Pairing Shimano R8000 crankset with 10 speed rear mech- any compatibility issues?
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4387 Post(s)
Liked 3,016 Times
My current drive train has an FSA-SLK crankset with a BB30 and a 10 speed (7900) RD. The bottom bracket has been a royal pain and needed replacement nearly every year. Talking to the folks at my LBS today, it was suggested that I replace the crankset with something like an Ultegra R8000 that might give me a more durable BB.
But the R8000 was designed for 11 speed, rather than my current 10 speed. If I mix and match, are there likely to be compatibility issues or problems with smooth shifting?
Liked 2,968 Times
Fwiw i went from the flatbar trig shift, a mtb front der & mtb triple that used a square taper to brifters, road front der & road triple that required the oct bb. No issues.
-Oh Hey!
-Oh Hey!
A bit off your question, but I was looking today at compatibility of 5800 and R7000 crankset and found out that the new R7000 has the inner ring 0.4 mm inside than the previous 5800.
Similar with Ultegra and Dura Ace. Then I went to check which FD I have bought when I built and found out it is a FD-5801 - that is compatible with R7000 crankset
https://productinfo.shimano.com/#/co...453&acid=C-455
I had for a few miles (like 20), front 105 5800 50-34T and rear cassette Ultegra 10sp (12-30) paired with RD-5800 (11 sp).
Worked without problem .... I didn't adjusted fully because was just trying out a rear wheel build (my first). I didn't have prob shifting.
Basically swapped the rear wheel and adjusted the limit on RD.
I’m running an 11 speed 5800 crankset with my 10 speed 6750 derailleurs, 10 speed chain and 10 speed cassette. Works fine, actually works better than the 10 speed set I replaced.
Liked 3,016 Times
Liked 3,016 Times
Liked 3,016 Times
While we're at it, do people have opinions about the advisability of doing this to improve BB performance? As I said, the FSA with the BB30 has worn out about yearly (admittedly, I put a lot of miles on that bike - 3-4k/year, but bottom brackets should last longer than that! ). The idea is to switch to the shimano/hollowtech technology using a BB30-24 adaptor. How much should that help?
Are there other options I should consider?
Quoted: 338 Post(s)
Liked 408 Times
I have a 10 speed drivetrain and use 11 speed Dura-ace chains. Shifting works perfectly well, and probably better than older 10 speed KMC chains. If there was any problem with 10 and 11 speed stuff meshing together, there'd be a problem.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Any Shimano 11 speed crankset will work with 10 speed rear. You should have zero anxiety about fit and function. It will be fine.
Consider a Praxis conversion bottom bracket.
https://praxiscycles.com/bottom-brackets/conversion-bb/
Or, if you have the funds, an Enduro Torqtite.
-Tim-
-Tim-
Quoted: 336 Post(s)
Liked 309 Times
Liked 3,016 Times
-Tim-
-Tim-
Quoted: 453 Post(s)
Liked 104 Times
Have you considered what bearing you are currently using? maybe trying a different spec, say Enduro?
- Soli Deo Gloria -
Liked 736 Times
Wheels Manufacturing makes a similar product for BB30. There is nothing to press. Like the Praxis Conversion and Enduro Torqtite it simply screws together.
https://wheelsmfg.com/pf30-threaded-...-bb-black.html
This is what the Enduro Torqtite looks like...
-Tim-
Liked 3,016 Times
Praxis and Enduro Torqtite are similar concepts. They screw together into the bottom bracket shell and will not creak.
-Tim-
-Tim-
It looks like the Enduro costs about twice as much as the Praxis or the Wheelsmfg. What does one get for the extra coin?
- Soli Deo Gloria -
Liked 736 Times
Gout de Diamants Champagne. Bugatti Veyron. Rapha Pro Series. Shaken, not stirred.
-Tim-
Liked 3,016 Times
gotcha. Thanks again.
focusyourself
Bicycle Mechanics
9
03-16-15 05:47 PM
pino1biker
Bicycle Mechanics
5
04-08-14 10:51 AM
j814wong
Bicycle Mechanics
6
11-03-13 10:57 AM
