch?v=SbRgLq2F3PA
Relevant to this discussion, my little cherub has ADHD so careful and deliberate are not in his wheelhouse. Full throttle and consequences be damned!
I’m looking into stylish pannier style baskets at this time since I think those would be the best solution. I’m still open to suggestions, of course.
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
I used to ride with a loaded rear basket on a 700c wheel, drop-bar bicycle. Riding this combo wasn't dangerous at all. There were two issues that the rear load introduced, though.
1. It requires extra care in holding the loaded bicycle upright during the times when it's not being ridden. Not too complicated to overcome.
2. Mounting this bicycle requires lifting your leg higher up, to get it over the rear load. Probably not a problem for your issue-less kid.
Here's the components that I recommend:
Use a rack with a top platform that's flat enough for the basket. They're usually available in black.
Wald #198 basket in black, fastened with black velcro wrap-straps to a black rear rack. If the backpack needs a wider basket, the Wald #1372 in black, strapped to the same rear rack, plus a small, black carabiner for additional security. It's all black, so, probably less visible than the bicycle itself.
Likes For Nyah:
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,538 Times
I''ve successfully used rear baskets held to the rear rack w/zip ties to carry various loads and shapes. Basket can come from Wald or even some old metal refrigerator storage bin baskets work quite well. Don't know if the aesthetics would meet a teenager's approval.
Quoted: 566 Post(s)
Liked 1,053 Times
Thanks for the feedback everyone. Little man insists his backpack will be fine. Short commute for him (~1 mile) so he may be right.
Quoted: 2333 Post(s)
Liked 2,097 Times
Good for that little boy!!
I'm jealous, the nanny state here would not even let my son walk 300 yards to school. AND, it was a 45-50 minute bus ride in the morning because naturally he was the first pickup.
He'll love riding to school. I don't think the backpack weight is much an issue, I used to ride with a golf bag over my shoulder to get places more than a mile
Quoted: 1562 Post(s)
Liked 1,734 Times
QR-disc must die!!!
Quoted: 397 Post(s)
Liked 199 Times
I know the OP has already made up his/her mind, but,
this is for anyone else pondering the idea for thier
own kids:
Orient the basket lengthwise with the rack.
It keeps the weight of the contents more centered
with the bicycle and the air resistance minimized.
own kids:
QR-disc must die!!!
Quoted: 397 Post(s)
Liked 199 Times
I prefer velcro wrap-straps instead of zip-ties. They allow unlimited adjustment, as well as removal of the basket without cutting the strap. They come is lots of colors. Use black ones for your kid's ride.
Quoted: 566 Post(s)
Liked 1,053 Times
That is true. My son is in the exact same boat as the OP's son. A few days ago I put a pannier rack on his bike and zip-tied a milk crate to the rack. Kid complained that it looked 'too third world'! Now I have to buy a black wire basket. Hopefully it looks less 'third world'. Dang kids and their first world problems!
Not 100% but what I am looking for doesn’t seem to exist and I would need to cobble it together. My ideal solution would be pannier style baskets or bags that are ~8” wide, hard-sided (wire mesh?) and fixed in place, NOT easily removable. All of the panniers I saw are designed to be easily removed. Style points, need those too.
What straps to you use for this? How do you attach them to the seat and rack?
Liked 1,678 Times
Liked 1,678 Times
It depends on the dimensions of the bag the flexibility of the cord and the distance of the seat rails (or post) to the end of the rack. A longer cord can always be wrapped around the end of the rack and anchored further forward to shorten the diagonal section.
A cheap, multi-length selection of bungee cords can usually be found at Harbor Freight, Wal-Mart, or any auto parts store. I think mine are usually around 2.5 to 4 feet.
From when I was a kid until now, I always prefer just a backpack as well. What made a decent difference (if his backpack doesn't have one already) was getting a backpack with a sternum strap. I live in a hilly area and climbing out of the saddle with the pack more tightly secured felt a lot better than when the weight shifted around. I don't carry enough to want an additional waist strap, just a sternum strap is my preferred compromise.
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,000 Times
Whatever works it varies so much there is no real answer. The only suggestion I will give is Highland Fat Straps. They are the best bungee cords out there. They are flat and well constructed, I have had mine for years and years with no issues.
Quoted: 1952 Post(s)
Liked 2,013 Times
We still have no picture of the bike!
1 mile? A lower saddle height than would be optimal for us will be optimal for him. Raise the bars and sweep‘em back some and No racks. Get his pack to ride low on his back and as mentioned above, get the books out of it if possible. eBay is your friend here. Cool kids pedal — dig it.
