Recommend a 1/4" Drive Digital Torque Wrench
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Recommend a 1/4 inch drive digital torque wrench. 3 to 15 Nm would be acceptable range. Should be ratcheting and not too long.
I'm not interested in beam or click types, nor am I interested in hearing about them. Thanks anyway.
Some of what I'm seeing out there are only guaranteed accurate above 20% of the operating range. I would like better.
I don't mind spending money for something nice and was looking at this Proto for reference. 1.5 to 30 Nm, 16 inches long. +/-2%. Pricey though.
I'm open to reasonable suggestions.
-Tim-
-Tim-
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Don't know of a cheaper 1/4" drive digital...I have this ACDelco 3/8" drive digital that does 3-50Nm IIRC:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Even Topeak's one is 3/8" drive, and double+ the price:
https://www.amazon.com/Topeak-602000...dp/B002FP9FHM/
-Tim-
-Tim-
I'd look at CDI's offering, as well. If you want to spend a bunch of money, snap-on.
Bikes: 1978 Jack Taylor "Tour of Britain", 2010 Cannondale CAAD9-4, 2013, Cannondale Supersix Evo Red Racing, 1969 Jack Taylor Ladies "Tourist" (wife's), 2010 Specialized Dolce Sport (wife's)
Quoted: 17 Post(s)
I don't understand your range for the Proto. It's range is 10-100 FT/LBS. That converts to 14-136 NM. If you want 3-15 NM that converts to a range of 27-127 IN/LBS. I would look for a wrench with a range of 10-200 IN/LBS or 1-23 NM. I'm afraid you will find them expensive.
Quoted: 336 Post(s)
Liked 309 Times
Stahlwille has a 1-20Nm that is 4% across the entire range. Stahlwille is a great brand; we use their angle-sensing digital torque wrenches where I work.
https://www.kctoolco.com/stahlwille-...tooth-ratchet/
Quoted: 336 Post(s)
Liked 309 Times
I prefer cam-over or slipper torque wrenches to click, beam, and digital torque wrenches. These are the only style that I have found that are really fool proof in not allowing over-torque.
- Soli Deo Gloria -
Liked 736 Times
Are you able to suggest a brand or model?
-Tim-
Non omnino gravis
Quoted: 2604 Post(s)
Liked 1,933 Times
Oh, really? What's the zip code for "Nowhere, Fast?"
Ayup, bought a click-type wrench after I stripped a stem (S&S coupled bike), and it's been a few years since I used the bigger torque wrench.
Meanwhile, I'm staying over here using a torque wrench from the Harbor Freight (with a companion Ritchey Torkey) because I work on bicycles, not Mars rovers.
Looking forward to the eventual write-up on the $500 torque wrench, though.
User pre set click torqkey, when you hit target torque number is another option ..
Come up to the Pro level, like Snap On and you can get a periodic re calibration
for the search impaired ; https://healthyhandyman.com/best-1-4-torque-wrenches/
Quoted: 336 Post(s)
Liked 309 Times
I never said that cam over and slipper torque wrenches weren’t total overkill for working on bikes. I don’t own them, I use them at work where we do build high tech equipment.
It it is very possible that the OP derives pleasure from owning the best tools possible. They asked for options and I gave them. The OP isn’t spending my money, so if buying the absolute best tool for a job makes them happy, I say go for it.
Quoted: 336 Post(s)
Liked 309 Times
Non omnino gravis
Maybe I work on other things besides bikes? Will I offend you less if I spend $276?
https://www.protorquetools.com/1-4-d...rench-2401ci3/
You can act like a real ass sometimes.
Live your own life, not mine.
-Tim-
-Tim-
Whatever overkill option you go with, I'm sure you'll both be very happy together.
Quoted: 111 Post(s)
Liked 5 Times
-Tim-
-Tim-
Most high-accuracy digital torque wrenches are non-ratcheting.
Grainger lists a lot of stuff but has kind of a high markup.
https://www.mscdirect.com/ is where I get much of my machinist tools. They show a few 1/4" digital torque wrenches, for $500 - $750. Most are made in the USA, with a couple Euro companies in there too.
IMHO you are about to waste your money. Any digital, industral-grade torque wrench is way more precise that will matter for anything on a bicycle.
I just have some beams and clickers myself. My little one is a Park 1/4" beam. I think it cost $32 at the time but Park seems to have stopped making beam wrenches entirely now. And their clickers cost WAY more than the beams did...
Amazon is showing some 1/4" beams for $20 to $40.
